displaying posts 26 to 50 of 59
Pages (3): 1 [2] 3
Author Subject: Rear suspension noises
its rare you'll find anything on a 2 post ramp even if the beam is totally f*cked, hell my 205 passed an MOT with no bearings left whatsoever!!!
Posted 8th Aug 2011 at 01:02
gti6neil
cornish_pug wrote:
Had a quick glance at the wheel arches, and the drivers side wheel seems to be sitting further back in the arch than the passenger side.
Could worn bushes cause this? Unsure
i had this problem on my 6 and it was due to the axle mounting being bent for some reason Crazy i have since fitted solid mounts and can report that every thing lines up perfect and the ride is noiser and more harsh LOL only person that cares is my daughter that sits in the back LOL
yeah the zx td is back on the road front mounted intercooler fitted fuel pump tweaks now required + turbo adjustment
Posted 8th Aug 2011 at 05:16
mik
I just went out and took the rubber grommets out on the boot floor and tightened up the 6 (14mm?) bolts under there. They were tight-ish but could be tightened up a bit more with some effort. Will test drive later to see whether an improvement has resulted.
Cherry Rallye SOLD
Posted 8th Aug 2011 at 17:53
mik
Nope, noise still there.
Cherry Rallye SOLD
Posted 8th Aug 2011 at 21:02
Mine is doing my absolute twat in now tbh. It gets worse from time to time.
Posted 9th Aug 2011 at 19:16
Wink
Posted 9th Aug 2011 at 20:02
jiffy
Oh dear, I'm planning to fit solid mounts myself. I've heard some people say they made no difference to the ride. Is it really noticeable?
Posted 9th Aug 2011 at 21:43
cornish_pug
I think i'm going to buy the bushes at some point. The car is on 122k now, can't be sure if they're the original bushes. Not bad for 122k if they are Cool
Team Diesel
Posted 5th Sep 2011 at 21:49
aaron6
I have the same issues. My one creak from pull away and also there seems to be rumbling/clicky noise at 5-10mph. I have solid mounts and a beam that had everything changed 25k ago. I know my rear shocks are f*cked so im having billy b6's fitted Wednesday. The mechanic is going to inspect the rear end to see what my creek is. Is it obvious to see if the noise is from the tb's or arb? Im hoping its just a sticky caliper or something as lots of cash has been spent on the back end. Sad
Posted 5th Sep 2011 at 22:57
mik
Post #35
Jeepers that is irritating getting noise _after_ spending a bunch of money on the rear end.
I called CG Cars, and one of the blokes there suggested in my case the clonk could be something to do with the ARB adrift or end-plates (13mm bolt) needing to be tightened up.
Cherry Rallye SOLD
Posted 5th Sep 2011 at 23:00
aaron6
Post #36
My problem is probly just something daft but its finding it. Still, at the very least my back wheel won't bounce anymore with the billys on. Hopefully my mechanic mate Will sort the old bird out for me. Il find out Wednesday so il post up his findings. Smile Good old 6's... All fun and games! LOL
Posted 5th Sep 2011 at 23:09
Post #37
unlikely to find much unless he pulls the trailing arm out...
Posted 6th Sep 2011 at 02:51
aaron6
Post #38
Oh... Sad
Posted 6th Sep 2011 at 06:15
aaron6
Post #39
Found the problem. The beam bearings have failed on the driver side after less than 25k. So... New beam for me then. Sad
Posted 8th Sep 2011 at 13:18
Post #40
what was done 25k ago? A bodge job probably...
Posted 8th Sep 2011 at 13:22
aaron6
Post #41
All bits were done. New pins (205 ones) New bearings and seals too. All pug bits too. So i getting a beam off of jord and chucking it on. Ill rebuild my old one and sell it on to recoup sons cash i reckon. Could it be the solid mounts have caused premature failure due to loss of dampening? If so ill save and get pug rubber ones.
Posted 8th Sep 2011 at 13:28
Post #42
Hmm
shouldnt need to do the whole beam if only one side has gone, has it been stripped down?
would imagine the seal clearances were not set properly if it failed in that time, its pretty critical as too tight and the seal will wear out and let water in, too slack and the water will get in.
Have taken apart 100k+ beams with pretty minimal wear, though most lowered ones even with less mileage have been donald ducked due to the seals as mentioned above.
Solid mounts wont affect it, big torsion bars will though.
Posted 8th Sep 2011 at 14:20
aaron6
Post #43
Not stripped down but got a load of camber. Ill check the beam out once its on the table in a week or so.
Posted 8th Sep 2011 at 15:11
Post #44
I had my mot today, interestingly as a advisory it says osf beam mount noisy
Posted 8th Sep 2011 at 19:12
aaron6
Post #45
Super. So you getting a beam done mate?
Posted 8th Sep 2011 at 19:46
walker_texasranger
Post #46
I was getting some serious knocking from the back end of my car, the beam looked ok i.e no camber and no squeeking, just knocking so I got the 4 mounts and had them swapped. The old ones were absolutely Fubar'd. The cars done 226k now and I reckon they were the original mounts Erm?
End result is that I now have a nice quiet beam and a car that doesn't sound like I have a sledge hammer jumping up and down in the boot, it handles so so so much better too! As it would really.....
If one of your wheels is showing a lot more camber than the other one then its beam rebuild time unfortunately.
Hilux InvincibleX daily
306 No.13 Doh
Posted 10th Sep 2011 at 12:09
mik
Post #47
walker_texasranger wrote:
...the beam looked ok i.e no camber and no squeaking, just knocking...
Yes, that is exactly what I have. Food for thought. Maybe beam mounts then.
Cherry Rallye SOLD
Posted 10th Sep 2011 at 13:25
walker_texasranger
Post #48
Got to be the first place to start, 4 mounts from GSF is a lot cheaper than a refurbished beam and if it is the beam you would be replacing the mounts anyway, logical course of action. Roll the car slowly forward and stick the handbrake on, if you hear a clunk, its the mounts Yes
306 No.13 Doh
Posted 11th Sep 2011 at 02:49
Post #49
This has made my mind up, my mounts are f*cked
Posted 11th Sep 2011 at 08:43
aaron6
Post #50
Well it is the cheaper issue. Smile Got my new beam but have to wait a week before my trusted garage can fit it. Sad But the road trip to get it yesterday was fun. 512miles covered yesterday. Cheers pete26 for the company and cheers Jord for beam. Smile Looking forward to trying the rubber mounts instead of my solid ones. Smile
Posted 11th Sep 2011 at 09:36
Pages (3): 1 [2] 3
