displaying posts 226 to 250 of 884
Pages (36): first .. 9 [10] 11 .. last
Author Subject: Goldie the track car
Post #226
Sorry for the late reply, i've been having fun inside my new climbing frame. I had to duct tape the windows in, just hope no robbers come to steal the contents tomorrow whilst i'm stuck at work. LOL
The cage looks epic cheers Phill, i'll get everything out at the weekend and get some more pics up of it. Cool
Posted 23rd Nov 2017 at 19:00
Post #227
Laugh my ass off, screws and mounts are in your big box 'o goodies. Somewhere....
Had fun drilling that plate yet? LOL
Posted 12th Apr 2012 at 00:23
Post #228
It was too dark to see anything last night, my light has been broken since i last used it so it kept flicking on and off so i decided to just tape the one window in, the other one had the hinge and what not already attached which made it quicker and easier to fit, still a ball ache though. LOL
Not had the pleasure of trying to do anything else to it yet, just plonked the bonnet in position to hopefully avoid it getting much unwanted attention from the gypo's that stalk the streets whilst normal people are at work.
Posted 12th Apr 2012 at 06:55
Post #229
So that means if I double back today and steal the engine nobody will suspect? Big grin
Posted 12th Apr 2012 at 09:29
birk
Post #230
That one of your cages phill ? how much that cost to do?
Looks sexy Smile
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 12th Apr 2012 at 09:38
Post #231
I took the engine out and hid a 1.4 one in there just to catch you out. Razz
Posted 12th Apr 2012 at 09:44
Post #232
Looks sexy Smile
Depends how many extras you add LOL:
Posted 12th Apr 2012 at 12:39
clen666
Post #233
I want quite a few extras, inc solid engine mounts. And why haven't you designed a new lightweight subframe yet? Sad
Team 'unintentional rat look'
Posted 12th Apr 2012 at 14:51
Post #234
You learnt some new swear words yet Steve?
No time for a lightweight subframe, the original ain't too bad bar benefiting from some bracing, too busy making tubular rear suspension and top braces Big grin
Posted 14th Apr 2012 at 20:51
clen666
Post #235
Hmm, that is an acceptable answer.
Carry on
Posted 14th Apr 2012 at 20:54
Post #236
By tubular rear suspension do you mean just the trailing arms will be tubular, or will it be wishbone and coilover style?
I've not needed to learn any more swear words, i'm quite comprehensive with them at work LOL
I've just been de-spattering the cage, wire wheeled all the areas which have been welded and given them a couple of layers of hydrate 80.
Tomorrow if the weather holds out i want to get the seat bars welded in, then i can start masking the windows etc ready for painting. I had to hoover the car out today, someone left spatter, dust and all sorts of mess in there...and they didnt even paint the cage for me.
Posted 14th Apr 2012 at 21:00
Post #237
The bas**rds! Just can't get the staff...
I mean complete new beam with semi-trailing arms to bolt on Thumbs up
I hope those seat bars go in better than the engine chocks!
Posted 14th Apr 2012 at 21:02
Post #238
Tell me about it. Laugh
Posted 14th Apr 2012 at 21:04
Post #239
Have you found any more free tools yet? I had a full set of snap-on gear in there at one bit taking parts off so you might get lucky LOL:
Posted 14th Apr 2012 at 21:06
clen666
Post #240
I could do with a new beam...
Posted 14th Apr 2012 at 21:10
Post #241
Not yet, i'll have to keep an eye out, hopefully a nice 1/2" ratchet and full set of sockets will be in there somewhere amongst the wiring. Hyper
Is there any reason i shouldnt remove the cross member which goes from the sill to the exhaust tunnel in order to get my seat bars as low as possible?
I'd imagine that fitting the seat bars will help replace any structural strength the current setup has?
Posted 14th Apr 2012 at 21:11
Post #242
Yeah, the seat bars will sort that out, drill the fecker out, only spot welds. If I get my car running tommorow I'll nip over in the afternoon with yer paperwork + steal me ruler back/lend a hand for a bit.
Posted 14th Apr 2012 at 21:12
Post #243
Cheers.
I could also be interested in one of your beam setups, though i've got a set of 21mm TB's, 30mm ARB and a beam rebuild kit sat in my bedroom which i was going to fit at some point along with getting some neggy machined into the arms. Hmm
What sort of money would i be looking at for your beam setup and is there anything else i'd need?
If i've got as far as getting the welder out i'll be as kind as to let you have a try with it and see if its just me who'se s**te with it or if its the welder itself. I seem to be fine with proper industrial style ones but my dads is a cheap clarke one and i never seem to be able to get nice results, as im sure you may have noticed. Whistle Laugh
Posted 14th Apr 2012 at 21:13
Post #244
LOL
Bodyworks a bas**rd to start with when welding it to cage tube/plates. Specially the rusty bits!
Posted 14th Apr 2012 at 21:17
Post #245
I've got a little bit done to the car this weekend, I've hydrate 80'd all the welded areas on the cage to prevent corrosion, and done it on the triangulation to the front struts too.
Today i set about removing the crossmembers which normally live under the seats, for some reason the first one took me ages but i'd got into the swing of it for the second one and got it out in next to no time.
I then set about sorting out some seat bars, i wanted the seat to be central to the steering wheel and after some playing about decided that it needed to be closer to the centre tunnel than possible if i was to have the seat bars lower than the level of the exhaust tunnel. With that in mind i got the seat in a position that seems good for the pedals, marked it out and got the plates welded to the sills and tunnel.
Next i trimmed down some tube and welded that in, getting it as close to horizontal and the top of the tube to be flush with the top of the exhaust tunnel. My plan is to use the normal M8 nuts found in the tunnel for securing the standard seats and use them on that side's alloy mount, then i measured up and tacked on one of my home made mounting brackets to the bar, plonked the seat on to check it all lined up then gave it a test sit to ensure it felt good. It did.
Out came the seat and in went some finishing weld to the brackets.
I decided that i want the passenger seat to be in-line with the drivers seat so i've basically marked up where the plates needed to be, flap wheeled all the paint away in them areas then welded in the plates.
I also welded in the seatbelt mounting plates to the centre tunnel.
I ran out of time to get the bars cut and tacked in, the pub is calling me so whilst cleaning up the tools & mess i got the hydrate 80 back out and covered all the fresh welds. Earlier in the day i also noticed some little like nails stuck into the car at various places, i can tell you that kneeling on one of them is very unpleasant so i got walt and flap wheeled them all away, also giving the bare steel a layer of hydrate 80.
Enough typing, heres a few pictures:
IMG_1551 by Steve Count, on Flickr
IMG_1552 by Steve Count, on Flickr
IMG_1553 by Steve Count, on Flickr
IMG_1554 by Steve Count, on Flickr
IMG_1561 by Steve Count, on Flickr
Looks like i've got a co-driver once it's back on the road. Laugh
Posted 23rd Nov 2017 at 19:06
Post #246
It's better than what's under the bonnet LOL
Slow down a little bit, you're moving too fast is all Thumbs up
Yeah, I had a few swear words at those little pins/nails...ripped open two pairs of overalls on the feckers.
Posted 15th Apr 2012 at 21:30
Post #247
Cheers Phill, i'll try slowing myself down. Hopefully the weather will be ok tonight and i can crack on and get more practice in on the passenger seat bars. Smile
Posted 16th Apr 2012 at 06:58
Post #248
If you want some more practice, fancy doing mine for me? Smile
Posted 16th Apr 2012 at 08:36
birk
Post #249
If i dont get a welder sorted out soon, can i borrow yours steve, i need to sort my cradle out.
Why dont you get some spare metal and practice, its not that hard Smile
07889376885
Dan
Posted 16th Apr 2012 at 08:57
matt evans
Post #250
Making good progress, The dog looks lovely as well.
honestly3k wrote:
owain wrote:
Posted 16th Apr 2012 at 09:53
