displaying posts 226 to 250 of 380
Pages (16): first .. 9 [10] 11 .. last
Author Subject: Red Rallye tidy up/underbody protection........
matt evans
Post #226
I must say Kev, the power curve on yours (and mine tbh) were some of the smoothest there today, plus yours sounded awesome.
To say its a daily driver, you keep it mint too.
honestly3k wrote:
owain wrote:
Posted 27th Jan 2013 at 21:28
Post #227
jord294 wrote:
matts got a gti 180 Blink
i thought the ka was his Laugh my ass off
Too manly for him a KAYes
Check out the cheeky intercooler on the sleeper rover 200Wink
Best sounding car running up on the rollers by farThumbs up
Posted 27th Jan 2013 at 21:29
Jake
Post #228
Wow! Looks mega clean, lots of work gone into that.
The 205
205 GTI6 For Sale
Off Racing!
Posted 27th Jan 2013 at 21:38
mik
Post #229
Kev, was it Millers XFS 5w50 you were using?
Cherry Rallye SOLD
Posted 27th Jan 2013 at 22:27
Post #230
ThanksThumbs up
YeahSmile
Came out pretty clean after 8k miles,never needed to top up,and virtually no oil bar a film in my seperatorThumbs up
Posted 27th Jan 2013 at 22:32
Post #231
The poor old car is on axle stands in bits againThumbs up
Tax was up end of Feb so thought SORN it for a month(hopefully) and get the tank down and front subframe to de-rust/paint the remaining underside I did not do when I first bought itSmile
Also got a VTS rack to fitWink
Planning on doing the cambelt/water pump while front susp is out of the way too.
Once the tank was down I inspected the brake lines and found quite a few patches of rust/corrosion on themAngry
So I've ripped all the pipes off,and the compensator and ABS!Whistle
Will re-pipe it with a single line under car with a bias valve in it then a T piece at rear to each side.
Not much rust to report thankfullySmile just the odd bit of surface rust on spot welded areas etcThumbs up
Posted 5th Mar 2013 at 20:49
Post #232
Had a surprise when I unbolted the upper subframe mount,water ran out of the hole!Thumbs down
Would explain the state of these,proper water trapAngry
Nearly forgot I'm refurbing a pair of front hubs tooSmile
At the beginning:
Degreased and wire brushed,then into the DEOX C Cool :
Out of the DEOX C,rinsed,wire brush in the drill then wiped over with Metal Blast:
Looking good,totally rust free nowYes
Posted 5th Mar 2013 at 20:55
marco gti6
Post #233
Coskev may i ask where you got your downpipe from and what cat you are using? Is it 2,5" if so would you mind telling how much that one cost you?
Thanks in advance,
Marco
Posted 6th Mar 2013 at 06:33
rich306
Post #234
Damn, a job done properly Smile
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 6th Mar 2013 at 06:49
matt evans
Post #235
Bufty boy phase three!
Good work gramps, be lovely when its done i'm sure. You going down the powdercoated route for the subframe?
You know the little cups that bolt to the front rails, that were full of water, they are actually two pieces, the cup and the square headed section, they just rust solid together. Give them a clout with a hammer and they'll come apart to be soaked in the deox.
Posted 6th Mar 2013 at 09:56
russbez
Post #236
ah awesome work
always tempted to take fuel tank off and derust under there
same with subframe, think its the only two bits that havent been off my car for a good derust
My Rallye project thread
Posted 6th Mar 2013 at 10:48
russbez
Post #237
ahhh man why did i see this, i know fine well my subframe cups will be like that LOL
ocd Yes
Posted 6th Mar 2013 at 10:56
Post #238
CheersThumbs up
Raining this mornAngry ,didn't consider the weather when I started stripping it outside!!!!Whistle
Thanks in advance,
Marco
It's a universal 200 cell sports cat off E-Bay welded into a Magnex de-cat pipeSmile
Pretty sure Magnec de-cat pipe is 2.5.
Cat was circa £100.
Ah right cheers!They are well stuck together atmLOL
Yeah satin black subframeThumbs up
Posted 6th Mar 2013 at 12:38
tvrfan007
Post #239
Whose is the 220 turbo?
Dedication there mate, dedication.
I'm Si btw Tee hee
Night Blue VW Golf GTD
matt evans
Post #240
Its some young lad from the local car club. Right heap it is, got a 620ti engine/box in it, we were just waiting for the thing to grenande on the rollers, alas it didnt, but it was boost cutting at 14psi, with an enormous backfire!
Posted 6th Mar 2013 at 12:52
tvrfan007
Post #241
Typical converted bubble then by the sounds of it. Most 'young lads' made them as they could convert a 214Si or similar to a 220 Turbo with ease without telling the insurance. Still running his standard ecu then with the bleed valve replaced with a maxed out bleed valve. Surprised he hasn't just added a motobuild tuning chip innit. even with the boost cut removed mems extrapolates fuelling curves beyond 14Psi anyway, your engine survives solely on the fact it ran rich to start with.
The engines are bulletproof on mems to be honest, especially with FMIC he's pretty safe at 14.
I'm Si btw Tee hee
Posted 6th Mar 2013 at 13:07
russbez
Post #242
let us know how easy it was refitting the subframe
take it there is no risk of fitting it squint or anything?
i bought a few bits from Pug to replace rusty cups and bolts a while back, i never done it cause i new it would be a fair amount of prep work before i put it back together
Posted 6th Mar 2013 at 14:03
Post #243
There are pointy plastic inserts on the subframe to line it upThumbs up
Matt will be able to confirm if they do work!!!Smile
Posted 6th Mar 2013 at 15:24
mik
Post #244
I bought new pointy plastic bits, cups and bolts new from Pug and scratched them up, Electrox and then silver paint (except plastic of course!). Sprayed Dynax UC on them once back together. My new subframe was etch primed (B-H Etchweld) then satin black painted, with Dynax S50 cavity wax sprayed inside.
Haven't got fuel tank off yet though.
Cherry Rallye SOLD
Posted 6th Mar 2013 at 19:51
matt evans
Post #245
Mine went straight back up, no worries.
Posted 7th Mar 2013 at 11:56
Post #246
Was hoping to get a good few hours in today and finish off removing the underseal and surface rust ready to paintAngry but woke up to find this:
So looking like the Rallye might be off the road for two months rather than my planned one monthThumbs down
Posted 22nd Mar 2013 at 14:06
mik
Post #247
I know what you mean. The other day I had the genius idea to shoot the lacquer onto my C5 wheels before I went to work as it was near ideal outdoor spraying weather - i.e. not raining or windy. Good job I did as it was raining when I got home and hasn't stopped raining since. And I can't do it in the garage because the slightly disassembled car is in there. And I don't think my wife would like a partially lacquered kitchen floor.
Cherry Rallye SOLD
Posted 22nd Mar 2013 at 14:46
Post #248
Another day off and nothing doneAngry
I'm pretty keen when it comes to getting under the car to do some work,but this weather is taking the p**sThumbs down
Not a sniff of getting anything done.
The eagle eyed of you 306 experts might spot something I've cut off the carWink after hitting my head on them too many times!!!Whistle
Posted 25th Mar 2013 at 12:23
Post #249
Hope you don't sell the car to Hovis in the future. He'll have nowhere to put the axle stands LOL
  • Posted 25th Mar 2013 at 12:27
    Post #250
    LOL
    That's another reason for cutting them off!Yes
    To stop numptys putting axle stands under themRoll eyes
    And they hold water and had surface rust all around themThumbs up
    Posted 25th Mar 2013 at 12:30
