Author Subject: my proper gti6, not a wannabe
jord294
many people will remember this
so following on from this, the 6 is now road legal Big grin
last week was when the majority of the work was done. good job really, considering the weather we're having this week Sad
i bought the car, with no m.o.t. a snapped front spring, excessive noise of the exhaust and front o/s sidelight not working
first job was to remove the monstrosity of an exhaust system. cat welded to straight through centre pipe and then backbox welded onto that
replacement std exhaust, and o/e cat in excellent condition £95
next (and favourite) job, was to lower the ride height of the rear beam. but at the same time, fit new bearings and seals, and also use the vts 21mm torsion bars i had in stock
new mounts were also fitted, at a cost of £250 for the 4
didn't really know what height to set the beam, so i took into consideration of fitting thicker torsion bars and set it at 312mm between shocker mounts. i also left the a.r.b out, as chances are, i would probably have to adjust again
once the beam was back on, my work could commence on the front end of the car
i started off by draining the gearbox oil and the coolant, and then removed the std struts. i already had some almost new bilsteins, which already had eibach springs fitted. so it was a simple swap Wink
re-filled the gearbox with oil, and then started on fitting new cambelt, tensioners and waterpump
although the 6 has a fpsh, the previous owner had no idea when the cambelt was changed. so just to be on the safe side, i thought i'd get it done
once the plastic belt covers were removed, it was plain to see that cambelt and waterpump had only done a few hundred miles. typical! ah well !
once new cambelt etc was fitted, i fitted new thermostat and filled the cooling system, and bled. then replaced the o/e spark plugs with some NGK ones Wink
also fitted a k&n replacement filter, which i got cheap Wink
car fired up lovely Big grin
drove car to the end of my drive to check ride height.
as expected, it did sit a little high for my liking, so adjusted the torsion bars to bring the ride height down about 10mm. once that was done, i re-fitted the a.r.b, and hand brake cables. also fitted new shocks and tightened to correct torque
all i had to do then was bleed the brake system with fresh fluid, and job done
i also remembered i'd bought some later 306 headlights (crystals), so i fitted them also
once all the work was done, i gave the 6 it's first wash in my ownership, and to be fair, it scrubs up quite well (albeit a few little dents)
i've also just had 2 steel wheels re-furbed, and had some snow tyres fitted. will post pics up later Razz
(BIG THANKS TO EVERYONE THAT HAS SUPPLIED ME WITH THE PARTS TO GET MY GTI6 DONE Smile )
Posted 1st Dec 2010 at 17:33
mike rallye
some good been done there, lookin all good now
Posted 2nd Dec 2010 at 00:41
jord294
thanks pal
'if a jobs worth doing, it's worth doing well' Cheers
Posted 2nd Dec 2010 at 04:24
craigy_87
i really like the ride height!
looking good Thumbs up
Posted 2nd Dec 2010 at 04:44
Looking good mate Thumbs up
Posted 2nd Dec 2010 at 04:48
jord294
just a little more progress (most of the major work is for the warmer weather)
fairly normal looking bay (it will be a lot cleaner soon)
just a bit of colour Big grin
although it will probably be removed if i get hold of one of the custom made lower braces LOL
also decided, it was about time i changed the headlight bulbs
apologies if following pics aren't that clear but osram plus bulbs have made a difference Cool
old sidelight
old main beam
new sidelight
new main beam
Posted 31st Dec 2010 at 18:17
ant_kernow
nightbreakers ftw Thumbs up
cars looking good mate, great height Wink
team umpalumpa.
Posted 31st Dec 2010 at 18:31
j1mmy
very nice mate love the colour awesome Cool
now a very happy an proud GTi6 owner! Big grin
TEAM: Blaze phase 2
TEAM: Off the road for now Sad
Nimrods going up 4 sale will be available in the next week! Pm if interested.
Posted 31st Dec 2010 at 23:05
Didnt i see this for sale on pistonheads a few weeks back? Unsure
Posted 31st Dec 2010 at 23:29
jord294
correctamundo Yes
i had to get rid of one of my 306s and i gave the choice of 2
BUT since getting the gti6 road legal, i'm glad i made the right decision Thumbs up
Posted 31st Dec 2010 at 23:48
tvrfan007
Have you ever done a rear beam guide at all? I'm keen to understand all the bits of a rebuild of one. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 1st Jan 2011 at 02:21
jord294
i haven't. i prefer the business LOL
welshpug is your man. he has a guide somewhere Wink
Posted 1st Jan 2011 at 03:13
matt evans
Car looks ace fella. Good luck with the future jobs you have planned.
honestly3k wrote:
owain wrote:
Posted 2nd Jan 2011 at 00:05
chrisd306
looking good, shame its vile blue
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 4th Jan 2011 at 13:59
jord294
better than a pink rallye Razz
Posted 12th Feb 2011 at 21:48
jord294
sorry for the delay in updating this thread Blush
done quite a bit to the car, and most of you know, there's always something else to do LOL
first job i wanted to do, was get a nice fresh set of re-furbed cyclones
already had 2 decent pe2s, so decided to have 2 new ones (always been a toyo man)
while the wheels were away, i'd ordered rich_w roller bearing bushes to replace these
voila Cool
powder coated wishbones with new ball joints, and roller bearings fitted
and fitted
while i was under the car, i also fitted new diff seals and a bbm bottom mount Big grin
the difference in driving with roller bearings and bottom mount is like day and night!
also decided to check top mount
oops Thumbs down
luckily chassis mount is in good order Smug
genuine part new mount, and old fubar'd mount
next job on the list is to replace the slightly weepy steering ram. thanks to shakey, i have one ready to bolt on
future jobs, are to, fit freshly painted front calipers, new discs and pads, freshly painted rear yokes and disc protectors, and also powdercoated cam covers and inlet manifold
so watch this space Smug
Posted 12th Feb 2011 at 22:10
jord294
also did a bit to the interior
steering wheel was in a poor condition, so i decided to change
unfortuneatly, i was a little too keen pulling the wheel off, and pulled the wiring off the contacts for the airbag. but luckily my trusty soldering iron fixed my f**k up
better condition steering wheel fitted Big grin
i also wanted to repair the o/e wiring for the stereo. simple enough job, once i'd bought the proper connectors. even simpler job fitting the new head unit Smug
back to the exterior. i wasn't happy how the passenger door sat in it's frame. so i removed the door
adjusted hinges
and voila Big grin
sits in the frame a lot better
also the outer window weatherstrips had started to bubble (as can be seen in top of pic)
so replaced with new (the 2 in bottom of pic)
Posted 13th Feb 2011 at 00:57
