displaying posts 1 to 25 of 199
Pages (8): [1] 2 3 .. last
Author Subject: Chassis repair service £200 + VAT
A common problem as most of you will already know is the excessive movement in the top engine mount. Aside from causing unpleasant driveline shunt when stop-start driving the constant back and forth action tends to fatigue and crack the mount cup on the drivers side chassis leg. This usually makes itself known by a creak or a clunk as you come on and off the throttle. Chocking up your engine mount using one of the kits for sale on the forum or fabricating your own will improve the driving experience rewarding you with a smoother gear change as you will get less torque reaction from the engine, and you may avoid a chassis crack.
For those less fortunate who have had a chassis mount failure however I offer a permanent repair service that is garanteed not to fail.
Here are some pics of the proceedure, I also install some mount chocks which firmly grip the buffers on the engine mount preventing further excessive movement.
An example of a badly repaired chassis mount (The welded repair patch came away with a firm blow from a hammer and chisel)...
Here is the repair piece I prefer, 3mm thick mild steel, with a hot formed curved edge, which adds strength with the added benefit that it sits flat to the old chassis cup further adding support.
A hole is drilled in the correct positon using a template, and a nut is fully welded in place to anchor the stud on the bottom of the mount.
It gets a coat of etch primer before welding to help prevent corrosion later on.
It then gets welded in place using a suitably powerful MIG welder to garantee good penetration...
Lastly, the engine mount chocks go on. You get one either side and afterwards a lick of paint but the camera ran out of batteries before the job was completed, but you get the idea.
The job is a while you wait service, it takes two hours roughly and you are welcome to stay and supervise or there is a nice pub five minutes walk down the street where you can refresh yourself while I take care of the hard work Wink
For this service I charge £200 + VAT.
Please note, I no longer supply repair kits, it's a fully fitted service or nothing, sorry for any inconvenience.
PM me if you need it done, thanks for looking Cool
Posted 7th Apr 2015 at 12:18
will130787
I had this done on my Astor and its highly recommended! Jim did a great job of it and I stayed to watch how he does it, mine looked exactly the same as the above pictures and the chocks made the world of difference, was like a different car!
Free bump, top work Thumbs up
p.s. think the Bianca needs some welding treatment Sad
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 29th Apr 2010 at 15:00
lotek
i had a cheapo job done locally that went wrong,
so had it rectified by daveyboy.
the time and care he puts in is awesome, and the craftsman ship is 2nd to none.
would recommend to Anyone Thumbs up
Posted 29th Apr 2010 at 15:01
Thanks guys for the free bumps and positive feedback Smile
Posted 29th Apr 2010 at 16:13
MCH_GTi6
formerly mch
why the hell are you so far away Sad
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 29th Apr 2010 at 16:53
Cornwall is'nt that far away Wink
Posted 29th Apr 2010 at 17:10
neil_gti6
Fancy coming down then... because you can do mine at the same timeRazz
Team diablo
Posted 29th Apr 2010 at 17:28
Not a job I fancy doing on site really, sorry guys Razz
Posted 29th Apr 2010 at 17:48
rallyestyle
That looks an awesome fix Thumbs up If mine ever goes then i will be knocking at your door Thumbs up
Just Drive It
Posted 29th Apr 2010 at 21:39
allesclar
hmmm how far away are you from rich_w?
Team allesclar ®
Posted 29th Apr 2010 at 21:44
puglover Banned!
ill be coming down when i can Smile
Posted 29th Apr 2010 at 22:00
neil_gti6
Would you sell the fabricated part you made so i can get some 1 closer to home to fit it or is that not an option? Dunno
Team diablo
Posted 30th Apr 2010 at 00:49
hanpug25
How much does it raise the mount by? Gotta be 5-8mm?
Passat B5.5 TDi estate (174bhp, 260 lbs/ft)
Posted 30th Apr 2010 at 01:59
The thickness of the steel plate is 3mm, and thats all it raises it by Smile
Posted 30th Apr 2010 at 03:23
20-25 minutes away buddy.
Posted 30th Apr 2010 at 03:25
I could knock up a few plates, drill and weld on the captive nut and the two packer pieces yes, How does £45 per kit each plus postage sound? You will want a reasonable sized machine to weld them in properly, I'd say something like a 180 would be good. Don't be afraid of melting through as the material is very thick around that part of the car.
Posted 30th Apr 2010 at 03:29
jimmy_boy
Brilliant work.
My brother and I did a similar thing to mine about 6 years ago and it's still perfect.
Basically how Peugeot should have had them leave the factory!
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 30th Apr 2010 at 05:10
jimmy_boy wrote:
Brilliant work.
Cheers Jimmy, the engine chock mod was the first thing I tackled when I got the Rallye, that set me off on a very sippery slope! LOL Ninja
Posted 30th Apr 2010 at 05:28
Bump Smile
Posted 6th May 2010 at 05:05
Weekend bumpage Cool
Posted 28th May 2010 at 22:33
dan@msx
have you made any of these to ship out?
Posted 28th May 2010 at 22:39
Not as yet, at £40 for a cup plus packers nobody has wanted any so far Wink
Posted 28th May 2010 at 22:41
gti6-ginge
my mate needs 1 of these kits ill get him 2 pm you
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 29th May 2010 at 04:23
Ok bud, I'll knock up a few extra sets this morning then. Smile
Posted 29th May 2010 at 13:06
Another one fixed this morning, and I've formed up some extra chassis cups and packer plates for anyone that fancies tackling this job themselves.
Price of the formed cup with a welded nut underneath, plus the two packer plates is £42.50 posted.
I'll put up some pictures of the parts later if anyone is interested.
Posted 29th May 2010 at 19:19
