Im located in south London.
Angus
| Author | Subject: Red positive battery terminal cover and female threading |
lion king
Newbie Location: London Registered: 07 Jan 2011 Posts: 14 Status: Offline |
My battery linkage is having problems as the thread to the positive terminal is worn. Thus there is not a good connection to the battery. In addition the threaded connector on the battery is also not the best. Does anyone have both of these in good condition? Im located in south London. Angus |
poogiepug1
Seasoned Pro Location: Dover Registered: 24 Nov 2004 Posts: 1,666 Status: Offline |
Mine were the same, i just bought mine from Halfords, best to get new ones![]() ________________________________________ |
lion king
Im still having problems finding this. I went to Halfords and they did not have a clue what I was talking about. I have searched the forums and the part number I need is 5615.49. Any ideas on where I could find one. Anyone breaking one? |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
If u have the part number why do u not just go to pug and order one?? It can't be that expensive.... ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
£5.21 from Peugeot. Obviously Citroen sell the same if it's closer to you.________________________________________ ![]() |
I'd just chop it off and fit a normal clamp from a motorfactor.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
lion king
Thanks for your input.......I was having one of those..........I need to ask someone moments when I had the internet at my disposal. Im such a douche! |
ale624
Regular Location: bristol Registered: 02 May 2016 Posts: 180 Status: Offline |
Sorry to bump an old thread, but my battery is pretty shagged and I can't get the bloody ring off to swap it with the new spare in my other car that gets trickle charged with a solar panel. Anyone have any tips on how to get your old one off as pug have not made these for a while... |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
If possible tap it further down linish of the contact then remove Rotate on removal if you can ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
ale624
mocinim wrote: If possible tap it further down linish of the contact then remove Rotate on removal if you can Cheers, I'll give that a go tonight... had to actually jump my car this morning to get to work. interesting design isn't it. i quite like the screw on idea, just a PITA pug dont still make the rings... |
there's a good reason, they're crap!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
I can get them if required ???________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
RetroPug
Cut the end off the battery cable, put a new clamp on it, remove old battery with old clamp stuck to it, fit new battery, tighten new clamp onto new battery.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
mocinim
Now thats not rallye oem is it !IS IT ![]() ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
ale624
mocinim wrote: Now thats not rallye oem is it !IS IT ![]() ^ exactly! Decided to just say f**k it and drill the old battery post out as the thing couldn't even start the car, making it pretty useless haha Was a success, was stuck on there tight af though! Mocinim has managed to find some, so I'm getting a couple new ones. ![]() EDIT: god damn, giant images: http://imgur.com/a/PxorB |
that was f**ked anyway, so you probably ruined a decent battery just because the adapter is knackered and not making contact.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ale624
welshpug! wrote: that was f**ked anyway, so you probably ruined a decent battery just because the adapter is knackered and not making contact. i know haha, its working on my new battery now though, so its ok until i get a new one. charged the old battery on a battery charger and it seemed to charge to max pretty quickly so it was pretty dead :L |
or not dead at all...________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mocinim
Check the water level and plate wear________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
