| Author | Subject: GETTING THERE Fatlapits turbo (turbo frog) |
fatlapit
Location: STOCKSFIELD Registered: 02 Nov 2010 Posts: 3,040 Status: Offline |
f*ck it al chuck it lol________________________________________ |
fatlapit
did a bit more today manifold should be finished tomorrow ![]() ![]() ![]() turbo needs a bit reangling ![]() how it sits in the engine bay ![]() ![]() ![]() ![]() ![]() ![]() Other thing that are happening atm, dash out to remove a/c and change the matrix, also in two minds whether to flock it and also need to make a feature of the ecu which is gonna sit where the pass. airbag used to be. ________________________________________ |
fatlapit
new intercooler![]() ________________________________________ |
swiftyboi006
Nice start to what could be a beast of a car. I think it was binka who is/was the turbo man to talk to if you need any advice ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
fatlapit
cheers mate for that ![]() ________________________________________ |
JWP EFi
hmmm, evening welding courses on the cards!!!selling my 405 T16 manifold to help towards a DP setup |
fatlapit
Just tacs it shud be getting welded up this w/e and making the down pipe. also making a metal thermostat housing. will get pics of the bottom mount. mate i have saved £800 making it myself. ________________________________________ |
JWP EFi
be interesting to see how it works out! fancy making another one lol |
fatlapit
Could do mate if the price is right ![]() ________________________________________ |
fatlapit
Post #35
intercooler mock upin the hole ![]() bumper on ![]() loads of room ![]() plans for the oil cooler is to put it where the horns sit or try and fit it inbetween the rad and cooler. ________________________________________ |
playboyb
Seasoned Pro Location: Maidstone Son! Registered: 27 Jun 2011 Posts: 1,464 Status: Offline |
Post #36
Can't wait to see how this turns out, will be keeping an eye on this one! Good progress pal! ________________________________________ 306 1.8 xs moonstone blue-SOLD306 gti6 supercharged china blue-SOLD 406 coupe D9 3.0 V6-SOLD |
fatlapit
Post #37
did a bit more today, just got in fact!!manifold is near completion ![]() ![]() ![]() ![]() also thought i would bin that horrible piece of plastic that feeds the thermostat heres what i started with ![]() couple of hours later ![]() finished ![]() sorry but forgot to get a pic of the bottom mount, also didn`t have time to start the downpipe as i had to help a mate out on his maxi 5 turbo rebuilding two starter motors and wiring in some omex (the gucci bits). Also had to give the servo pump some space so did that too, as you can see not all the manifold is new, this is because the old manifold i used (gti6) had all the right components i needed, also they were in good condition, i only had to buy 6 90 degree 38 mm bends to make it. all the pipes are withtin 10mm in length of each other too, (so it wont soumd like a bloody sh*tbox subaru the downpipe is only going to be 2.5" for a couple of reasons a: because the bore is sufficient and b: a 2.5" pipe is easier to fit in the hole. after the downpipe is made its going for ceramic coating, not sure on the colour yet though. Well night night puggers am fooked so am going for a kip xxx FATLAPIT ________________________________________ |
clen666
Post #38
Good progress, this is turning into a nice project.Would you be willing to knock up another one of those thermostat adaptors? ![]() ________________________________________ Team 'unintentional rat look' |
fatlapit
Post #39
clen666 wrote: Good progress, this is turning into a nice project. Would you be willing to knock up another one of those thermostat adaptors? ![]() yeah not a problem, can only really do it when my car is done because i need every bit of time to try and get my car done for fcs, if i have a spare couple of hours i will do one and pm you pal. ________________________________________ |
clen666
Post #40
That would be great, cheers mate What size is the outlet? ________________________________________ Team 'unintentional rat look' |
fatlapit
Post #41
clen666 wrote: That would be great, cheers mate What size is the outlet? its 50mm atm but i`m gonna machine a fitting to use the standard pipe without the horrible clip assembly. dont suppose you know what diameter the standard pipe is??? ________________________________________ |
clen666
Post #42
I'm not 100% but 38mm rings a bell________________________________________ Team 'unintentional rat look' |
Post #43
You need a 3" downpipe on a volvo to get 300+ bhp. 2.5" isn't big enough and makes it all run too hot.________________________________________ Nothing to see here |
fatlapit
Post #44
Cheers for the comments but i will see what happens with the 2.5 system. also this aint my first turbo build.________________________________________ |
7057sam
Seasoned Pro Location: Stowmarket,Suffolk Registered: 18 Apr 2009 Posts: 2,080 Status: Offline |
Post #45
amazing work,how much has the project cost you already ?________________________________________ Rallye build: 11 November 1998 - a WednesdayTeam rallye,built for track ----Click this if you like rallyes Rallye dead Secret Team Astor... |
fatlapit
Post #46
For an engine, with manis, plus metal for all the work. £300 all in. not bad when i have both manifolds a downpipe a bottom mount and a thermostat housing and a intercooler too. ________________________________________ |
fatlapit
Post #47
just a quick snap before she goes to bed![]() couple of jobs to do, pull the turbo away from the body and pill the compressor towards the engine so its parrallel. also remove the power steering cooler and fit a little oil cooler behind the r/h fog light for it. make mounts for the intercooler too. ________________________________________ |
306 Rxs
Regular Location: Gondomar Registered: 01 Jan 1970 Posts: 184 Status: Offline |
Post #48
I was just thinking on doing the same to thermostat entry. Very well done mate. ![]() One doubt...how are you going to weld in the center of the 4 branch?? ________________________________________ What is a hybrid?Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering... |
fatlapit
Post #49
on the collector?? weld from the inside and then you can make a nice cone shape to promote good air flow ![]() ________________________________________ |
306 Rxs
Post #50
Thank you... ![]() I wonder how i didn't catch that sooner!! ________________________________________ What is a hybrid?Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering... |
