displaying posts 51 to 75 of 168
Pages (7): first .. 2 [3] 4 .. last
Author Subject: 306 (k20 inside)
Post #51
Dash looks spot on!
What is this rally tissue you speak of? I am in the process of removing my dash and was thinking of getting it flocked, but cheapest quote I have had is £100 Unsure
Posted 24th Feb 2012 at 08:43
Post #52
Great build thread!
Couple of things:
1. Reinforce the top engine mount on the shell as it will crack with a solid mount - they are bad enough with normal ones.
2. Be careful with the amount of float in the driveshafts increasing the camber that way - they are likely to pop out on full lock. If you speak to CRF450 (martin) on here he machines the hubs to give greater camber that way. He also does loads of stuff on the rear suspension to give more camber etc etc.
3. Have a look at seam welding the front subframe.
Posted 24th Feb 2012 at 09:56
306 Rxs
Post #53
Thanks guys... Wink
Cjm...the jobs are made by me, but the final price for a complete dash is not so cheap!
A 106 complete dash is around 85 pounds, but if i went to a upholterer to do the job, it would double the price. I spent almost 5 hours in the making of it!
This tissue gives almost the famous rubber touch, and it's really dark. In the pictures, i can't capture the real colour of it. I will try and take better ones with a proper camera.
This is what many race cars use instead of flocking. It gives better touch and can be easily cleaned, but is harder to apply than flock.
Adam, thanks in advance for the advice Wink
1- I'm already using a thicker stud on this mount, but the car has already done 4k miles with another rigid setup, always on track and hill roads, and the shell is still nice. It easier to crack it in UK due the rust!! lol
My problem is the amount of power that it will have to cope with now, because it passes from a s16 almost stock engine for a gti6 with more than 200hp...let's hope it can do the job. lol
2- The driveshafts that i'm going to use are from a 406, because they are just about 3cm longer than the 306 one's, giving me the extra length that i need.
3- The subframe has already been seam welded.
What is a hybrid?
Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering...
Posted 24th Feb 2012 at 10:40
playboyb
Post #54
Looking awesome, great thread and track pictures are looking sweet mate. Keep up the good work! Big grin
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 25th Feb 2012 at 09:01
Post #55
No rust and they still do it!
Posted 25th Feb 2012 at 09:31
Post #56
PH3's don't exist for this engine, PH2's fit just about in stock head, PH4's are race/rally cam Big grin
edit, Doh I only spotted the inlet manifold not the cam covers LOL
Posted 25th Feb 2012 at 10:35
eddy_gti6
Post #57
Very impressive build this Big grin You sure are putting the work in. Wish I had the skills to make some of this stiff Laugh my ass off Looking forwad to seeing the finished project Thumbs up
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 25th Feb 2012 at 18:46
306 Rxs
Post #58
Welshpug, this ph3 are made only by special order. They´re not available on the Newman catalogue.
They still use hydraulics, but on the edge of their limit.
The car is now using the xu10j4rs, not the original one j4 from the first pictures.
The inlet and TB were from a gti6 from the beginning!
Adam, as i said, the car has already been using a rigid setup for a while now, and there's no marks of damage on the mount base. Wink
Thanks Eddy Wink
The phase will get to an end in the next 15 days...the work is almost finished.
What is a hybrid?
Posted 26th Feb 2012 at 00:52
306 Rxs
Post #59
Developments for tonight
Wheel and the rest of the acessories mounted...
Top struts reinforced by welding 3mm plates, already with adjustable top mounts.
Single wiper from a ZX...
Weight saving on little details...LOL
First impressions with the wheels on, without spacers...
Some wide arches might be needed... LOLLOL
By rxs306 at 2012-02-28
What is a hybrid?
Posted 29th Feb 2012 at 01:29
eddy_gti6
Post #60
the zx wiper is that standard or does it need to be modified?
Posted 29th Feb 2012 at 03:07
306 Rxs
Post #61
The wiper and motor are standard, but the mounts had to be modified.
On your offside mount, it just needs to be drilled a 4mm hole beneath the original one.
The drivers side mount needs to be welded to the car.
What is a hybrid?
Posted 29th Feb 2012 at 09:03
tom275
Post #62
Hardly a Rallye wanabee! Looks awesome
Posted 29th Feb 2012 at 09:23
306 Rxs
Post #63
Thanks... Wink
I'm gonna make one of the first Ph1 rallye ever seen...Big grin Big grin
The badges are already here, but i will only put them when the car is finished.
What is a hybrid?
Posted 29th Feb 2012 at 09:41
ADP
Post #64
Phase 1 rallye????? Your not doing it properly, should have bought a genuine rallye Wink
Posted 29th Feb 2012 at 11:03
306 Rxs
Post #65
I'm not doing it wrong, i'm doing it different...but better!!
You are putting a nonsense rollcage instead of a decent one...that's what's wrong!!
Do not try to mess around with me, when you make mistakes like that...you're just digging a bigger hole for yourself.
What is a hybrid?
Posted 29th Feb 2012 at 11:58
ADP
Post #66
Ha! I understand ur comment on the cage, but putting rallye Decals on a phase 1 gti6........ Says it all really. Lol Smile
Posted 29th Feb 2012 at 13:33
306 Rxs
Post #67
This is not a ph1 gti6!!
A 306 rallye is just a gti6 without leather seats, electric windows and radio... Wink
If you'd understand my coment on the cage, i don´t know what's happening with your posts in my topic!!
Just go around the block and see if i'm there...ok!!??
What is a hybrid?
Posted 29th Feb 2012 at 14:15
ADP
Post #68
Sorry my mistake, putting rallye decals on a phase 1 s16......that's even worse! I didn't ask u to comment on my cage so don't write on my posts, and if u do atleast try and make them make sense!
Posted 29th Feb 2012 at 15:03
clen666
Post #69
Now now, let's calm things down and get more pics of the progress
Team 'unintentional rat look'
Posted 29th Feb 2012 at 17:11
midlife
Post #70
x2 No No
Cool
Team 330™Cool
Team "no front end or engine"
Posted 1st Mar 2012 at 04:49
306 Rxs
Post #71
Always in a good mood...but this kind of wise guys just have to know the right ways.
If the critic was correct in his topic, i don't know what's the problem with him...even criticizing something that isn't done!!
Going on...the s16 is back on 4 wheels again!!
The suspension is mounted, but there will be a change in the lenght of the spindle, because it has just too much!
What is a hybrid?
Posted 1st Mar 2012 at 12:44
atterz
Post #72
Looking awesome as always! You also have Pm mate, never heard back from you! Smile
owain wrote:
Posted 3rd Mar 2012 at 20:05
306 Rxs
Post #73
I've just answered you... Wink
Some teaser shots from today's work
Camber...yeahh!!!
By rxs306 at 2012-03-03
Last week, during a td preparation on some other friend's cars in my house!!
What is a hybrid?
Posted 3rd Mar 2012 at 21:11
eddy_gti6
Post #74
Love them old BM's Big grin
Posted 4th Mar 2012 at 12:44
306 Rxs
Post #75
That's a mint 320is model...2.0cc 4cyl 192hp...the engine is just an M3 with less power and some cc! lolol
It has only been sold in Portugal and Italy due to taxes apllied on the cc of the engines!
We were mounting some braided hoses on it...
What is a hybrid?
Posted 4th Mar 2012 at 13:37
