displaying posts 326 to 350 of 884
Pages (36): first .. 13 [14] 15 .. last
Author Subject: Goldie the track car
Post #326
IMG_1698 by Steve Count, on Flickr
Undertray fitted, it held up ok on the local b roads, just got to hope its upto the task at Donnington tomorrow.
Posted 23rd Nov 2017 at 19:37
Post #327
Goldie held herself together all morning at Donnington, no real issues other than a slight clunk when changing direction, which i suspect is an ovalled hub. I've got a spare pair of 18mm hubs in the garage so i'll get a couple of wheel bearing kits, track rod ends and a pair of new balljoints and get them fitted before i go to the 'ring.
Over all i'm very happy with how well she did on track, the roll cage has made a huge difference to the chassis stiffness and improved on what was already a good handling car. Thanks Phill. Thumbs up
I managed to get a few videos on track.
Session 1
Session 2
Session 3
I was pretty steady on session 1 as its the first time i've done Donnington. Session 2 was ok. Session 3 it was wet so it was like driving on ice, as you may notice around 2:00 in. Tee hee
I got a fourth session recorded but with a HD camera, which the sound is awful on. It does briefly feature Carl though so i'll start it uploading and edit in a link when its done.
I quite enjoyed watching everyone spinning off once the track was wet. Laugh
Posted 18th Jun 2012 at 15:24
Post #328
Meant to come and take a look at your car,but the time seemed to go nowhereWhistle
Was that pile of gravel behind your car in the pits from the underside of your car????????Roll eyes
Thumbs up
Posted 18th Jun 2012 at 21:00
Post #329
Wasn't from mine but i believe it may have been from another 306. LOL
Session 4 - Turn down your speakers!
I've just changed the oil and filter this afternoon, and whilst on axle stands had a play with the front wheels, theres some play in the n/s one so i reckon the bearing is on its way out. I can't feel any play in the n/s track rod end but if i hold the body its very free to rotate slightly on the ball so i suspect that thats worn a bit too.
Posted 18th Jun 2012 at 21:05
Post #330
Might have been all the extra downforce from that diffuser! Whistle
Posted 19th Jun 2012 at 00:07
Post #331
Probably. It is a work of art! Laugh
Posted 19th Jun 2012 at 07:02
midlife
Post #332
I'm liking the undertray, nice piece of workThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 19th Jun 2012 at 07:52
Post #333
Looking good mate Smile
Sorry I never got back to you on Sunday, didnt get there til about 12:30 then was rushed around getting sorted for briefing etc. I didnt see you at all on the stand etc, what time did you leave?
Also, what rear suspension set up are you running? Looks to be going well in the videos Cool
Posted 19th Jun 2012 at 11:33
Post #334
Thanks Wayne.
No problem Chris. I think i left around 2:30 ish, car shows arent really my thing and i get bored really easily so once i was done on track i only stopped for a burger, met a few friends then buggered off home. LOL
Rear suspension is standard torsion bars and anti roll bar, solid mounts and the dampers which came with my KW V2's, which i believe are koni units.
The rear suspension is something which needs a bit of attention really, but i'm holding fire for the time being as something better may be coming up in the future.
I've got 21mm bars, a 30mm arb and the bearings for the trailing arm shafts sat under my bed. LOL
Posted 19th Jun 2012 at 17:13
Post #335
Thanks mate Smile
The rear of my car was awful on track, and just seeing its whether is standard, or the fact that its f**ked Laugh
Will get it rebuilt with hybrid arb and solid mounts I think and see how I get on with that.
Posted 19th Jun 2012 at 17:16
Post #336
Well, if Steve's was better, yours is f**ked! LOL
Posted 19th Jun 2012 at 20:01
Post #337
Thats what i was thinking. Unintentional neggy camber ftw on my beam. LOL
Posted 19th Jun 2012 at 21:46
Post #338
Same as mine. About 3 degress on the rear from knackered standard beam Laugh
Posted 19th Jun 2012 at 23:18
Post #339
LOL
Should have had lovely handling with all that extra camber Whistle
Posted 19th Jun 2012 at 23:26
Post #340
Update time.
I decided to treat the car to a pair of 18mm hubs which i picked up at bargain prices on here months ago. Pressed out the bearings, shot blasted them, wire wheeled the stubborn bits and painted.
New wheel bearings, ball joints and track rod ends.
IMG_1737 by Steve Count, on Flickr
IMG_1740 by Steve Count, on Flickr
IMG_1751 by Steve Count, on Flickr
IMG_1760 by Steve Count, on Flickr
A few weeks ago i bought a bargain filter, so set about cleaning that and fitting it, i had to move the ECU back to get it in a position i wanted it in, so i had to knock up some new brackets and decided to do a little triangulation to stiffen up the housing as the old setup could wobble a bit.
IMG_1738 by Steve Count, on Flickr
IMG_1767 by Steve Count, on Flickr
The windows have been leaking with heavy rain so i bought some of that adhesive backed foam stuff for sealing draughts for the rear 1/4's. Whipped the lexan out, stuck the foam round the edge and put the lexan back in. After a few days of testing with it being crap weather i'm happy that they no longer leak so i put the borders on which Chris supplied for me. I thought i'd got the countersunk bolts flush but apparently not quite. Not to worry though, the borders look infinitely better than the shiny stainless bolts standing out.
IMG_1768 by Steve Count, on Flickr
I had my heated windscreen fitted the other day. It works a treat, i'm well chuffed with it so far.
I drove it for a while without a sunstrip but got fed up of it being nearly impossible to drive in the evenings when the sun is low, so i've stuck on a new strip today.
IMG_1769 by Steve Count, on Flickr
I've just bought a trackace wheel aligning kit, so i can do the tracking myself once it arrives, should save me a fortune over the years.
I think that's about it. I'm taking it over to the nurburgring this thursday, so hopefully this year will be better than last year. Cool
Posted 7th Dec 2017 at 18:24
Post #341
I'm back from the 'ring now, managed 11 laps in her and one pax lap in a Noble M12 GTO 3R, which was pretty epic.
The weather was mostly rain with dry spells, which wasnt really ideal, however goldie never missed a beat and proved herself more than capable against some much more expensive machinery. Cool
Pic time:
IMG_1849 by Steve Count, on Flickr
Video time:
8:55 BTG
9:50 Wet BTG
Behind rwgti at the end
Behind a fast Mini before the battery ran out
During the trip i've managed to cover my discs in pad material, so braking is nice and jerky now, and i've once again got some clunking coming from the front end.
I'm sure i did some faster laps than the ones recorded but my usb adapter for the cigarette lighter didnt work so i couldnt charge the camera in my own car, and had to rely on using my mates charger when he wasnt using it which wasnt ideal.
I've also killed an almost new R888, but one of the old ones i had taken off was in decent condition so i'm going to get them swapped when i get time.
Posted 7th Dec 2017 at 18:27
marco gti6
Post #342
Some nice pics there Steven. I put some pictures on my Ring thread in the meets/events section from you and rob go have a look.
See you next year Thumbs up
Posted 19th Jul 2012 at 21:57
Post #343
Yeah i noticed your pics, just wish i had noticed before i spent hours trawling through the various photographers websites to re-find them. Doh LOL
Hopefully we'll see you next year, the 'ring has just gone into liquidation so the 2013 season is a bit unknown. Sad
Posted 20th Jul 2012 at 00:02
eddy_gti6
Post #344
Glad you are happy with borders mate Thumbs up cars looking well now Cool
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 20th Jul 2012 at 00:25
matt evans
Post #345
My most favorite ever Blaze. Looks ace in the action pics, you can see your committed in the corners.
Awesome project, keep up the good work.
honestly3k wrote:
owain wrote:
Posted 20th Jul 2012 at 08:14
Post #346
Blush A likeable blaze. Laugh
Thanks for the compliments. Thumbs up
Posted 20th Jul 2012 at 18:40
Post #347
No new shiny bits fitted for a while, i've been blowing my money on holidays instead LOL, but i did take it to Cadwell for an evening on track the other day.
Weather was crap, a tree fell onto the track after the sighting laps so shut it for 45 mins, and at the end a golf set on fire so it closed 10 mins early.
Only ended up on track for 40 mins out of the potential 2.5 hours, plenty of closures between all that with people spinning off.
Just one clip that i could be bothered to edit and upload. LOL
Clicky
Planning on doing another couple of trackdays over the coming months before i start spending money on the car again. Cool
Posted 20th Aug 2012 at 20:16
Post #348
Hey, at least you got to watch a burning Golf, the evening wasn't wasted LOL
Posted 20th Aug 2012 at 21:02
Post #349
True. Laugh
Posted 20th Aug 2012 at 21:32
seans6
Post #350
Great project, just read through it all Thumbs up
The undertray though, does it actually do anything? Also what was it like driving to germany with a stripped out interior did you wear ear plugs or just man up lol.
Posted 23rd Aug 2012 at 12:04
