displaying posts 1 to 25 of 488
Pages (20): [1] 2 3 .. last
Author Subject: GETTING THERE Fatlapits turbo (turbo frog)
fatlapit
started a turbo conversion will give updates bit by bit.
Spec:
Battery relocated to boot area
500 cc injectors in billet fuel rail,
Swirl pot, Fse fuel pump and fuel pressure regulator -6/-8 braided lines with black fittings,
wossner 86.5 mm pistons and PEC rods,
Rebuilt bottom end,
Bit of head work,
Head stud kit,
T2871 turbo with 2.5" bost pipes (making a hard pipe kit with minimal hoses), 3" air filter with custom airbox, Turbosmart race port dump valve.
Self made exhaust manifold with 38mm pipe work, 3" to 2.5" downpipe keeping standard flanges
All ally work to be anodised gold, inlet polished, compressor housing anodised gold,
Adaptronic ecu and probably more but this is what am up to atm Smile
Standard engine bay
http://i364.photobucket.com/albums/oo83/fatlapit/TURBO%20FROG/standard.png
Two turbos the one on the right is the one i have a T2871
http://i364.photobucket.com/albums/oo83/fatlapit/TURBO%20FROG/turbo.png
Mock up
http://i364.photobucket.com/albums/oo83/fatlapit/TURBO%20FROG/MOCK1.png
More pics to come if i get time off from the wife n dog Smile
My old 205 turbo
http://i364.photobucket.com/albums/oo83/fatlapit/chris060.jpg
ALSO HOW DO YOU DO A CLICKY???
Posted 22nd Dec 2011 at 18:18
fatlapit
Also in the process of making solid p-bushes, have made solidish bottom mount and made top engine mount and made the resonator bung too however mine is welded in but was bolted first, not sure how to go with the gearbox mount but i will get pics of these too. (lathes are really handy tools Smile )
Posted 22nd Dec 2011 at 18:29
BrianM
put this at the start of your image link: so you'll have this: for example!
From what i can see it looks nice but those images are quite small.
'13 208 Gti Bianca White, '99 Bianca 306 Rallye, '92 309 Goodwood GTi 5dr, '92 Miami Blue 309 GTi 3dr.
Posted 22nd Dec 2011 at 19:28
fatlapit
Cheers i tried a few times but i couldnt get it to work
Posted 22nd Dec 2011 at 19:53
Standard engine bay
Mock up
My old 205 turbo
Posted 22nd Dec 2011 at 20:43
fatlapit
Cheers dude
Posted 22nd Dec 2011 at 21:27
fatlapit
Did a bit more today
Posted 27th Dec 2011 at 16:19
fatlapit
and did some stripping
got the ex manifold off too what a tw*t that was lol
Posted 27th Dec 2011 at 16:22
rallyeash
no worky mate. copy the img code from the box under the uploaded picture on photobucket
309 3dr K20 Type R
fatlapit
The way this is going its alot easier than i anticipated i may offer my services to do other conversions, bearing in ming you would need the same spec as mine as the map could just be uploaded to your ecu and go for "tweaks" instead of a full map.
Posted 27th Dec 2011 at 16:30
fatlapit
Some pics
Posted 24th Jan 2012 at 21:22
fatlapit
and vids witht the bottom mount disconected to show clearence
Posted 24th Jan 2012 at 21:25
binkagti
You will have probs with air filter there, the intercooler pipe wor going to the manifold will folw on it and will not be a straight run so to speak, been there done it mate good luck
TEAM Supercharged Rallye
Posted 24th Jan 2012 at 22:37
fatlapit
the throttle body might be moving mate but the filter wasnt on properly and was drooping also the abs may be moving to give me room to move the filter over and make an air box for it with a bonnet vent.
Posted 24th Jan 2012 at 22:46
ADP
Looking good mate! Keep updating this thread!!!
Posted 26th Jan 2012 at 22:17
fatlapit
few more pics
at skunk works Smile
cambelt end
servo pump end
in the car
there is alot more room than i thought in between the engine and bulkhead which is a good thing. Toying to go with a v band turbine housing and a tial external waste gate but i think i will aim just to get it running then "play" around with the set up. As you can see it uses the stock collector too Smile
When it is all done i will get pics up of it finished and with the downpipe with ceramic coating if i can save a bit more cash Smile. The whole system is made to use a stock exhaust.
Posted 20th Feb 2012 at 19:34
sosmotorsport
why you going to all that bother and then suffocating the engine with a stock exhaust system ?
looking good tho :-)
SOS Motorsport
www.sosmotorsport.co.uk
450bhp 205 16v Turbo
www.facebook.com/pages/SOS-Motorsport/159917677353556
Posted 20th Feb 2012 at 20:51
fatlapit
Sorry stock fitting lol
2.5" should be good for 300 tho
Posted 20th Feb 2012 at 21:44
sosmotorsport
lol thats better hahaha
go 3" tho Thumbs up
SOS Motorsport
Posted 20th Feb 2012 at 21:47
fatlapit
go 3" tho Thumbs up
Noise??????Dunno
will the 2.5 not flow enough???
talking to traders at the autosport show it should.
Posted 20th Feb 2012 at 21:49
sosmotorsport
go 3" tho Thumbs up
Noise??????Dunno
noise will be ok with correct boxes
why coz any restrictions Dunno
at 300bhp i would be looking for a 3" exhaust system Yes
SOS Motorsport
Posted 20th Feb 2012 at 21:55
fatlapit
cheers for the advice mate Smile
Posted 20th Feb 2012 at 21:57
Coming on nicelyCool
Bin the ABS alltogether and just run the pipes direct from MCThumbs up
Thats what I will be doing if I do a engine bay resto on my RallyeYes
Posted 20th Feb 2012 at 22:05
fatlapit
i thinlk i`m gonna move it but not sure because tbh i feel it cuts in too early!!
Posted 20th Feb 2012 at 22:09
I know alot of people with Cosworths with big AP etc brakes have the ABS on a switch for track use,because as you say it kicks in too earlyThumbs up
Posted 20th Feb 2012 at 22:42
