displaying posts 1 to 25 of 38
Author Subject: Peugeot 309, pic heavy
Jonnybravo
New to the website, I'm helping a friend out with his GTI-6 track car which we will both hopefully use a bit whilst we finish our other projects, one being my 309 and the other being a Mk4 Astra with a 500hp engine.
Anyway Ive already had a few members ask me to post up a thread of mine so here goes
The car was originally built in 1992 and raced in the 1993 Thundersaloon series, it was built by SHP, Sonny Howard who is famous for building the oval circuit cars and similar tube chassis stuff. The race series rules were literally changed overnight and many cars, inc mine were not eligible for the new season ( thats how I understand it anyway ! )
Due to the car being a expensive ornament it was split down and sold on as a rolling chassis with some of the parts remaining with the shell. It was purchased by a guy in south London who then built it back up and has used it for the last 15 years as a track toy. The car came up for sale last year, after a few sleepless nights trying to convince myself to sell my current project at the time I made the call and a deal was done Smile
I didn't buy it with the intention to pull it to pieces but although mechanically the car had recently had fortunes spent on it the body wanted some loving and thats where my mate who owns the 306 jumped in, I'll post a spec below, the car is currently a bare shell and should be off to the paint shop in the middle of november Smile
Some piccys of how it all started:
and then the strip down :
At this point I decided it needed more than a wire brush on a grinder so I dropped it off to have the front end and parts of the interior blasted :
So it was this point where Ash stepped in. I had planned to just paint the bay and interior but the roof had been jumped on at some point its life and other parts were really started to show that they needed attention :
Once the panels were nigh on perfect some of the rotten areas that turned into see through areas after blasting were addressed, front triangulation needed to be removed and remade as the bulkhead in that area had virtually dissapeared
There were a few other bits sorted but nothing I have pictures of at the minute.
Next up was to strip every remaining part off the shell, it didn't need to be rolling so all the rear suspension and axle was removed and then the car was placed in the air so we could look at how to deal with the floorpans.
Narrow tyres :
With the car now placed in the air courtesy of a LOT of pallets I decided to strip all the underseal off them, typically after literally spending hours doing that we then just cut them out, DOH ! however it was probably for the best as there was a bit more rust lurking under the panels, typically any rust so far has only been on what was originally 309 LOL
Its now currently a Flintstones spec shell, no pics again but I'm sure you can picture it with the 2 floorpans missing !
The chassis will now have some bracing added which will also act as the mounting points for the seats ( it only ever ran one seat being a race car ) I'm having some weld in slugs made which will be welded into the 1" box to fix the sidemounts too. We will then lay a 0.8 mm skin over the top of the chassis which will be a much nicer looking floor than we had before.
If you curious why this wasn't done originally that is because the rules specified the cars must run the original floors and bulkhead, once again thats how I understand it, it may well of been a certain % that had to remain on the car but I've seen a few other cars that also run the original floors.
I guess lastly would be the spec and purchases I've made for when it goes back together, as mentioned the car mechanically was good, the loom was a heap of shi* so I've had a friend make a new one, I've had several bits powder coated and tried to just buy things that the car needed rather than just throw endless amount of money at bits that worked perfectly well.
Raychem loom courtesy of Ryan @ Car Looms UK
Small race battery as it did have a huge car battery in the footwell !
New OMP wheel with some buttons to switch through the dash screens
Dash
All the new rose joints finally arrived, I just checked everything on a upright as it had been a while since I took it to bits !
Lastly the spec
Chassis :
309 D, semi tube chassis, large tubs, big diff, prop and gearbox tunnel, custom front end with double wishbone setup
GRP/Kevlar bodykit, arches, doors, bonnet, bootlid and both bumpers.
Engine :
Cosworth 200 block, Cosworth pistons, Roland Hayes cylinder head, Isky springs, BD14 camshafts, Kent pulleys, Custom sump pan, Pace dry sump pump, EEC4 plenum with 8 injectors, RS500 T4 turbo, lightweight flywheel, AP Twin plate clutch. Motec M48 advanced tuning
Transmission :
Glebe T5 5 speed dogbox, Gartrac propshaft. Semi floating Atlas axle, Quaife shafts, Tran X plate LSD, Diff cooler
Suspension :
Koni sport 2 way coilovers all round, bladed front ARB, 18mm rear ARB, Cosworth front uprights
Brakes :
Fronts, AP 4 pots, 330x36mm discs. Rears, AP 4 pots, 2wd Cosworth discs. Adjustable pedal box, braided lines throughout. Bias control
Wheels and tyres :
Fronts, 10.5 x 16", rears 12.5 x 16" magnesium minilites, Avon and Hoosier rubber.
I'll keep the thread updated as things progress. The car should be out and about for early next year with any luck, I don't plan to race it or use it every weekend but having thrown lots of money at cars in the past I really wanted to just buy something that could ( if I can drive it well enough lol ) do the business round a circuit.
Posted 27th Oct 2011 at 16:10
FAIR. That's a proper job, that is.
Posted 27th Oct 2011 at 16:31
matt evans
Recognise the user name from Passion ford.
Awesome project. Very very well done.
honestly3k wrote:
owain wrote:
Posted 27th Oct 2011 at 16:41
Jonnybravo
I think everyone is on Passionford LOL certainly seems that way !
Thanks though, I owe a few beers to mates for help with things so far, well I say that, I did have a working car until I was convinced into taking the engine out, its proved to be worthwhile though and I can't wait to see some paint on it !
Posted 27th Oct 2011 at 16:45
matt evans
There are quite a few of us on here from there, Me, Spiky, Coskev, ed van djik.
As with most of these projects, Mates are essential. Mine wouldnt be where its at without assistance form mates
Posted 27th Oct 2011 at 16:48
Jonnybravo
I know Steve ( Spiky ) We went out to Germany together, never got a chance to go out in the 205 as he seemed too attracted to the sheep.
Wasn't the best trip for me as it happens, infact not been back since and probably won't unless its a proper trackday !
Posted 27th Oct 2011 at 16:55
Truely awesome car, a credit to you Thumbs up
Look forward to the updates. Subscribed Big grin
Posted 27th Oct 2011 at 17:08
rallyeash
what a beast, look forward to following this thread.
309 3dr K20 Type R
Posted 27th Oct 2011 at 18:16
marksorrento205
Holly f*ck! Me want one LOL Good old Yb and a t5 box - match made in heaven. Passionford is a bob on site too Thumbs up
How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 27th Oct 2011 at 19:35
matty_rallye
Looks evil. Hoped there would be a thread on this car after you posted a pic of it the other day!!
2.1 16v 306 Rallye.
Posted 27th Oct 2011 at 19:51
marco gti6
That really looks like one mean mad machine Mate Thumbs up
Posted 27th Oct 2011 at 21:03
Jonnybravo
Thanks guys, its certainly a bit different Smile
Posted 27th Oct 2011 at 21:09
Hmm double wishbone front and a live axle out back LOL
Posted 27th Oct 2011 at 21:13
Jonnybravo
Everyone knows that live axle cars drive better Wink Steer it from the rear etc... saying that it doesn't have that much steering lock so its not one for drifting !
Posted 27th Oct 2011 at 21:21
I have such a stiffy over this Love
Posted 27th Oct 2011 at 21:49
ballardpaul
It's a stunner!!! Cool
Nissan 350Z (300 BHP)
Posted 27th Oct 2011 at 22:13
same here
Posted 27th Oct 2011 at 22:15
Jonnybravo
Erm Cheers ! lol
Posted 27th Oct 2011 at 22:28
7057sam
great job,is it staying yellow,What plans do you have for the engine?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 27th Oct 2011 at 23:32
BrianM
As a 309 enthusiast and have a few myself - I absolutely love this thing. I dribbled from my penis the first time I seen pictures of this car.
'13 208 Gti Bianca White, '99 Bianca 306 Rallye, '92 309 Goodwood GTi 5dr, '92 Miami Blue 309 GTi 3dr.
Posted 27th Oct 2011 at 23:47
Jonnybravo
The car is being painted all over in Ford frozen White, I had planned to paint the interior in a grey but just decided the White with black parts would look good enough.
Engine wise it's done 8 laps of brands since being rebuilt. Compared to the last engine this has higher compression, 8 injectors, new turbo and the dry sump setup, it's only been mapped to approx 440-450 @ 1.9 bar, more than enough really but it is a 500hp engine if I wanted it to be. The engine was built and mapped by HT Racing
Posted 28th Oct 2011 at 08:31
arigti6
... Now that is a Project if I ever saw one! Thumbs up Great read, I look forward to any updates + pics as mentioned Yes
Edit: Frozen White?! Hyper Oh baby!
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 28th Oct 2011 at 12:28
russbez
very nice! keep pics coming
My Rallye project thread
Posted 28th Oct 2011 at 12:50
clen666
AWESOME.
That is all.
Team 'unintentional rat look'
Posted 28th Oct 2011 at 13:04
simonjames
Awesome car mate hopefully your not repainting it nana though
MY EBAY ITEMS
07943066306
Posted 28th Oct 2011 at 13:09
