displaying posts 601 to 625 of 775
Pages (31): first .. 24 [25] 26 .. last
Author Subject: Track Cars for Dummies
Post #601
...again?
Posted 12th Sep 2011 at 12:57
cwspellowe
Post #602
It's basically just an industrial rampant rabbit, right? Big spinny bit on the end of a shaft?
New to the Ann Summers Industrial range Laugh
Bye bye Sundance Kid Sad
Posted 12th Sep 2011 at 13:22
Post #603
Was chatting to a guy at work about my wire locating problem, when another guy walked past and overheard. One of those guys who's always go loads of weird shit. "Ah, what you need is a Fluke!". Eh? "I've got one in my car, I'll go and get it".
Well yes basically it's exactly what I needed. Attach a cable at one end which puts a signal down a wire and a probe that detects the electromagnetic field the other end and you know which wire is which. Sounds pretty spot on to me.
Except it didn't work. No idea why, whatever.
Instead, went about splicing into the main ignition feed. I didn't have any massive cable, but as the return from the ignition switch splits into two anyway I just ran two bits of 17A cable; that'll be more than enough, I've got barely any electrics to run any more other than the ECU.
First up, get the little resistor. In case anyone ever needs a replacement, it's an 11W 3.3Ω jobby.
EDIT: Wtf? Why can't this godforsaken forum display an Ohm symbol? Jeez, it's not 1995.
Both ends attached to wires to give a bit more choice on the location; spade on one end for the switch and a ring on the other to be earthed.
With that sorted, I made up and ran my little four-wire loom for the ignition, and stuck that behind the dash.
Under the ignition, you're looking for the double pole connector with orange & yellow on the key side, and white and a yellow & blue twin on the other. The white is the feed to the switch, so is probably the better choice to cut into. However I wanted to take advantage of the two wires, so I cut into the return. Make sure they're properly soldered and heatshrunk to minimise the chances of them coming undone...
And job done. Double-check against the diagram, and give it a go. Works a treat - engine cuts instantly, no drama, no issues restarting. Brucey.
Took the car for a bit of a hoon after that, seeing as it's quite late. Got it up to temperature, oil cooler kicked in and doesn't seem to be p*ssing oil out, which is a bonus. Still over-cools on roads, but that's to be expected.
The brakes are still weird (which is kinda to be expected, as I haven't changed them...) but do give the impression they'll be awesome once they're done. It seems to pull slightly to one side under really heavy braking, whether that's down to the imbalance due to air in the calipers, or one of the rear calipers sticking I don't know. I did have to free up one of the rears when I changed the discs, so maybe it's just siezed again.
Possibly time to get them off and do a proper refurb job on them, oh joy. Maybe some other day eh?
Posted 12th Sep 2011 at 20:26
cwspellowe
Post #604
Thank god you didn't over tighten then!
Posted 12th Sep 2011 at 20:42
Post #605
I know! Imagine! I'd have saved two litres of really expensive brand new oil! Disaster.
cwspellowe
Post #606
Just use the cheap stuff ffs, you have the cheek to call me a tart!
Owain go steal me a duct off an Evo, you must know of one somewhere
Posted 12th Sep 2011 at 21:02
Post #607
You cannot compare buying decent oil to polishing wires and spray painting the crumbs down the sides of your seats yellow to match your bodywork.
Mate of mine had an evo, sold it three days ago though so you're out of luck there I'm afraid. Else I'd have robbed it right off.
Posted 12th Sep 2011 at 21:19
cwspellowe
Post #608
He should have the details of who he sold it to. Go and rob it anyway.
Posted 12th Sep 2011 at 21:23
matt evans
Post #609
Owain, what sort of oil temps are you seeing on the road now, say driving normally?
honestly3k wrote:
owain wrote:
Posted 12th Sep 2011 at 22:07
cwspellowe
Post #610
Too cold from what he's been telling me. I don't get it though, isn't the cooler thermostatic? If so should it not just regulate it better as opposed to letting it run cold?
Posted 12th Sep 2011 at 22:43
Post #611
Laugh my ass off
Posted 12th Sep 2011 at 23:15
Post #612
It barely hits 50 on the gauge when driving hard, but I've got no undertray so that's the temperature in the sump when suffering windchill as well.
Certainly lower than I'd like, hence the cardboard bodge. The cooler doesn't kick in initially but as the stat is right up inside the engine it probably *is* easily 80 degrees plus in there, so gets routed off to the cooler where it hits the 13 degree air and gets over-cooled.
Should be good on track though, which is what it's meant for anyway.
Posted 13th Sep 2011 at 08:07
Post #613
i had a digital gauge made up to monitor temperatures after the oil cooler was put on. it rarely shows over 70 on the road even thrashing it around b-roads. thought i had a problem at first but it's fine
Posted 13th Sep 2011 at 10:30
lewisdmz
Post #614
cjm_harris wrote:
This does look sweeet, love the colour combo. The only thing I regret about having a black car is that you're stuck with silver wheels (imo).
Has this been weighed yet?
Posted 13th Sep 2011 at 12:11
Post #615
btw owain you want some s1 106 rallye vents.. they fit into the foglight ducts on our bumpers. got 'em on mine Smile
Posted 13th Sep 2011 at 12:38
Post #616
Nope, should probably get round to that.
But I've got some shitty cloth from eBay, what's wrong with that?
Posted 13th Sep 2011 at 13:00
Post #617
Nothing, think of the weight saving Smile
Posted 13th Sep 2011 at 13:33
Post #618
THANKYOU. Finally a man who understands.
Posted 13th Sep 2011 at 13:34
Post #619
what paint finish is on the wheels handsome man?
Posted 13th Sep 2011 at 13:46
davewagon
Post #620
You'll be wanting to get rid of the remaining side strips then ??
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Post #621
No need, I just paid £800 to have them filled with helium.
Posted 13th Sep 2011 at 13:52
Post #622
Oi fat blunt answer my question! Angry
Posted 13th Sep 2011 at 16:28
Post #623
Ha! I'm not even trying and yet I keep ignoring your posts, it's fantastic.
No idea. You'd need to ask Ash, bought them from him. Some kind of grey...?
Posted 13th Sep 2011 at 16:31
Post #624
Sometimes you're less than helpful,and others you are totally f*cking useless
This is one of the latter times Roll eyes
Posted 13th Sep 2011 at 18:11
Post #625
Same as mine by the look of it, Anthracite, metallic finishes cost extra though.
Posted 13th Sep 2011 at 18:14
