displaying posts 26 to 50 of 57
Pages (3): 1 [2] 3
Author Subject: Trackday / Ring Toy build
ashtal
Cutting and notching door bars is an easy job! Roof bar is a nightmare, easy way to waste alot of time scratching your head!
By ashtal82 at 2010-11-07
Not bad for a beginer.
Door bars
Ran out of mig wire so the days work was cut short
Rear pick ups being joined
So far
Posted 8th Nov 2010 at 02:40
gti_ben
Good skills with the cage!!
Posted 8th Nov 2010 at 21:15
is it getting double door bars then?
Posted 8th Nov 2010 at 21:20
ashtal
Yeah, want to tack the main bar in place before i start cutting the x tube tho.
Already cut one short!!!
Posted 8th Nov 2010 at 23:15
ashtal
Seat frames! As my seats are under mounted i need to make the brackets up myself.
Im planning on using a 60mm X 60MM 3MM plate to weld either end of the tubes to spread loads. Will a 25mm box tube be up to the job for the frames!?! If so where can i get some!
Posted 17th Nov 2010 at 01:38
tvrfan007
Is it just me or has that cage obscured the rear beam mount bolts?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Nov 2010 at 12:53
yeah, mine is like that so have had to make my own tools to undo things LOL like a swan neck spanner and a few other funny things. fine now though!
Posted 17th Nov 2010 at 13:37
ashtal
Not at all, the bolts are down the pipe. Just need an extension on you socket!
Posted 17th Nov 2010 at 14:30
want to see how this goes around a track with those aps before i invest in some lol
Posted 17th Nov 2010 at 16:44
ashtal
Post #35
Done a sub 9.30 BTG at the ring! Not to bad.
Posted 18th Nov 2010 at 01:53
jimmy_boy
Post #36
Great work with this.
A few of us just went to Oulton last week for a blast. Come along next time and let us see the project in action Smile
Nice pic on the Nordschleife too Cool
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 19th Nov 2010 at 23:23
ashtal
Post #37
Had some good progress with the rear half of the cage.
By ashtal82 at 2010-11-21
Posted 21st Nov 2010 at 22:51
lotek
Post #38
thats a good looking climbing frame Yes
Posted 21st Nov 2010 at 23:39
chris with a pug
Post #39
are those harness bars? they look way too high. And how come ur rear diagnal comes so far in surely its better for all the bars up there to meet at the same place
Posted 22nd Nov 2010 at 00:34
ashtal
Post #40
The harness bars are as long as they can be to allow me to cut to length when the seats are mounted. They need to fall at 10 degrees from the seat harness holes so cant be done till the seats are in position. When i got my cage i spoke to the bloke who makes them he said it makes no odds to the cage as every pipe you fit is just to support the hoop.
Posted 22nd Nov 2010 at 00:53
Post #41
they look perfect there, unless you're a real shortarse.
Posted 22nd Nov 2010 at 00:54
Post #42
It is better for them to meet at the same place, less torque on the hoop in a crash then, but anywhere within 100mm of the centreline is OK by MSA regs anyway.
Posted 22nd Nov 2010 at 00:58
chris with a pug
Post #43
I am a short arse LOL
but they look ok in the other pics I was looking at the one from above and they look higher than they are. Doh
Posted 22nd Nov 2010 at 01:18
bellcp306td
Post #44
The green stuff pads are not that good. go yellow stuff if anything
Where did the road go!
Posted 22nd Nov 2010 at 18:12
ashtal
Post #45
Well, im just about ready to take the car to work and do the finishing touches before welding it up!
This is the way i have decided to mount the seats
By ashtal82 at 2010-11-28
I have put the bolt in the seat from within the seat so when bolting it up its just a nut on the underside, Less messing about trying to line up holes! Smug: Smug:
After aome messing about i also cut and fitted the tunnel brace.
This is a really tight fit and should offer really good side impact protection.
The X door bars also got cut and tacked in place, not and easy job todo as the hole cutters wont do the cut in one go and the cutter wants to hit the notching tool before finishing the cut, but there all done now.
I have started the seat mounts but will finsh them at work as it was -2 and i was getting cold! Also the dash bar and front triangulation todo. Its getting there now tho. :thumb:
Posted 28th Nov 2010 at 19:50
ashtal
Post #46
Im further on than the pics show but not taken any pics of that yet!
In regards to cutting holes in the floor etc, when the hoop mounts were removed, the cage could drop back and allow me to get any my welds done to all the top surfaces. Happydays
Plenty of room to get the welder in!
Posted 26th Apr 2011 at 18:19
Jonnybravo
Post #47
Well there have been updates on this car.
Firstly Ashley finished the cage and its had the interior painted, we modified the dash and sat down and worked through the wiring which tbh there appears to be a LOT of stuff that isn't required, I'll probably set to removing a fair bit of it once I've got my head round it and its up and running again.
The engine had the dreaded ticking that seems to be very common, I convinced Ash that we should sort this so the engine was removed and the head removed, turned out that the 2 inlets were very mildly bent so we have replaced those.
The head is being bolted back on tomorrow night and timed up, should be back in and running on saturday.
I need to sort out some oil for it, its a track only car so will simply be getting a good thrashing 99.9% of the time so any advice on a good oil would be appreciated.
More updates soon, I'll tell Ashley to stop being a tightarse and pay the fee !
Posted 27th Oct 2011 at 17:20
Post #48
Looking great, I really wanted to get mine into paint before the winter but it's not going to happen Roll eyes
Posted 27th Oct 2011 at 18:05
rallyeash
Post #49
Thumbs up, good work guys
309 3dr K20 Type R
Posted 27th Oct 2011 at 18:23
marksorrento205
Post #50
Im liking it Smile Being sprayed in white its giving me ideas of what mine could look like LOL
Posted 27th Oct 2011 at 19:32
Pages (3): 1 [2] 3
