displaying posts 51 to 75 of 199
Pages (8): first .. 2 [3] 4 .. last
Author Subject: Chassis repair service £200 + VAT
Post #51
neil_gti6 wrote:
Is there any kits avalible mate?
Thanks
I can do you one, when do you need it by?
Posted 2nd Aug 2010 at 01:12
neil_gti6
Post #52
daveyboy wrote:
Thanks
Sooner rather than later if possible please mate?
Team diablo
Posted 2nd Aug 2010 at 01:18
Post #53
neil_gti6 wrote:
daveyboy wrote:
Thanks
I'll try and get one sorted early this week then buddy.
Posted 2nd Aug 2010 at 01:20
mechanical_repairs
Post #54
Anybody would think you weld for a living, looks great.
Carl
Posted 2nd Aug 2010 at 01:24
neil_gti6
Post #55
daveyboy wrote:
neil_gti6 wrote:
daveyboy wrote:
Thanks
Ideal cheers mate, when do you want payment?
Team diablo
Posted 2nd Aug 2010 at 01:34
Post #56
Carl
If the salesman thing falls through its always nice to have a skill to fall back on Smile
Cheers Carl
Posted 2nd Aug 2010 at 01:33
pete26
Post #57
PMd jim Wink cracked engine mount cradle for me Sad i require your services
Ph2 Black GTI6
Ph3 China GTI6
206 xsi manstone daily runner (GAY)
Ph1 Cherry Red GTI6
307 HDi 110
Posted 10th Jan 2011 at 11:17
jord294
Post #58
Carl
i agree. very professional repair
luckily i have no problems with my top mount (keeps fingers crossed Razz )
but if i ever need repair kit, you'll be the first person i'll call on
Posted 10th Jan 2011 at 01:49
Post #59
pete26 wrote:
Pmd Wink
Replied Smile
Posted 10th Jan 2011 at 13:32
pete26
Post #60
Jim how much are your DIY kits. And what does it include? cheers Pete
Ph2 Black GTI6
Ph3 China GTI6
Ph1 Cherry Red GTI6
307 HDi 110
Posted 10th Jan 2011 at 14:02
Post #61
£45 posted, you get everything you need, the two plates, the formed cup and the nut welded on. It needs careful lining up by marking the exact position of the existing hole BEFORE you cut the clearance hole. If you just drop the plate in the cup and then weld it in the chances are you wont be able to get the mount to line up witht he hole in the engine support arm. Its a simple job but needs some thought or else it can go badly. You need to take special care when moving fuel pipes away so you dont cause leaks and if you have A/C then care must be taken not to damage the pipes with heat or when you drill/grind the clearance hole for the welded nut to drop through.
Posted 10th Jan 2011 at 14:50
dragoon
Post #62
This lining up is only needed when the original cradle is cracked right?
In my case it isn't cracked but the nut went oval for some reason So I believe it's more a case of drilling out the original nut and dropping in your cradle? Or am I mistaken?
(going to attempt doing this myself tomorrow Roll eyes Unsure )
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 15th Jan 2011 at 02:28
Post #63
What I do is draw a crosshair mark intersecting the original hole AFTER sanding off all the paint and galvanise in the area to be welded. I run this line up both sides of the cup and the back. I then do the same thing on the new section bfore putting it into place. Once you have drilled out the clearance hole and dropped the plate in you have no way of lining it up except those marks, its all curves and rounded edges at the bottom ant the replacement bits are made by hand so there is no way I can garantee that they can be just put in and welded wherever they land. If you mark correctly though its a piece of cake.
Posted 16th Jan 2011 at 19:27
Post #64
Bump
Posted 25th Jan 2011 at 00:04
dragoon
Post #65
Another vouch for these sets!
Worked out just fine in the end, thanks mate Smile
Team Wheelwhore
Posted 25th Jan 2011 at 00:17
Post #66
I'll be needing one of these DIY kits in the next few weeks, do you have any stock?
Still £45 posted?
Posted 1st Feb 2011 at 02:36
Post #67
Still £45 posted?
Still the same price, PM me whenever you need one.Smile
Posted 1st Feb 2011 at 03:45
Post #68
Bump for this cracking good service... Shut up
Posted 16th Feb 2011 at 01:47
Post #69
Another one saved, this time a neat XSI, cheers for your custom Adam, hope it serves you well Smile
Posted 19th Feb 2011 at 19:33
pugjim
Post #70
How much for just the formed cup (without the hole or nut welded on) ?
Posted 8th Mar 2011 at 12:33
Post #71
£38.50
Posted 8th Mar 2011 at 14:05
Post #72
Bump
Posted 4th May 2011 at 15:08
daryl357
Post #73
How long are you going to be offering this service for? Mine needs doing but I could do with waiting a month or so as things are tight.
Posted 18th May 2011 at 23:18
Post #74
Indefinitely.
Posted 27th May 2011 at 02:23
daryl357
Post #75
Well I took Daveyboy up on his offer and I think the price is great considering the time and effort that goes into each repair.
My car feels much better to drive and the awful knocking noise is long gone Smile
Worth the drive and I would not hesitate to recommend his services.
Posted 5th Jun 2011 at 04:38
