displaying posts 1 to 25 of 134
Pages (6): [1] 2 3 .. last
Author Subject: Mount mod!!
dommorton Forum Admin
At last I have stopped my top engine mount from flopping about!!!
Me and kebabman discovered moons ago that if you chock the top mounts buffer the mount does not move at all!! result
Got so fed up with engine movement as I change gear and come off clutch Angry
Even with new mount there was little change Sad
Basically all I did was remove the top cover part of mount
Made up a piece of 4mm angle. Drilled a hole in it.
Wedged it between mount buffer and body (totally locking the mount so it can't budge)
Then bolted it down with the existing bolt that holds the cradle on
It's amazing the change it makes to the feel of the car Shock
Result Big grin
dommorton has attached the following image:
Posted 22nd Aug 2004 at 16:39
Here
Posted 22nd Aug 2004 at 16:38
and back together
dhampton
thought it was a bit odd that there was a gap either side.
was it like this from new?
"good thinking batman!" - sorry it had to be done Smile
Clio 182 FF 306 Rallye (track) 306 Gti-6 Megane R26 Clio 172 Cup (track) 106 Rallye S2 (track) 306 Rallye Saxo VTR 106 Zest2
Posted 22nd Aug 2004 at 16:48
Yep they have always had the gap Blink
much better to drive without one tho Happy
Posted 22nd Aug 2004 at 17:28
Adam PV
AKA jjfukkard
Make me one? Moolah moolah moolah?!?
Please? Whistle
JJ
Blessed are the cheesemakers...and all purveyors of dairy products....
Posted 22nd Aug 2004 at 17:38
Yeah Dom, how much do you want to make me one please?
Thanks mate,
Stan.
Posted 22nd Aug 2004 at 17:40
Welly Forum Admin
Ohh....
Dom do you reckon i could use those rear beam tensioners in there rather than the killing the ride on the back of my motor
They are poly so would offer better resistance
Vrs power!!
Welly it would be hard to make um stay there wouldn't it? if not then go for it Yes
As for making more of um Doh
It's so easy to make one yourself Laugh
Posted 22nd Aug 2004 at 19:27
6miester
Lazy lazy people! (yeah i also need one cheers DomWhistle Thumbs up)
The Joy Of 6.
But boost is stillbest!
Posted 22nd Aug 2004 at 19:29
justin
Dom forgive me for being awkward but why did peugeot leave such a big gap in the first place ?
This may sort my exhaust problem out as well ?
time for a new sig!
Posted 22nd Aug 2004 at 23:01
god knows why the gap is there?
Car is a million times better with mount shimmed Yes and less movement means less exhaust trouble Yes
Posted 22nd Aug 2004 at 23:14
alien
what sort of symtoms are there with this engine movement as i think mine is the same especialy coming down the gears it drives me mad lol
Posted 22nd Aug 2004 at 23:20
justin
Dom did you buy that piece of metal with the bend in or did you bend it yourself ? I shall try and fit one of these tomorrow. Did you fit this on both sides of the buffer ? If you didn't won't one side of the mount cover sit higher because of this plate ? Cheers fella.
time for a new sig!
Posted 22nd Aug 2004 at 23:31
jimmy_boy
Nice mod ... may incorporate this idea into my repair we are doing this week Smile
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 22nd Aug 2004 at 23:52
nwphoto
Club Snapper
Cool
that'll take some strain off the mounting hole at the bottom too!...
....i'll be in the workshop tomorrow then!
Posted 22nd Aug 2004 at 23:55
ash
Six Addict
I fitted two big washers between the front and back of the engine mount which pushes the rubber pyramids tightly against the car which has the same result at yours.
Posted 23rd Aug 2004 at 00:23
nwphoto
Club Snapper
don't they fall out?Unsure
Posted 23rd Aug 2004 at 00:47
ash
Six Addict
nope - they are trapped as it is a kinda v shape. Well not moved for several thousand hard miles anyway! Doms approach looks a bit more professional!
Posted 23rd Aug 2004 at 00:55
nwphoto
Club Snapper
quote:
....Doms approach looks a bit more professional!
....'til it goes rustyWhistle LOL
edit: sorry, dark blaze
Posted 23rd Aug 2004 at 08:06
jjfukkard-work
Result Big grin
Initially this seems like a good idea.....but won't this put stress on the engine mount?
It's supposed to have some give in it or there will be stress on the engine mount/bolt it self.
Won't putting a chock/stabilizer in at the top mean stress further down, possibly causing damage to the body where the mount is seated....we all know how fragile that is.
I'm not picking holes, I'm just trying to think of any down sides to adopting this mod. Unsure
[url]http://www.adampv.pwp.blueyonder.co.uk/vids/Movie.wmv[link]K&N+decat+Scorpion=Big grin4miles!Love <---clicky
Posted 23rd Aug 2004 at 08:09
nwphoto
Club Snapper
i would say that with less rocking, there'd ne less strain on it, although excessive rocking might have been caused by a weekness in one of the other mounts.Unsure
Posted 23rd Aug 2004 at 08:14
Yep deffo less strain Yes as it was the mount takes a hammering and works loose.
Had the metal in the garage Big grin with bend Big grin
Just fitted to the one side. Yeah the top thing sits higher one side but that's not an issue
Posted 23rd Aug 2004 at 08:50
jjfukkard-work
Yes, there may be less rocking, but the engine mount is made of rubber so that is will give rather than just break. There is going to be a sheering affect on the mount is there not?
Posted 23rd Aug 2004 at 08:54
nah
before it pulled the mount from side to side too much which damaged the bodywork underneath and made the mount very soft.
Like this the mount works properly. There is still give in the rubber. I can see you would need to see this in action to be totally convinced Roll eyes
Remember the bodyshell was designed with 1.4, 1.6 etc engines in mind.
Then pug dumped this engine in with no bodywork mods Dry
Posted 23rd Aug 2004 at 09:00
This thread has been locked
