displaying posts 1 to 25 of 59
Pages (3): [1] 2 3
Author Subject: Rear suspension noises
cornish_pug
Hi all,
I've got a strange noise occuring at the rear end of the car when moving across uneven ground, to me it sounds like it's coming from directly under the boot floor pan, a creaking like noise. Also I can here I slight knock from there as I pull away or sometimes when I come to a stop. I can also hear it creaking noise from outside the car if I lift the rear end. If a heavy weight is plced in the boot like I bag of coal it seems to stop. Dry
Any ideas on curing this noise, much appreciated.
Team Diesel
Posted 6th Mar 2011 at 07:14
jord294
if you have no proof of the rear beam ever being refurbished, i would say it was about time you had it done Wink
Posted 6th Mar 2011 at 13:27
cornish_pug
I take it that's an expensive job?
Team Diesel
Posted 6th Mar 2011 at 15:07
binkagti
Oh yes lol, budget for around £400 to £500 and get your rear beam rebuild kit from miles from this forum.
Getting mine done at the moment.
TEAM Supercharged Rallye
Posted 6th Mar 2011 at 15:36
could just be front beam mountings knackered and the rear calipers sticking.
Posted 6th Mar 2011 at 16:17
cornish_pug
Saying that, my passenger side rear caliper doesn't seem to hold very well, & I only get the noise during or just after breaking, as i'm pulling away at a junction.
Team Diesel
Posted 6th Mar 2011 at 20:20
cornish_pug
Are these the bushes that could be making the knocking noise? Wink
cornish_pug has attached the following image:
Team Diesel
Posted 6th Mar 2011 at 22:39
smegal
Yes
Ex SC-6
Now in a Megane R26
Posted 6th Mar 2011 at 23:01
yup Smile I'd get the easy bits sorted then see if there's still creaking, if its gone then carry on and save up for a replacement beam, if its still there, cry LOL
Posted 6th Mar 2011 at 23:02
cornish_pug
Had a quick glance at the wheel arches, and the drivers side wheel seems to be sitting further back in the arch than the passenger side.
Could worn bushes cause this? Unsure
Team Diesel
Posted 8th Mar 2011 at 05:05
nope that would be bent stub axel or worn out bearings mate Sad
Posted 8th Mar 2011 at 13:46
footah212
the bushes you have pictured are the more expensive and harder to fit ones. I would try these first
Clicky.
Cheap and quick to fix. May not be the final solution but its where i wouls start.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 8th Mar 2011 at 15:22
cornish_pug
Clicky.
There's no picture with the link! Shock
Team Diesel
Posted 8th Mar 2011 at 17:44
those ones don't cause knocking, just a wayward rear end.
Posted 9th Mar 2011 at 01:16
mik
I have a knocking/clonking from the rear of the Rallye when going over bumps and rough road surfaces that sounds very much like the exhaust hitting the underside - except the exhaust does not have excessive movement and doesn't seem to be touching anywhere (mostly on the left where the exhaust is, but sometimes might be on the right). I thought it could be the spare wheel bracket, but I took the spare out and the noise is the same.
The car drives and handles very well, and there is nothing obviously wrong with the suspension (nothing seems to be loose), but I can't find the source of the noise. I've done a search on here, but nothing conclusive.
Any suggestions gratefully received. Ta.
Cherry Rallye SOLD
Posted 3rd Jun 2011 at 23:47
i had this for a while and it ended up being loose torsion bar :shock it was tight but loose in the splines. temp fix until you get a new arm ptfe tape Huh?
Posted 4th Jun 2011 at 02:15
I have the exact same thing , to the tee, nothing wrong with my handling either, I thought it was a shock for a while but now I'm fairly certain its the beam mounts, do me a favour if you find out what it is tell me? I even removed the wheel like you to test as well Razz
Posted 4th Jun 2011 at 15:31
mik
If there are two of us with this issue there must be more...
I was dealing with some surface rust underneath today and had another good look while I was under there - torsion bars don't seem to be loose either. Nothing obvious at all.
I might be able to get it up on a hoist in the next week or two - if so will have a good poke around and report back.
Cherry Rallye SOLD
Posted 5th Jun 2011 at 00:50
gtburrows
I had the same symptoms on mine once. Turned out to be one of the nuts holding the damper to the chassis was slightly loose. Only by about a quarter of a turn, but enough to allow for some movement. Might be worth a check.
Posted 6th Jun 2011 at 02:47
mik
Thanks, good suggestion will add these to the list of things to check on Wed afternoon when I will be able to get it on a hoist.
Cherry Rallye SOLD
Posted 12th Jun 2011 at 19:15
mik
Got the car checked out on the hoist today. There is no play in the rear beam, no loose wheels, bearings, mounts - nothing loose at all, everything is as it should be. The only source they thought could produce the noise is the front of the spare wheel carrier where it goes through the holes in the brackets. Perhaps the holes have rusted bigger or the carrier is bent or something. My tyre was very soft so I pumped it up to see if it allowed the wheel to move up and down in the spare wheel carrier - no difference at all.
There is definitely nothing loose that could cause a safety issue and as I said before the handling is spot on. The mechanics suggested I talk to a Peugeot garage or specialist as this issue must have occurred before due to the numbers on the road. I'll give Carl a call when I have a moment.
Spare wheel carrier is the only possible suspect at present.
Cherry Rallye SOLD
Posted 16th Jun 2011 at 02:20
Well that doesn't make me feel much better, I'm hoping it just goes when I fit solid mounts, having said that mine is occurring more often this month, next to a vibrating heatshield its doing my twat in
Posted 20th Jun 2011 at 06:08
Will make even more noise with solid mounts! Trust me Doh
Posted 20th Jun 2011 at 15:31
lewisdmz
fitted solid mounts at the weekend and it seems my noises are gone. I used to get a slight knock from the rear when crawling along in 1st gear under 10mph, if you just gently accelerate then lift off.
When i took the front mounts of there was quite a lot of play in them.
I was expecting there to be more noises/vibrations but it really doesn't seem to be any different at all...
Posted 20th Jun 2011 at 17:44
mik
After listening to the noise for another 1000 miles I think it must be the rear beam mounts, even though the handling feels fine. I will get them replaced when I can.
Cherry Rallye SOLD
Posted 8th Aug 2011 at 00:51
Pages (3): [1] 2 3
