displaying posts 226 to 250 of 375
Pages (15): first .. 9 [10] 11 .. last
Author Subject: Tea Boy's 6
tea boy
Post #226
Welcome back, darling xxx
Hello, sugar. X
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 21st May 2014 at 07:57
tea boy
Post #227
Well, I got some new hose for the screenwashers and that is now sorted.
I also got some new clips for the doorcards as they have been rattling.
When I had the driver's doorcard off I noticed that one of the pop rivets which hold the window regulator on had sheared off, so I fixed that with an m6 nut & bolt.
Whilst the door was in bits I also thought it would be an opportune time to fit the 3 phase rub strips which I have had for about three years.
Now that looks crap, so I replaced the one on the wing and the rear quarter too.
I still have the other side to do.
A job for tomorrow, assuming the sun is out.
I still need to do something about the bonnet sound pad, does anyone have a picture of a phase three one installed that you could post up?
Make tea, not war.
Posted 25th May 2014 at 22:02
pug_306
Post #228
Looking good, maybe you should sort your side badges they are back to front :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 29th May 2014 at 08:40
tea boy
Post #229
pug_306 wrote:
Looking good, maybe you should sort your back to front badges too :-)
What should they be like?
Some scrote has nicked the badge off the back so I need to get some more.
Make tea, not war.
Posted 25th May 2014 at 22:39
walker_texasranger
Post #230
It's a while since I've seen this, so just re-read it again Big grin still one of my favourite project threads!
I think Pug_306 is referring to your near side badges where the 6 is sat in front of the GTi badge' needs swapping round Wink
Keep up the good work Tea!
Hilux InvincibleX daily
306 No.13 Doh
Posted 26th May 2014 at 02:56
mik
Post #231
Agree with what has been said above - this is one of the great project threads and inspired me to do mine.
WRT the sound deadening under the bonnet, mine was tatty and full of salt so I deleted it with no adverse effects. As mine's a Rallye it went with the lightweight ethos.
Cherry Rallye SOLD
Posted 26th May 2014 at 11:17
tea boy
Post #232
Thanks for the positive thoughts chaps.
I stuck the other side rub strips on, badges are going to stay where they are, I like the symmetry.
Could do with some new ones though, all the silver has worn off.
I am going out for a drive in it now.
Make tea, not war.
Posted 26th May 2014 at 14:29
sparkie1984
Post #233
Fantastic thread mate.
Wish I had the ability to do things like this.
built on: 15 January 1999 - that's a Friday afternoon car..eek!!! ;o).........sadly missed
Posted 29th May 2014 at 08:30
gilesy
Post #234
Epic thread bump, I saw a white Porsche in London today with the reg 7EA and thought it might be you
Posted 3rd Apr 2015 at 21:31
Post #235
quite unlikely, he hasn't finished the oil tank yet Razz
Posted 3rd Apr 2015 at 22:00
Post #236
http://retrorides.proboards.com/thread/96138/1986-porsche-911?page=27
Posted 3rd Apr 2015 at 22:15
Post #237
He is a complete nutter but in a very good way
Posted 4th Apr 2015 at 12:14
gilesy
Post #238
Posted 7th Apr 2015 at 20:00
Post #239
I've driven one of those. Was alright.
Had 7k on the clock and the interior felt worn already. Hmm.
Posted 7th Apr 2015 at 20:14
tea boy
Post #240
Hello chaps, I still have my 6.
It is due a bit of TLC to be honest, I got an advisory at the last MOT on brake pipes, a bit of play on the steering rack and a stiff load valve.
Also, I have a snapped front spring which happened whilst Mrs Tea was taking the nipper to school.
In typical Tea Boy style I have decided that the only course of action is a full suspension re build.
To that end I have been collecting a few bits.
I have got;
A Xsara VTS axle with 21mm bars which I will rebuild and fit
A new load valve.
Bilstein B4s
Xsara p1 steering rack (new tie rods, ends gators etc)
BBM solid beam mounts.
and loads of ather small bits and pieces which I can't remember, and loads more on order from Peugeot.
As Welshy says, I am still fannying about with the oil tank for my Porsche, so I haven't started on it yet.
I do need to get the torsion bars out of the beam soon so I can get them and the Xsara front springs off to the powder coaters, then I can at least get the thing back on the road.
I'll keep you informed when I do get started
Make tea, not war.
Posted 9th May 2015 at 00:23
Post #241
Will look again in 2018
Posted 9th May 2015 at 13:51
tea boy
Post #242
Yeah mate, you can't rush a good job.Big grin
Make tea, not war.
Posted 9th May 2015 at 14:17
tea boy
Post #243
Well, I have spent literally hours battering hell out of my slide hammer trying to remove the torsion bars.
My arms are hanging off but sadly the T bars are not.
Make tea, not war.
Posted 10th May 2015 at 20:52
Post #244
heat and a sledge hammer Smile
Don't know the dimension sorry, but I would try 322mm, standard is 330.
Posted 10th May 2015 at 20:53
tea boy
Post #245
Which bit do I heat, and where do I hit?
Make tea, not war.
Posted 10th May 2015 at 22:48
Post #246
Everything
Posted 10th May 2015 at 23:01
tea boy
Post #247
Everything
I can't hit feck all at the moment, by arms are knackered.
Make tea, not war.
Posted 10th May 2015 at 23:18
Puggitt
Post #248
I just used a socket and bolt as a puller to dislodge mine the either lather the other end with never cease, and slide hammer or bash it through or remove the arm and drift it back though the inside.
Posted 11th May 2015 at 03:16
tea boy
Post #249
I keep spraying it with penetrating oil whilst my arms recover for the next round...
Make tea, not war.
Posted 12th May 2015 at 23:30
heliosphan
Post #250
Apparently acetone and ATF (in a 50/50 mix IIRC) makes a great penetrating/releasing fluid. Mix it up and paint it on or get some in a Windowlene style bottle and spray it. May not keep well in a plastic bottle though! I'm going to make some up at some point, just to try it out.
Posted 13th May 2015 at 00:04
