displaying posts 1 to 25 of 105
Pages (5): [1] 2 3 .. last
Author Subject: High boost clutch
chris with a pug
I have now got my rods so the engine parts are all off to the engineers next month to be machined and balanced. So I need a clutch to so I can get it all balanced on the crank.
So what are the high boost people running?
Posted 11th Mar 2011 at 15:41
davedgti6
I am using a helix paddle with a sachs cover plate, at first I didn't like it as it was a bit either on or off, but have got used to it (maybe bedded in a bit too) and it's fine now, the standard clutch is supposed to be ok too and will only slip if you give it the full 400bhp treatment I hear Ninja
Posted 11th Mar 2011 at 17:36
chris with a pug
how much was ur clutch kit to get the coverplate?
I text rich and think I am going to go for thr helix. (dont them make pencils?) How many miles you done on it?
Posted 11th Mar 2011 at 19:57
davedgti6
I bought the paddle and cover off here second-hand, although it had done little mileage so don't know price, Lynx can get them for you though I suspect,
I have done between 2k and 3k on mine and although initially not liking it I think it's fine now, the only bugbear is that it can get a little annoying when you are in a traffic jam, but you just have to give it a bit more gas and be precise with your biting point, once on the go it's great,
I think I initially didn't like because of other factors too, my throttle cable was sticking because of the way I routed it and my lower Bbm mount caused too much vibration for my liking at idle and take off, I altered the throttle cable route, oiled it, and changed my bottom mount back to my powerflex one -controversial but my powerflex mount has been on for over four years when the car was standard, low boost and now high boost and it's been fine and still looks as good as when it was initially fitted Smile -this made the car much nicer and smoother to drive
Posted 12th Mar 2011 at 15:43
chrisd306
your looking about 6-650 quid for a helix paddle clutch, thats what im thinking of getting as mine was slipping on rollers doesnt seem bad on the road but suspect it will only get worse on the track, i was looking at other paddle clutches but think it will be the helix kit with uprated plaste and bearing coming in about 6-650 although will be bought through the garage meaning no vat so be cheaper!!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 13th Mar 2011 at 01:54
chris with a pug
Rich said he gets them for 200 quid, that might be a different one though.
Posted 13th Mar 2011 at 02:45
chris with a pug
does the 600 quid include the coverplate? I think Jim has this one in pauls race car, no good for the road as u cant slip it
Posted 13th Mar 2011 at 02:46
chrisd306
what do you mean slip it?
Its for the full kit.
might have to give rich a text see what he can do.
& Audi Q5 S Line
Posted 13th Mar 2011 at 03:59
chris with a pug
Basically the clutch is on or off. if ur sat in traffic it will get mullered pretty quickly
Posted 13th Mar 2011 at 04:00
chrisd306
get you, that would mean id kill a clutch taking mine on off ther transit!
& Audi Q5 S Line
Posted 13th Mar 2011 at 04:06
joker
davedgti6 wrote:
I am using a Helix paddle with a Sachs cover plate
Same here, I can't fault it on anything Thumbs up
Team 375 BHP Duratec™
Posted 13th Mar 2011 at 22:07
That's what I use, and again, can't fault it....Smile
Posted 13th Mar 2011 at 22:23
chris with a pug
Where can I buy a sach clutch from? GSF?
Posted 13th Mar 2011 at 23:46
miles
GSF or ECP I think,
Same here, Run a Organic one on my Dads car and a padal one on mine, Organic is OK for liught use but with abuse it can slip unlike the padel which is all or nothing
www.pugracing.com
Posted 14th Mar 2011 at 03:23
chrisd306
so what do you need to buy, just a paddle clutch or do you need to buy the lot bearing,clutch plate?
& Audi Q5 S Line
Posted 14th Mar 2011 at 04:19
devere
The helix paddle clutch kit comes with the release bearing already with the cover plate.
Posted 14th Mar 2011 at 22:23
birk
I had a friction plate made by CG Motorsport in leeds, its held up so far, but ive yet to drive it more that 1k and not realy driven it hard yet, will be back out to play in a couple of weeks Smile
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 14th Mar 2011 at 23:27
davedgti6
You just buy the Helix paddle and then buy the sach's cover plate separate, which comes with the release bearing attached -same as standard, only bit I'm not sure about is if you can just buy the cover plate on its own or if you have to buy the complete clutch kit
Posted 14th Mar 2011 at 23:52
chris with a pug
I think you have to buy the whole lot. I know Jims car has a helix cover plate on. I am sure him or paul can explain what its all about
Posted 14th Mar 2011 at 23:58
Best to give the fella at Helix a ring, he is very helpful by all accounts. I'm sure if you tell him what you want and what use you intend to put the car to, then he can recommend exactly what you need.
Posted 15th Mar 2011 at 00:06
miles
You can buy each part on it's own, Nice and easy
www.pugracing.com
Posted 15th Mar 2011 at 05:49
fatlapit
is it just a stock sachs cover?? with a helix paddle friction??? if so its only 240 all in
Posted 7th Mar 2012 at 18:50
birk
That's what I basically had on mine yes, took some abuse, but it's hard launching that will destroy the cover.
07889376885
Dan
Posted 7th Mar 2012 at 20:26
fatlapit
Wat u gonna run now?
Posted 7th Mar 2012 at 23:18
I have found no issue at all with the Helix friction plate and Sachs cover, still running it now with 320ft/lbs going through it. Yes
Posted 8th Mar 2012 at 10:49
