displaying posts 376 to 400 of 884
Pages (36): first .. 15 [16] 17 .. last
Author Subject: Goldie the track car
clen666
Post #376
prism7guy wrote:
I'd been putting the beam off for ages, hoping to go down a different route but that's been delayed for a while so i decided to tackle it, it really wasnt as hard as i was expecting. Smile
Think this it's the same reason I need to do my beam! LOL
Team 'unintentional rat look'
Posted 4th Feb 2013 at 18:27
daver6
Post #377
I have mine in bits at work, the bearings are in and the tube is painted....
But then I look at the arms and think I should renew the wheel bearings and blast them, you know, do a proper job?
I'm betting I just press the new shafts in and reassemble Thumbs up
Wishbone Polybushes available
Posted 4th Feb 2013 at 21:27
Post #378
I was considering new bearings, but decided that all being well i'll be upgrading again within a year, so theres no point throwing even more money at something when the old bearings are still working fine and i'm only going to lose more money. LOL
Posted 5th Feb 2013 at 07:02
Post #379
Suppose i'd best do a little update on this.
I've had some AP 4-pots lying round for months which i've been intending to fit for a while, after the last trackday last year when i used the last of my pad material i decided it was one of this winters projects to properly sort the brakes out.
I've looked over other big brake threads in the past and always get put off by usually having to go to bigger wheels, i'm a tight northerner so having to buy other sets of wheels and more expensive tyres didnt appeal to me. Laugh
Fortunately a few others have squeezed decent size discs under 15's, which inspired me to have a crack at it. Enough waffling on, i'll let the pics to the talking.
First off i needed some 28mm thick discs to suit the calipers, using info from other threads i knew i wanted a minimum of 300mm and the maximum would probably be around 315mm for getting inside the pro race 1.2's, so i bit the bullet and ordered some 310mm discs from hi-spec.
I went for the ap racing copy version with a 46mm swept area, meaning the eye diameter would be slightly larger so i could offset the disc further back and have part of the balljoint inside it, meaning the wheel wouldnt need to be spaced out quite so much.
Once i had the discs i got some scrap steel and did some PCD drilling so i could see how far i could offset the disc before clearance would become an issue.
IMG_2091 by Steve Count, on Flickr
I have a spare 16mm hub with the balljoint still in it in the garage, so i used that to keep offsetting the disc then give the balljoint a good wiggle to see if it would touch the disc, i think i managed to get the offset to 15mm before things got tight.
Luckily i then decided it would be worth the time and effort of taking the setup out to the car and double checking, it was as on there with the 18mm balljoint the disc was hitting the ball cup.
I moved the disc until clearance was fine and ended up settling for 12mm offset.
I don't know if its the size of the balljoint that affects the clearance, or if its just different balljoint manufacturers that make the cup part to different sizes.
Either way, i'm glad i checked before i went ahead and made the bells.
IMG_2098 by Steve Count, on Flickr
IMG_2102 by Steve Count, on Flickr
Once happy with the offset i could work out the dimensions for the caliper brackets.
I knocked up a temporary bracket out of an offcut of ally angle to check i'd got it right. I had. Smile
IMG_2118 by Steve Count, on Flickr
I had to buy another set of wheels since i'm pretty sure the xantia steelies i've been using for the roads wont clear the new setup, fortunately some 1.2's came up for sale on here, 15x7" et16 just like my current set so i snapped them up.
I then used these to check the clearance before i went ahead and made the brackets and bells.
IMG_2149 by Steve Count, on Flickr
IMG_2151 by Steve Count, on Flickr
The wheels wouldn't fit if i kept the bell 8mm thick, so i had to space the wheel out slightly. I just kept shimming it out until it would rotate freely, once i knew how much i'd shimmed it out i added a few mm for extra clearance and set about making the drawings.
I was going to incorporate the spacer into the bells but decided in the end to make the spacers separately.
Next step was to order in the material and get it machined.
IMG_2157 by Steve Count, on Flickr
IMG_2160 by Steve Count, on Flickr
IMG_2163 by Steve Count, on Flickr
IMG_2176 by Steve Count, on Flickr
IMG_2177 by Steve Count, on Flickr
IMG_2162 by Steve Count, on Flickr
IMG_2168 by Steve Count, on Flickr
IMG_2175 by Steve Count, on Flickr
I gave the calipers a good clean.
IMG_2184 by Steve Count, on Flickr
They are now at the powdercoaters.
I want all the aluminium hard anodising, so to make the most of the minimum order i stripped pretty much anything aluminium from the car ready to take to the anodisers.
I also thought ahead on how the tyre seems to have rubbed on the wing with the standard spacing and thought about the wheels having a slightly wider track and decided that adjustable topmounts were the solution. They are now on order.
I haven't seen the top mounts yet but i know that due to KW being awkward using 60mm springs, 2.25" spring cups wouldn't fit so i'd have to make my own. Cue more aluminium turning. Laugh
IMG_2187 by Steve Count, on Flickr
They're pretty heavy, but i'd rather them be like that than too weak and fail on me.
I also took the time to remove excess material from my poorly thought out droplinks, they now look suprisingly like someone elses. LOL Whistle
IMG_2167 by Steve Count, on Flickr
I also made a couple of other bits for when i get the topmounts.
IMG_2190 by Steve Count, on Flickr
I'm pretty sure there wouldnt be enough thread after the spherical bearing to make use of a nyloc, so i made my own and i'll just use a drop of loctite on it.
I took all the ally parts to the anodisers today, should be ready next weekend all being well.
I've got new caliper pistons, seals, bell mounting bolts, pads and a few other things on order, all being well they will be delivered next week so i can make a start on building it up, conveniently i've got most of the week after booked off as i had to use my leave up at work.
I should at this point say thanks to Phill for being helpful whenever i've had any queries. Thumbs up
I think that's about it for now, it's taken an insane amount of time, effort and money getting to this point, hopefully now i can ease up on the spending for a while. Cool
Posted 9th Dec 2017 at 19:48
aaron6
Post #380
Looks good mate. Im a toolmaker so I appreciate those piccys. Smile
Posted 16th Mar 2013 at 21:40
marco gti6
Post #381
Nice progress Steve! You seem very handy with making custom parts for goldie Thumbs up
Looking forward to see you and the others this sumer on the Ring.
PS Get me a pic of your assembled self made droplinks please... Wouldn't mind some for mineWhistle
Posted 16th Mar 2013 at 21:44
Post #382
Those links look familar Steve....
The top hats are a little overkill, you can loose half of that thickness, bit late if you've dropped them for anodising already though LOL
Posted 16th Mar 2013 at 21:50
Post #383
Nice workCool
What colour anodising have you gone for?
And how much has it cost?Thumbs up
Posted 16th Mar 2013 at 22:44
Post #384
One of the perks of my job i guess Marco, can't wait to get it over there now. Big grin
I'll get some pics of the links once they're assembled, i'm not sure i'm too keen on making droplinks for other people though, don't want to go stepping on other peoples toes.
Yeah, i wonder who'se links they remind me of Phill. LOL
To be fair mine just looked daft with the spanner flats in the middle and they were far from practical so i had to remove them somehow.
I still havent seen the underside of the topmounts yet so i didnt have a clue how much space i had to work with, so i decided to be quite leanient with the taper, allowing plenty of clearance, and i hadnt worked out how much material removal i could get away with and make sure they were strong enough for the job, so i left a lot on. I can imagine they are under some pretty high loads when hitting kerbs on track.
I could have just ordered the top hats from KW but whenever i've tried contacting them in the past they havent been overly helpful so i decided to have a crack at it myself.
Posted 16th Mar 2013 at 22:50
Post #385
Getting it all hard anodised in black.
Guesstimate is £50-60+VAT, but they may get some parts polished first for a better finish at slight extra cost.
Posted 16th Mar 2013 at 22:51
Takedown
Post #386
Wauw!!!!!!!!!!!!! great job, very jalous of what some guys can make from "scrap"
Now make me some caliperadapters please Wink
Posted 17th Mar 2013 at 09:29
Post #387
Great work Steve Thumbs up
So, do you want to make me some brake brackets the same as the Welly ones so I can buy some Wilwoods? Smile
Posted 18th Mar 2013 at 12:35
Post #388
Cheers lads.
I don't think my gaffer would be too happy with me making any more bits for cars for a while, it's taken me several weeks of stopping after hours and going in at weekends to get my bits done. The machine centres are currently flat out on proper work jobs and will be for the forseeable future, which meant i had to make my caliper brackets with the manual miller, god knows how many hours it took me to make mine. LOL
(Wouldnt have been so bad if i had one long stab at it, but when you have 1.5 or less hours per eve and you have to set it all up from scratch and clean it all down in that time you can see why its a pain in the arse.)
I've ordered eight new caliper pistons today, and the other bits like the seals and bell mounting hardware etc should have been dispatched today too. Big grin
Posted 18th Mar 2013 at 17:24
Post #389
Little update from the easter weekend:
Fitted new bridgecraft topmounts.
IMG_2210 by Steve Count, on Flickr
Collected all the ally bits from the anodisers.
IMG_2196 by Steve Count, on Flickr
And the calipers from the powder coaters.
IMG_2199 by Steve Count, on Flickr
The new pistons, seal kits and various other bits arrived ready for assembly.
IMG_2200 by Steve Count, on Flickr
I drained the old oil out, and got the oil lines off the two coolers. I noticed one of them had started to weep a little so i marked up the hoses and took them to a mates to have some ferrels crimped on, much better than relying on jubilee clips.
IMG_2221 by Steve Count, on Flickr
I then spent a few hours rebuilding the calipers, using a fine layer of rubber grease on both the seals for each piston.
IMG_2223 by Steve Count, on Flickr
Loctited the stainless helicoils into the caliper brackets.
IMG_2226 by Steve Count, on Flickr
Built up the bell/rotor assemblies.
IMG_2227 by Steve Count, on Flickr
Eventually slapped it all on the car.
IMG_2228 by Steve Count, on Flickr
IMG_2232 by Steve Count, on Flickr
Nice and tight. Cool
IMG_2233 by Steve Count, on Flickr
Just need to wait for my new pads to arrive now, then i'll get the brakes bled through, then i'll need a new set of tyres and tax and it's ready for some tarmac abuse. Hyper
Posted 9th Dec 2017 at 20:02
jmh306
Post #390
Every on likes it tightThumbs up
FB: South Downs French Car Club
Diablo 6 2001 low boost
Diablo 6 2000 100% standard working air con
Vw Caddy tdi work van
Posted 2nd Apr 2013 at 20:11
vts_tibi
Post #391
WOW! Grat work! Don't you wanna sell me those lathe chucks? Big grin
What kind of aluminium did you use for the bells and brackets?
VTS
best 60' : 2.272
Team Trackday™
Posted 30th Jun 2013 at 21:43
Post #392
Cheers, I used 6082 T6 ally. Smile
No plans to sell anything for the time being.
Posted 2nd Apr 2013 at 22:11
allanallen
Post #393
Just managed to have a scan through this Steve, some nice work Smile you'll be happy with the brakes, I've got the same calipers on one of my 205s and they're fecking brilliant!
Facebook
Posted 3rd Apr 2013 at 08:45
russbez
Post #394
nice work
My Rallye project thread
Posted 3rd Apr 2013 at 09:20
Post #395
Great work Steve, brakes look the tits Cool
Posted 3rd Apr 2013 at 09:37
Post #396
Thanks Allan. I had a read through your project thread on your Eaton charged 205 the other day, nice work on that. Thumbs up
I've had the car back on the road through may and the brakes are now bedded in so i took it out into derbyshire earlier to give it a bit of a shakedown since i won't get chance to take it on a track before i take it to the nurburgring, only one word can describe the brakes now and i'm not even sure it's a strong enough word; epic!
There is so much less understeer now that i have negative camber up front, i'm not sure if its becasue of the camber or not but the car does now seem to like to try and veer off in one direction or another when accelerating and braking, i'm suspecting that i could do with a bit more caster. Dunno
I wouldn't mind raising the rear ride height a touch as i'm not a fan of the wheel being so high in the arch, or the possibility of hitting the bumpstops, might do that next weekend if the weathers nice and i get a spare couple of hours.
Posted 2nd Jun 2013 at 19:26
Post #397
Forgot to add a couple of pics, i've had to buy more cage padding as i'm under the impression that the new rules at the nurburgring dictate that if you can touch your roll cage it needs padding. I've gone over some bits with some PVC tape to try and give it a bit more durability when scraping over it getting in and out.
I've also had to buy two new bucket seats since the bloody krauts have also decided that my old bucket seats with the surround part for my head is not acceptable for TF days. :&lt;&lt; Laugh
They aren't a patch on how comfy the older seats are so i'm just having these as my 'ring seats from now on. LOL
New vs. Old:
IMG_2330 by Steve Count, on Flickr
Both new in:
IMG_2333 by Steve Count, on Flickr
Padding so far, could do with another metre or so. Doh
IMG_2334 by Steve Count, on Flickr
Also treated myself to a GoPro, so should hopefully get more reliable trackday footage from now on.
Posted 9th Dec 2017 at 20:06
Post #398
Raised the rear back up a touch today, much happier with the stance now. Smile
IMG_2388 by Steve Count, on Flickr
Posted 9th Dec 2017 at 20:07
Post #399
Another small update, nothing great really just a bit of preperation for it's anual trip to the 'ring. Hyper
I sorted out a mount for my go pro, did a bit of triangulation between the roll cage and roof skin to prevent it from flapping about as much as it did using the go pro pivot arms alone. It also allowed me to drop the camera down a bit so it doesnt just look in the rear view mirror and forwards a bit so the A pillars are at the outer edges of the video.
IMG_2411 by Steve Count, on Flickr
I stuck my euro trip headlights in (a spare set with the beam deflectors stuck on, i'm too tight to keep on buying them each year and they are a pain to remove the sticky residue afterwards, hence the dedicated pair of lights LOL)
IMG_2415 by Steve Count, on Flickr
Then i decided it was about time to try and make the rear bumper a little less scruffy with the patch of missing paint. I'll let the pictures of that do the talking:
IMG_2409 by Steve Count, on Flickr
IMG_2410 by Steve Count, on Flickr
IMG_2412 by Steve Count, on Flickr
IMG_2413 by Steve Count, on Flickr
IMG_2417 by Steve Count, on Flickr
With these skills i should be working in a bodyshop. Laugh my ass off
To be fair it was a very lazy attempt at it, using halfords rattle cans and my only intention was to make it look less noticable than it was, which i think i just about achieved. Laugh
I'll probably just buy another blaze bumper in the future and stick that on when i get the time, i'm just trying to cut down the spending on the car at the minute whilst i work on getting myself on the property ladder. Sad
Posted 9th Dec 2017 at 20:10
Post #400
What the f**k is that! Huh?
LOL
Posted 30th Jun 2013 at 21:39
