| Author | Subject: Diablo Track Toy |
eddy_gti6
Post #151
there are a couple of little chips in the bore but nothing big. i wont be using that block for my rebuild tho. i will get a better look at it today once i get the whole lot stripped down. i found chunks of piston and the valve seat inside my inlet manifold and sump. all i need of this block is the crank if its ok________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddy_gti6
Post #152
been on all day stripping both my bottom ends down and making up one good one. striped the 1st one down whet has the hole in the piston, all i needed was the crank and shells, once i got them out and checked them they were all fine, not a mark on them. started with the 2nd bottom end what had sized big end bearings on conrod 4. stripped it down, removed crank and shells ande gave all the bits i was going to use a good clean. built the block back up with bood shells and crank, torqued them down to what it said in the bookbig end: 25nm then a further 70degree turn main bearings: 20nm then a further 60degree turn put everything else back on, oil pump ect... and it wouldnt turn over by the crank pully. so i took it all apart again re tightend all the bolts and put it back together and still no joy ![]() think am just going to buy a new engine and save the hassle on. ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
CUJ
Seasoned Pro Location: Southampton Registered: 18 Apr 2006 Posts: 22,218 Status: Offline |
Post #153
I've just done exactly the same thing, with the help of Welshpug and Ash. Hope you get there mate, that piston was a mess ![]() I'm sure it's something simple why it isn't turning, I'm afraid I don't the knowledge to advise though. ________________________________________ 340 horses |
eddy_gti6
Post #154
has to be something simple, maybe over tightend a bolt or something? lost interest now so will leave it for another day________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #155
eddy_gti6 wrote: think am just going to buy EFA!! |
mjm3043
Regular Location: inverness Registered: 26 Mar 2009 Posts: 195 Status: Offline |
Post #156
did you keep the caps for the crank on the same block and in the same order, if not thats why its locked up. |
eddy_gti6
Post #157
yes, removed all shells, placed them in order of where they came from and put them back in the same place.swap for my 6 and 2 broken engines ash ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #158
eddy_gti6 wrote: swap for my 6 and 2 broken engines ash you missed out the 2k in the deal |
Post #159
did you use the original crankcaps from the same engine? or the ones from the other block?new piston rings? Jon's engine was very tight due to the new rings, but still turned over fine with a spanner. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #160
Check the main caps are all in the right way round, not just in the right numerical order, they will fit both ways round and when you torque the caps up it nips the crank. I've done this before.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
Post #161
I done that to mate used caps from a diff engine and it locked up used the orginal ones and it was fine________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
eddy_gti6
Post #162
yeah, used the crankcaps from the engine i got the crank from. so if i use the crankcaps from the block i am using now they should be fine? i will give it a go tomorrow. hopefully my new head should be here tomorrow so i will get may dad to strip that down for me if he has nothing else to do ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddy_gti6
Post #163
well get the crankcaps swapped over today, engine turns over just fine thatks for all the advice decided to fit my battery cut off switch aswell. not got if on the car you but this is how its looking so far, i was going to put it on the inside of the car but couldnt fand anywhere to put it so i got the idea from the BTCC cars and put it just beneath the windscreen. sorry about the pic quality, i will get better ones tonight once i have fitted it to the car ![]() ![]() ![]() ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddy_gti6
Post #164
recieved my new head today. made a start on stripping it down and cleaning it up. managed to get the cams out and used some petrol to clean all the shit from underneath them. need to strip my head down tomorrow to get my cams as the ones in the head i have just getten aint in the best condition. all valves look fine and fully close. once i get the head built i get get the engine back together ![]() ![]() ![]() you can see the difference where i have cleaned one side of the head ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #165
crikey I hope that was cheap!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
eddy_gti6
Post #166
welshpug! wrote: crikey I hope that was cheap! try befor you buy friend helping a friend in need ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
chrisd306
Post #167
it was free untill he see if it works or not, it was erm stored outside my garage dunnno why it wasnt inside it!________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
eddy_gti6
Post #168
changed the valve the valve caps today and fitted some different cams out of my old engine. decided to give the head a lick of paint to tidy it up aswell while i have it out. next job is to get a head gasket and get the engine back together at the weekend at the latest i hope.________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddy_gti6
Post #169
engine is on the rebuilt, been on painting afew parts today and putting everything back on the bottom end. also got all my new stainless bolts today from mr swampy s16 ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
tea boy
Senior User Location: Market Rasen Registered: 27 Feb 2010 Posts: 632 Status: Offline |
Post #170
eddy_gti6 wrote: decided to gove the head a lick of paint to tidy it up aswell. You not finished that tin of red paint off yet? ________________________________________ Make tea, not war.If it ain't broke......fix it until it is. |
eddy_gti6
Post #171
no, not yet how did you no it was going to be red? done the bottom end today but that went black and gray found a new favourite colourblock, head gasket and new bolts ![]() ![]() ![]() ![]() ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
chrisd306
Post #172
somebody take that f*cking rattle can of him!!________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
jimmyrallye
Seasoned Pro Location: portsmouth Registered: 19 Apr 2008 Posts: 3,144 Status: Offline |
Post #173
^^^ hes ruthless with that can ________________________________________ "Police arrested two kids yesterday, one was drinking battery acid, the other was eating fireworks. They charged one and let the other one off." |
eddy_gti6
Post #174
got to look good under the bonnet ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
chrisd306
Post #175
thought you were going to be smoking the tyres this weekend, or was that just shite you were writing on facebook christoph?________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
