displaying posts 26 to 50 of 168
Pages (7): 1 [2] 3 .. last
Author Subject: 306 (k20 inside)
306 Rxs
I try to keep it low cost as possible, but the project is now passing the 5k by a small amount.
The gti6 engine is already being assembled, but with some goodies of course!!
Newman ph3 camshafts
Newman springs and tappets
Wossner high compression 86mm forged pistons
Copper and lead bearings
All the block internals were balanced (crankshaft, pistons, rods, flywheel...)
Magnex de cat exhaust...
What is a hybrid?
Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering...
Posted 12th Feb 2012 at 18:57
jeffers Forum Admin
atterz wrote:
That would be spot on mate! You buy a lot of stuff from the UK!
Them brakes look spot on, why are the helper springs on the top of the main spring instead of underneath it?
Tender progressive springs...... They make a serious difference to how nice the car drives and handles especially if u use it on the road too.
Team Running Engine again!
Team Negative Camber!
Posted 12th Feb 2012 at 19:57
306 Rxs
The gearbox was not forgotten...
A new LSD was installed, more precisely a clutch plate type...done by a portuguese company specalized in these kind of components.
http://www.rmc.com.pt/
I´ve decided to use the the s16 housing and final drive, wich is the shortest from psa range for BE gearboxes.
All the gears, from 1st to 5th are from a gti6 box...and this is the best setup for getting a close gear ratio, using original parts. The assembly was not a direct fit, because it needs some mods on the original
The chosen gear ratios for 7500rpm / 4,43 FD / 205-50-15 are:
1st - 2.92 - 68kmh
2nd - 1.85 - 107kmh - 5009rpm
3rd - 1.41 - 141kmh - 6008rpm
4th - 1.15 - 173kmh - 6457rpm
5th - 0.95 - 209kmh - 6544rpm
Remind you all that this is a track car, so there´s no need for a lot higher top speed.
What is a hybrid?
Posted 12th Feb 2012 at 20:05
306 Rxs
The suspension setup...
Selex Gold on tarmac setup
GAZ srings 350lbs x 20cm height
Tender springs 20lbs x 10cm height
Jeffers, that's right on target! Wink
What is a hybrid?
Posted 12th Feb 2012 at 20:17
midlife
So where exactly can I get my hands on those Wishbone uniball's??
Cool
Team 330™Cool
Team "no front end or engine"
Posted 12th Feb 2012 at 22:35
306 Rxs
You've got to steal them from me, because those in the photos are the first and unique pair that we've made!! lolol
What is a hybrid?
Posted 12th Feb 2012 at 22:39
atterz
The progressive springs are what Russian Guy uses on the rallye, i recommend checking his thread out if you get chance!
owain wrote:
Posted 12th Feb 2012 at 22:59
midlife
Ok then, on my way to Porto!!
They do look just like the answer to do away with the STD joints!
I'd love a set, if the price is right & they are made out of decent materialDunno
I can get titanium if you can make them out of thatNinja
Cool
Team 330™Cool
Posted 12th Feb 2012 at 23:35
clen666
Would you be willing to make some more up? I'm sure you could get a few people interested in a group buy
Team 'unintentional rat look'
Posted 12th Feb 2012 at 23:38
306 Rxs
Post #35
It´s not a very good price, because the balljoints need to be specific one's, so they can take with mud, dust and everything else...without rubber casing. Due to it's forms, there's no cover available.
Around here they cost around 90pounds each pair.
The price for the complete piece would certainly be around 110pounds or a bit more.
Remind that this isn't done with comercial purposes.
The material used for making the piece is steel just like the original one.
As soon as the s16 gets back on the road, i'll be able to do some parts...but till then, the few hours i have free, are lost in this project. Wink
What is a hybrid?
Posted 13th Feb 2012 at 00:18
midlife
Post #36
Price is not a problemSmile
If I got you some titanium would you be able to get them made
Out of that?
Cool
Team 330™Cool
Posted 13th Feb 2012 at 20:59
306 Rxs
Post #37
Yes, the gas for the laser cutter needs to be a different one, but it can made out of that.
The diet continues, and this time TB was the victim...LOL LOL
By rxs306 at 2012-02-14
Two more detail photos of one of my favourite parts... Yes
What is a hybrid?
Posted 14th Feb 2012 at 09:59
atterz
Post #38
How did you port the throttle body mate? And the seat rails look awesome!
Posted 14th Feb 2012 at 12:08
306 Rxs
Post #39
There was a small problem due to the original internal shape of the TB (not perfectly round), but the machining was possible anyway.
On the thicker part, it had to be welded some alloy, because it has a hollow part.
I don´t know if this happens on all gti6 tb's.
After the alloy welding, the TB was again machined until the aspect you find on the pics.
What is a hybrid?
Posted 14th Feb 2012 at 12:18
atterz
Post #40
Ahhh, should improve throttle response nicely!
Posted 14th Feb 2012 at 15:04
Post #41
Very good project and cracking car you have Thumbs up
Really like all the bespoke "M" bits Cool
Posted 14th Feb 2012 at 15:13
306 Rxs
Post #42
Thanks guys...
There´s some more work done...
The engine mount that usually cracks...
It was possible to get a lower weight by almost 400grs (1kg std/600'ish rigid one) LOL3 LOL3
Gearbox engine mount project...lol
Engineering moment St Peter's mode!! ;D ;D
Since the original gearbox mount is secured only by one stud, the target of the mount is the reinforcement of itself with the M14 std stud + M14 that the gearbox housing has just on the side of the first one + M8 stud that secures the clutch cable mount.
By rxs306 at 2012-02-19
The final product shoul be like this!
What is a hybrid?
Posted 21st Feb 2012 at 05:41
atterz
Post #43
Still looking awesome, let me know how much difference that throttle body makes! Interested in a ported one for mine, hopefuly to improve throttle response!
Posted 21st Feb 2012 at 23:02
JoeyD
Post #44
So much room in the engine bay with the battery moved! Could have a pretty neat induction setup there...
Posted 22nd Feb 2012 at 00:04
clen666
Post #45
Hmm the engine mounts look interesting.
Wondering whether to go for completely solid mounts like that, my top mount is completely cracked so would need to be repaired anyway.
How much more vibration would you get from that as opposed to uprated rubber mounts?
Posted 22nd Feb 2012 at 00:13
306 Rxs
Post #46
Atterz, i will not be able to tell the difference exactly because the engine is not the same.
Joey D...my induction kit is already very good...in my opinion of course.
Please check the post 13 on this topic. Wink
Clen...when idling, the vibration is very much noticed, but the response to the throtle and gear change is outstanding.
What is a hybrid?
Posted 22nd Feb 2012 at 00:56
306 Rxs
Post #47
Gearbox mount in the making...
Cambelt side mount already on it's place...
What is a hybrid?
Posted 22nd Feb 2012 at 01:23
woody.
Post #48
Wow, some seriously nice shiny bits there, top work!
Posted 22nd Feb 2012 at 02:22
306 Rxs
Post #49
Thanks woody...i always try to do my best!!
New bits...just covered my dashboard with a a proper rally tissue!
It will only be missing the central console alloy plate, but at least the mold has already been done too.
By rxs306 at 2012-02-23
What is a hybrid?
Posted 24th Feb 2012 at 04:39
davewagon
Post #50
Awesome thread this!!
Subscribed!!
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 24th Feb 2012 at 07:11
