displaying posts 1 to 25 of 31
Author Subject: Turbo failure or worn head??
binkagti
Hi guys, right i get a puff of blue smoke on start up. Once warm the car is fine, but when accelerating flat out there is no smoke coming from the exhaust but as soon as i come off throttle i get quite a large puff of blue smoke.
Now i know my tappets need doing and am getting the head sent to miles to be over hauled, but he did think it could be the turbo,
trouble is the car runs fine, keeps boost fine, goes like a rocket and no noise from turbo.
What do you think it could be??
TEAM Supercharged Rallye
Posted 20th Jan 2011 at 02:35
allanallen
Possibly turbo oil seals weaping a bit. A few friends of mine that run turbos never seam to worry about it to much. If it's getting worse though I'd certainly investigate.
What do you mean by tappets? You on solid lifters?
Facebook
Posted 20th Jan 2011 at 02:47
binkagti
Just sounds like a sowing machine at the top of the head, so want to investigate this.
Posted 20th Jan 2011 at 02:53
fletch
Track Head
Rings or Stem seals?
fletch
Track Head
Usually bent valve(s) on the 6 engine, think Ive only ever known one instance of worn tappet causing a top end tap.
Posted 20th Jan 2011 at 02:54
james_gti6
could be turbo, take of the intake pipe and check for play in the shaft, i know its a long shot but try forte seal conditioner, the stem seals had gone hard in my old saxo and this sorted it by softening them, worth a try for £15
if i dont see you in the mattress il see you in the spring
Posted 20th Jan 2011 at 02:56
allanallen
Or incorrect oil
Facebook
Posted 20th Jan 2011 at 02:57
binkagti
Also changing the oil and filter on weekend as apparently worn oil could build up carbon deposits thats what turbo technics say anyway
Posted 20th Jan 2011 at 02:58
jeffers Forum Admin
It does sound like worn blower oil seals I must admit......... :-(
Team Running Engine again!
Team Negative Camber!
Posted 20th Jan 2011 at 03:13
binkagti
Rubbish, along with a full suspension over haul and rebuilding the head and now possible bolloxed turbo, plus saving to go for france in sept not looking good at all.
Also thinking about it on the last kent meet the car on tickover was spitting out black what looked like carbon deposits from the exhaust, could be oil from the turbo??
Posted 20th Jan 2011 at 03:20
jeffers Forum Admin
Get the turbo rebuilt if that is the problem, I have a contact at a turbo place in Halifax that will do me a good deal, and a top notch job if that's any help binka?!
Posted 20th Jan 2011 at 03:22
binkagti
Yes mate, could be a big help, its a custom t34/35 hybrid, hopefully not to much money, knowing my luck it will be.
Posted 20th Jan 2011 at 03:23
chrisd306
id go with bent valves or stem seals as mine is a tapper and when giving it the beams and lift off, i get a puff off smoke, also i use oil on track days.
Im going to get a new head eventually
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 20th Jan 2011 at 03:54
Oil smoke on over run is a classic sign ov worn out valve stem oil seals, the vacuum from the cylinders drags oil from the lifter bores into the cylinders. The smoke goes away when you get back on the throttle as positive is restored. Not 100% but if you say the head sounds like a handfull of M8 bolts in a tumble dryer that's where I would start looking. Whats the mileage?
Posted 20th Jan 2011 at 04:11
jeffers Forum Admin
Binka, if the turbo wants doin in the end give me a pm il sort out some contact details for ya! Wink
Posted 20th Jan 2011 at 05:25
binkagti
Cheers jeffers, daveyboy yeah the head is quite loud, driveable but loud. It was meant to have a new head on it around 5000 miles ago lol, which was obviously not new at the time, must have been secondhand.
Think will get the head done then see if the problem still persists, if it does i know its the turbo
Posted 20th Jan 2011 at 13:25
rich_w
It could also be rings, for the same reasons Daveyboy discussed with regards to the stem seals.
Under boost the rings are forced to expand against the cylinder walls, but on lift off the vacuum conditions can draw oil past the rings into the combustion chamber.
When the heads off I would pop a piston out and at least inspect it, not much extra work.
Did they replace the rings as part of the rebuild after the rod broke?
Contact Details:
07732 822546
Posted 20th Jan 2011 at 15:55
binkagti
Yes mate they replaced these
Posted 20th Jan 2011 at 22:42
This is what I'd be looking at if the top end is making a noise, either the oil seals or the valve guides themselves.
Posted 20th Jan 2011 at 23:17
binkagti
Mega money to fix??
Posted 20th Jan 2011 at 23:59
mabgti
NV motors
Can only echoe whats been said.. only thing i can say is the rate of oil loss will determine if its stem, rings, or turbo respectively..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 21st Jan 2011 at 00:22
binkagti
About half a ltr per 1000 miles roughly
Posted 21st Jan 2011 at 02:03
whizzer 71
Normally if turbo is shot itll draw under vacumm, Ie when off throttle on over run or goin down hill so when you re apply throttle you get clouds, also can sometimes get blue haze on idle which will then clear after 30 secs or so on partial throttle, around 2k or so
Posted 21st Jan 2011 at 03:16
binkagti
No smoke on idle, does not smoke while coasting down a hill, only does it after taking it to the redline and then letting of. Also when reapplying throttle there is no smoke either.
Posted 21st Jan 2011 at 03:19
mabgti
NV motors
Bent valve causing damaged stem sealsYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 21st Jan 2011 at 05:14
