displaying posts 151 to 175 of 549
Pages (22): first .. 6 [7] 8 .. last
Author Subject: andys reborn 6
Post #151
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 13th Sep 2011 at 21:45
Post #152
Didn't use ZX arms in the rear beam did you?
That's what I have and there's no toe-in on the back, makes the car rather lively...
Posted 13th Sep 2011 at 22:01
Post #153
It is very very very lively but now I've drove to work after getting in bed it feels a lot less lively than it did before after been aligned bur saying that it does get too lively after 70Mph
Posted 14th Sep 2011 at 04:01
Post #154
Why is your front castor angle so low?
Are your top mounts the right way around?
Posted 14th Sep 2011 at 13:52
Post #155
dont find mine nervous at warp speed tbh Ninja
Posted 14th Sep 2011 at 15:04
Post #156
Mine's a bit nervous over about 70-80 leptons on bumpy b-roads tbh, constantly correcting the car, get's a bit tiring sometimes...
Camber thrust on mine probably doesn't help though, nor the high car, soft springs and lots of travel changing the toe all the time...
Posted 14th Sep 2011 at 15:08
Post #157
maybe I'm used to it from 205's LOL
been driving without any form of rear anti roll unknowingly for some time too Laugh my ass off
Posted 14th Sep 2011 at 15:12
Post #158
Can the top mounts be fitted the wrong way without it standing out in your face as been wrong?
It's the rear what I'm worried about at the moment, and seen as it's going to be highboost soon I've gotta get it right.
Has anybody got any suggestions? Should I fit anew front subframe to get the castor equal?
I havnt a clue why the back end has 0 toe.
Posted 14th Sep 2011 at 17:56
Post #159
sounds like a zx beam if theres no rear toe, as for top mounts what have you got on? pas and non pas are different
Posted 14th Sep 2011 at 18:58
Post #160
I ordered them using my chassis number and they was exactly the same as the ones I removed.
Posted 14th Sep 2011 at 19:05
Post #161
How can I tell the difference between the zX beam and the gti6 one eg, are there any njmbers anywhere?
Is it the trailing arms that are different?
Could it only be the trailing Arms or the stub axles?
Posted 14th Sep 2011 at 19:07
Post #162
they look identical. just the machining of the arms that set the angles.
wouldnt worry about it, its a good thing imo!
not sure what the ft castor is meant to be, was it the same before? pic may help
Posted 14th Sep 2011 at 19:11
Post #163
It feels good for very tight bends up to 60 but it's too Lary after that.
I don't think I could get the benefits of the high boost with it like this, the back end digs in and grips way too much and this
Makes it feel like over steer in a way, it just reacts far too fast
Posted 14th Sep 2011 at 19:21
Post #164
The round mounting bit should be further to the back of the strut hole, rather than towards the front.
Posted 14th Sep 2011 at 19:57
Post #165
Just over 2' for a non-power steering model...
Posted 14th Sep 2011 at 19:58
Post #166
It says the tolerances on the printout if you can make them out.
Posted 15th Sep 2011 at 04:42
Post #167
On the printout it says It's between 3.10 and 3.50 degree.
It's hard to make it out on the pic
Posted 15th Sep 2011 at 04:50
Post #168
Yeah, that's about right for a PAS model.
Right, top mounts go this way around and give just over 2' of castor for a non-PAS model:
And this way around for 3.5 degrees of castor on PAS models:
Posted 15th Sep 2011 at 13:35
Post #169
looks like the right ones then
bent wishbones? Hmm
Posted 15th Sep 2011 at 14:57
Post #170
Wishbones are new, could I have fitted them to the wrong sides?
I'll be home soon so I can check the top mounts are the right way as I'm not sure if I have a pic on here of them
Posted 15th Sep 2011 at 15:24
Post #171
Nah, they're not sided anyway.
Posted 15th Sep 2011 at 15:27
Post #172
thats a pic of your car LOL
Posted 15th Sep 2011 at 16:26
Post #173
Yes your right lol that is a pic, I didn't see it on the shitty phone earlier.
So the Tip mounts are the right way, I kinda wanted them too be wrOng so It would be sussed then but nope.
It wasn't like this Before I did the work and it handled better before with a fuxked beam and beam mounts.
I'm getting f*cked off with it now, I do everything by the book, I havnt spared nothing and it's not right, and I havnt a clue why as can't really go wrong with the front suspension.
I'm f*cked off to the point where I wanna sell up now.
Posted 15th Sep 2011 at 16:54
Post #174
Hmm i'd check the position of the damper piston compared to the front/rear bolt hole and compare to another car.
just a thought, how level is the ride height? nose down at all?
Posted 15th Sep 2011 at 17:02
Post #175
Ride height looks pretty level, it seemed slightly lower at the back at first, well the arch gap anyway, but I had a full tank of fuel and it's empty now
But now it looks level
Sorry for been thick but why do you mean mate?
Posted 15th Sep 2011 at 17:36
