displaying posts 451 to 475 of 488
Pages (20): first .. 18 [19] 20
Author Subject: GETTING THERE Fatlapits turbo (turbo frog)
Post #451
fatlapit wrote:
Day666 wrote:
You won't beat Dunlop DZ03G Direzza I believe Thumbs up
I personally wouldn't want to use the Kumhos for continued track laps ...well not the Supersofts anyway LOL
They dont make them in my size. I know hill climbers that have moved away from the dunlops to the khumo.
I understand why Thumbs up ......you can't get enough heat into DZ03Gs & they don't make soft compound anymore ...Kumho Supersofts grip from the start ....
I can't get Slicks in equiv size max 205/50/16s
Posted 13th Jan 2016 at 22:22
99rallye
Post #452
Have you got a link for the bonnet too?
Posted 13th Jan 2016 at 22:26
fatlapit
Post #453
https://m.facebook.com/tuningdrift69/
Pm robert
Posted 13th Jan 2016 at 22:39
marco gti6
Post #454
Chris can you tell us about the PTFE cam cover gaskets you are running on your engine and if they work well? Didi you end up using longer bolts?
Cheers mate
Posted 25th Jan 2016 at 09:59
fatlapit
Post #455
301842949034 search on ebay
No modification needed to the bolts
Either grind down the shoulders on the cam covers or cut off the biths the bolts go though on the gasket
He also does the tb gasket and inlet gadket
Posted 25th Jan 2016 at 14:02
eddy_gti6
Post #456
how thick is the inlet gasket Chris? been looking at one for the van
Posted 25th Jan 2016 at 14:06
Post #457
Ask Mei about the Inlet gaskets ?...think Sandy said not to use them for some reason ?
Just spoken to Sandy who said he's personally found they lose there shape over time & then you get air leaks & maps out ?
Posted 25th Jan 2016 at 16:43
fatlapit
Post #458
f**k knows lol
Posted 25th Jan 2016 at 14:09
eddy_gti6
Post #459
why not? Surely there better than paper gaskets and there proven to lower inlet temps
Posted 25th Jan 2016 at 14:21
demondriverdan
Post #460
I've got one on my new engine, seems ok?
Rallye Race Car
Posted 25th Jan 2016 at 14:32
fatlapit
Post #461
Nowt wrong with them. Ask sandy yourself. Better than paper ones.
Posted 25th Jan 2016 at 15:15
fatlapit
Post #462
Alot of people i know run ptfe gaskets
Posted 25th Jan 2016 at 15:17
craig903
Post #463
I use the ptfe inlet one perfect fit and nice quality, I cut the tabs off on the gasket for the cam covers
208 GTI Owner
Posted 25th Jan 2016 at 16:12
fatlapit
Post #464
As craig said
Posted 25th Jan 2016 at 16:24
fatlapit
Post #465
So what a crazy year. 3 gearboxes. A clutch and a diff rebuild. Canny expensive roughly 5k for this year. This year my fave tracks have got to be a toss up between knockhill and cadwell.
Some of you may have seen that it was up up for sale. There is a pothemtial buyer. And they are on this forum i dont know if they are a current member or not.
Saying that hopefully i will have enough money by xmas to but n trial out the spoox gearbox.
If the buyer does not complete the sale i will be out next year playing.
Any questions just ask. I know there is alot b**chyness on fb. But just ask me n ill answer best i can
Cheers Chris
Posted 17th Oct 2016 at 22:40
Post #466
negligible difference and whatever difference is soon negated by air leaks.
Posted 17th Oct 2016 at 22:59
fatlapit
Post #467
Never seen one with an air leak. Well not using a thermatec gasket any way
Posted 17th Oct 2016 at 23:00
td_dan
Post #468
great project mate but just wandering where did you take the oil feed from for the turbo and also did you just have a drain welded into the sump
Posted 10th Jan 2017 at 19:21
craig903
Post #469
You get the feed using an adaptor which sits between the block and the oil pressure switch, there's a m14? I think hole in the back of the block which goes direct to the sump. Take the plug out and that's your drain
208 GTI Owner
Posted 10th Jan 2017 at 19:32
fatlapit
Post #470
Craigs got it in 1. I took the feed from behind the starter. And there is a plug in the back of the block
Posted 10th Jan 2017 at 19:59
pug_306
Post #471
Are you running the new gearbox yet buddy ?
1992 205 GTi6
205 Turbo 340bhp
Posted 10th Jan 2017 at 20:02
td_dan
Post #472
Ok thanks both of you
Posted 10th Jan 2017 at 20:09
fatlapit
Post #473
Yep new box and diff. Just fitted epas to cope with the diff
Posted 10th Jan 2017 at 20:24
Post #474
You shouldn't be getting air leaks from creep unless someones been using sealant either side (lets them move), or had them made out of cheap non-virgin PTFE (I tried it once on my TU, like using Plasticine..) without fillers.
Posted 10th Jan 2017 at 22:41
Post #475
nope, no sealant.
Posted 10th Jan 2017 at 22:51
