displaying posts 26 to 50 of 134
Pages (6): 1 [2] 3 .. last
Author Subject: Mount mod!!
benny2097
i made a similar wedge months ago from aliminium plate and made a packing piece for other side to make arched cover sit straight when bolted back on so mine wont rust and it does make a huge differance spoke to a few garages and tuning places and the say putting it in will help reduce stress as there is still movement but it is more controlled and not as harsh
Posted 23rd Aug 2004 at 10:19
WillGTi6
I just have a flat ally plate wedged in there with a hole in the top corner and a zip-tie holding it tight to the top thing. A bent piece like doms and bennys would probably be a bit more professional but mine does the same trick.
It does make a huge differance to the smoothness of the ride, no big lurch when lifting off/changing gear etc.
Posted 23rd Aug 2004 at 10:26
jonboy3020
peugeot sell shims for that specific reason, to pack the top engine mounts out....
Are peugeots supposed to be reliable???
Posted 23rd Aug 2004 at 11:18
dommorton Forum Admin
Do they? Blink
Where do the pug ones fit?
Posted 23rd Aug 2004 at 12:10
sam
Would this stop my engine from creaking?? When in the drive, if i wind the windows down and, leave the hand break on and lightly bring the cluch up you can hear a creaking noise from the engine bay, dose it on the move to....Crazy
Times move on and things change, My old 6 i loved, my new Civic Type R i respect! Who ever invented V-tech IS A GOD!!
Posted 23rd Aug 2004 at 12:33
Sam
You have cracked bodywork under your main mount I should think
You need the mount stripped out and the bodywork inspected and welded if necessary
Posted 23rd Aug 2004 at 12:44
sam
quote:
Sam
Oh sh*t!! Is this majour??Shock
Posted 23rd Aug 2004 at 12:46
sam
Is this the result of this gap being to big on the engine mount?? (that you cured with you mod??)
Posted 23rd Aug 2004 at 12:49
jimmy_boy
Water sits in the bottom of the mounts cradle and rust weakens the body Sad
I expect many of us have this problem but don't know about it yet Mellow
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 23rd Aug 2004 at 12:58
Post #35
I don't think it's rust that causes it Jim
It's the flexing of the mount tears the bodywork
This in turn then rusts
Posted 23rd Aug 2004 at 13:00
pottsy
Post #36
The creaking could be the exhaust as mine used to do this and the mounting was fine as I fitted a new mount and no metal work damage at all.
Impreza Turbo 2000 (every day car)
Peugeot 309 MI16 track car
Posted 23rd Aug 2004 at 13:03
nwphoto
Club Snapper
Post #37
my creaking was the clutch mechanism!LOL
Posted 23rd Aug 2004 at 13:14
kebabman
Club Meat Vendor
Post #38
I can vouch for this making tha car feel better, especially in 1st gear, no more lurching in traffic!
Looks like that might stay in place a bit longer than our initial efforts with my car Dom Whistle LOL
Mechanical genius Wink and purveyour of fine meats - You wan chili saus?
Posted 23rd Aug 2004 at 13:28
nwphoto
Club Snapper
Post #39
sounds about right...rustproofing is generally very good otherwise
Posted 23rd Aug 2004 at 13:31
Post #40
Mount Chock Vers 1.2 Laugh
Posted 23rd Aug 2004 at 13:39
mr swampy s16
**BAD SELLER**
Post #41
ive done sonething similaie only used apiece of very thic rubber (section of a ford diesal bottom hose)
does the trick very well,also being rubber it will still give a little
Posted 23rd Aug 2004 at 13:43
jimmy_boy
Post #42
Mmmmm, mine has rusted and cracked before it even started to tear.
Bear in mind that the thread runs through the body and the rubbing alone would take any rust proofing away
GTI-6 & Rallye
Posted 23rd Aug 2004 at 13:47
justin
Post #43
Dom i have to say it your a genius -
I've chocked the mount with a 6mm piece of metal a stainless disc actually and taken the car for a drive.
1. Pulling away there is minimal judder from the clutch.
2. Changing gear is like so smooth its like butter - gears drop in really cleanly and positive.
3. Flooring the car now puts full energy into the wheels instead of iinto the mount moving and this makes car feel faster and you can actually feel the different power coming in across the rev range.
4. Floring it round corners feels a dam site smoother as engine isn't flopping about effecting the steering by tugging at it less.
But the exhaust is leaking at the join more - so what i reckon i will do in this case is wedge both sides equall amount so when engine is in the upright position it will be chocked central rather than chocked back towards the cabin. This should be ok shouldnt it ?
Top man and five gold stars Cool
Its quite amazing how much this effects lots of aspects of the cars drive. Big grin Big grin Big grin
time for a new sig!
Posted 23rd Aug 2004 at 13:52
sam
Post #44
I think you could be right mate, just poped down the garage to get her booked in for next week, and when i got home and reversed into the drive way i hung out the window (Ace Ventura stylee) and it sounds like it coming more from under the car rather than the front, I do have a magnex so could be more than likely the exaust and not the mounts ( I will get them checked anyway)
Posted 23rd Aug 2004 at 14:12
alien
Post #45
i have done the mod too with a small peice of meta,l god!! what a difference up changing is smoother and so is coming down the gears especially in to 2nd, i only had to pack one side as the other was flush with the craddle, almost as if the mountings were made badly?
Posted 23rd Aug 2004 at 15:00
stue306
Scarface Pilot
Post #46
i think ill be making one of thoseWink after ive had the captive nut/plate welded for the second timeRoll eyesLOL
R.I.P pete,see you at the crossroadsWink
so i dont forgetWhistle [url =copyandpastelink]type a clicky title[/url]LOL
p2 gti-6, scooby wagon'restoration project'
Posted 23rd Aug 2004 at 15:49
Post #47
Smug
your all welcome Big grin
oh and justin just get a new downpipe kit fitted as it sounds like engine movement has killed yours Wink
Posted 23rd Aug 2004 at 16:27
WillGTi6
Post #48
Movement sorted, now i just need to sort the crack under the mount Sad
Posted 23rd Aug 2004 at 16:30
alien
Post #49
oh a word of warning regarding packing the mounting out, make sure the pieces are secured ie with cable ties or by the cradle thing that bolts over the top of the mount because if the piece of metal was to fall out of the mount it will fall into the polly belt!!! and it will prob cause big damage!! if it takes out the cambelt
Posted 23rd Aug 2004 at 16:42
Post #50
Agreed hence my bolt down option Wink
Posted 23rd Aug 2004 at 16:53
This thread has been locked
