Author Subject: £750 supercharger fitting kit
i have a full used lynx power engineering supercharger fitting kit for the rotrex c30-94.
the kit has covered less than 1000 miles, not shown in the pics are the p/s reloaction bracket, air scoop and p/s pipework and connections eg, this is because i will supply brand new ones of these from richw along with a new belt. included is the compressor housing which has the boost pipework allready connected in 63mm pipe and has the throttle body housing pre welded to it, this has taken a lot of time and effort in order to get it right to clear everything in the way, p/s pump, oil filter, rad-heat excahnger pipe eg and is a
perfect fit that takes a lot to get right. however if you dont want this bit for whatever reason then let me know and i can arrange another.
I can also supply the injectors and a unlocked ecu with the updated low boost software in ready to go but these arnt included at this price and will be extra but if you buy all 3 items from me, all you need then is the supercharger, a intercooler and pipeworkand your ready to get it all fitted.
thanks for looking, you can also get me on:
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 29th Dec 2011 at 00:18
Willing to sell the bit of charger and pipework welded to it seperate?
If so, very interested Big grin
Posted 29th Dec 2011 at 08:36
hi, I think id rather keep it in the kit as it holds the throttle body and restrictor mounts, if somebody wants these supplying not welded to the charger housing when they buy the kit then I will happily sell it but I'd have to source replacements to go in the kit which will cost me so it's a none winner for me mate.
Posted 29th Dec 2011 at 09:18
How about a swap for my bits and a bit of cash your way?
Smile
Posted 29th Dec 2011 at 09:23
That manifold, it's too tall for 205 clearence isn't it?
  • Posted 29th Dec 2011 at 09:42
    Cjm that sounds good, let me consider it for a while mate.
    Dan I think I also read the same and that a shorter manifold is used on the 205, are you feeling the charger bug??
    Posted 29th Dec 2011 at 09:44
    I can do the whole package including low boost injectors and low boost ecu for £950
    Posted 30th Dec 2011 at 10:54
    ash
    Six Addict
    What's happened to the rest of the charger?
    Posted 30th Dec 2011 at 11:04
    sold with a brand new compressor housing on.
    Posted 30th Dec 2011 at 11:07
    they basically got a brand new charger but cheaper, it had covered around 750 miles, no more than 1000 at the max.
    Posted 30th Dec 2011 at 11:08
    Yeah, can't remember where I saw it though. I haven't seen one in person to see how much higher it sits than standard.
    Not so much the charger bug, half decent power bug LOL you always want more.
    I was considering bodies really, but this package is better value, especially for the power over that route
  • Posted 30th Dec 2011 at 11:18
    sold
    Posted 30th Dec 2011 at 12:58
