displaying posts 326 to 350 of 549
Pages (22): first .. 13 [14] 15 .. last
Author Subject: andys reborn 6
Post #326
stan_306gti6 wrote:
and they suddenly decide to stop producing it...Dry
they would have stopped making them 13 years ago Stan, just stock has run out now LOL
Posted 20th Mar 2012 at 19:37
Post #327
Well yes, I understand that. LOL
What I meant was, they should have carried on making some more so the stock lasted a little bit longer. Or is that me just being selfish? Laugh
Posted 21st Mar 2012 at 20:54
atterz
Post #328
Nope, Afaik Mercedes still stock all of their car parts regardless of age, not sure how true this is but somthing ive heard in the past.
owain wrote:
Posted 21st Mar 2012 at 21:01
Post #329
Well I went to start the car before last weekend and the battery was dead so after a 2 day charge it was still dead Sad that's where the 4 year warranty came in, so off to halfords for a new one Smile
She sounded lovely again, then I had a panic when the rotrex oil was spilling out of the breather oil cap on the reservoir, turns out I've overfilled it, it should be topped up with the engine running and the revs raised slightly, then it should go between the min and max apparently.
So after finding this information out I restarted her the next day, she sounded lovely till she got warm then sounded s**t.
I noticed the widband gauge had froze at 14.7.
Seems my lambda is shagged now LOL I'm not having much luck really but the seller efi parts has offered me a new sensor for cost price as its not covered under warranty.
So after fixing the boost pipes, then the oil cooler then the battery I now need a new lambda.
As I run a dta ecu I only have the wideband lambda sensor so any information i see on the gauge is what the ecu is seeing aswell.
I'm pretty sure I'm going to have no issues from now on.
I'm also thinking of a custom intercooler and rad set up.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 31st Mar 2012 at 11:58
Post #330
thats because they have a massive surplus, they don't still make bits for 70's mercs unless it was a part used on a late 90's car...
and that's pushing it with the recent European legislation, ten years and that's it.
Posted 31st Mar 2012 at 12:20
Post #331
Well here's a few pics Jamma style LOL
Bosch 044 external pump fitted:
To a swirl pot from rich w, now I must say it is excellent quality stainless steel and the welding is to highest standards possible, the only thing I could complain about is the lack of beads on the outlets but it doesn't and won't leak so there not totally necessary, it would be better with them though even just for peace of mind:
Awesome quality metal and welding on this I'm really happy with, the bosch pump is a noisy thing but it doesn't bother me.
One thing i do need to do is change the jubilee clips and mounting nuts/bolts to stainless ones and get stainless braided hose and use the fancy anodised blue and red connectors (I've forgot what they're called).
Here's some pics of the power flow exhaust, why the boxes have signs of rust when it's stainless I don't know and the tailpipe needs metal polishing all the time but it sounds nice:
My manifold also looks rusty:
Is it the extra heat from all the extra power it's now running?
New digital boost gauge and wideband lambda gauge from aem fitted:
The sensor for the boost gauge is fitted here in the manifold, it's the big one you can see plumbed into the end of the manifold out of the 3
3 bar Cosworth map sensor fitted:
8 rib belt and pulley conversion:
A new 8 rib alternator pulley and p/s pulley converter had to be engineered for this along with new pulleys and tensioners eg
Lower strut brace fitted, looks great under here with the fresh powder coated subframe, wishbones, roll bar eg :
A few pics of the engine bay, I keep finding loads of bits to paint/powder coat and freshen up yet:
I'm going to change this reducer to a black viper one as I think they're excellent quality, the elbow on the end of the throttle body needs extending to be able to use them mighty mikalors here, which will get done at a later date, besides doing a excellent job of clamping I also think they look much better athstetically than the normal s**tty worm drive jubilee clips
Bailey internal blow off/dump valve:
You may notice from the pics above that the outlet/pipe from the rad to the heat exchanger is not there that's because this is a different rad, the outlet is now here:
It then passes over the oil cooler thermostatic plate into the heat exchanger.
It had to be done for fit net of the bigger charger and it's a great idea but it's slightly thinner core than before so I'm not sure how it's going to do under hard driving eg yet but I'm thinking of going down the custom rad and cooler route of its affordable.
Nice shiny air scoop and manifold heat shield:
Shiny top brace mounts:
I've got to start another reply I'm scared I'm going lose this LOL
Posted 31st Mar 2012 at 19:09
Post #332
Simply awesome mate Thumbs up
Posted 31st Mar 2012 at 19:32
davedgti6
Post #333
Looks spot on, can the pipes coming off the brake servo pump be changed to newer shiner ones? Love the carbon fibre coil-pack cover and the new heat shield Thumbs up
Posted 31st Mar 2012 at 19:38
Post #334
Now for the oil coolers and intercooler:
Note the milk crate, that's cos I'm a short arse.
There is only space on the intercooler to use normal worm drives there due to the welded bead and the space between this and the intercooler itself
Carbon fibre vinyl wrapped petrol cap covers
What are people's oppinion on fitting this fire extinguisher here:
A couple of bad bits:
Chrome plated brackets from a s**thole of a place with useless twats running it in castelford rusty already:
Rusty powder coated brake calipers, had 7 months use from them, 2 month before it started:
Im not really fussed about the gearbox plate been rusty as I've got a very low mileage one waiting to be fitted along with a qaiffe LSD and a xsara steering rack
I'm also after a set of 330mm brembo brakes from the megane, I think I will save for these from new.
Here's how she looks today:
Yep on stands again Smile
Note my half finished drive and wall, has anybody noticed I take a fair while finishing things I start? LOL
Posted 31st Mar 2012 at 19:52
Post #335
Yes I'm going to get this done, maybe stainless braided ones?? I also need to get the bracket at the back which holds the heat shield and pipes as its looking rusty along with the engine lift points, strut top mount cups and a couple of other bits
and bobs.
Thanks for comments folk I'll be updating with the super duper high boost engine build pics soon.
Posted 31st Mar 2012 at 19:55
Post #336
I've dropped a bollock, I had the fuel rail zinc plated and I've etch primed and normal primed it:
And when I paint i don't do it sparingly LOL
But I've now decided after all that work, I'm going to chop the 3 welded on threads off and have it smooth as they're not used anymore and it will look better smooth
but seen as I used a full can of primer on it LOL I'll have to go but another can!
Posted 31st Mar 2012 at 20:19
Post #337
I need a better looking elbow for the catch tank and the throttle cable bracket on the t/b needs painting
Brown plug isn't used with the dta I can't remember what it's for but I presume it sent the temp to the fan relay box that then turned the fans on, the dta now tells the fans to go on and the old fan relay triangle plastic box thing has gone.
Posted 31st Mar 2012 at 20:25
Post #338
have seen many extinguishers in competition cars fitted there, make sure they don't interfere with the seat though, comp cars have fixed seats.
Posted 31st Mar 2012 at 20:31
Post #339
Will it be secure enough with just the 1 strap bracket holding it?
Posted 31st Mar 2012 at 20:32
Post #340
you can get ones with a metal over centre catch.
Posted 31st Mar 2012 at 20:42
Post #341
Yeah it's just velcro, it's for a hgv but they are less likely to roll a few times if crashed.
Would I get a metal catch bracket to fit this extinguisher easy enough?
Posted 31st Mar 2012 at 20:46
Post #342
Wtf all the pics have muddled up and some have gone, It took ages to write Up aswell Sad
Posted 31st Mar 2012 at 23:05
Post #343
Watch out with the Mikalors bud, they are overkill and can actually crush the thin ally boost pipes very easily if overdone. Loving the attention to detail though.
Posted 31st Mar 2012 at 23:22
Post #344
im confused, it looks ok on the laptop but last night on the phone it was all muddled up, maybe it was just me that was muddled up, i guess ill never knowLOL
Posted 1st Apr 2012 at 08:52
Post #345
Looks fine on both laptop and phone to me bud. Yes
Posted 1st Apr 2012 at 09:17
Post #346
Does to me today LOL I don't know what's going on
Posted 1st Apr 2012 at 09:33
Post #347
ok, heres the pics rich took when he was buidling a engine for me.
its got wossner 8:0:1 pistons,
sanez rods which was a fair bit dearer than the pec ones,
bearings are all ACL lead copper heavy duty.
heres the oil pump been refurbed and rebuilt:
Posted 1st Apr 2012 at 16:06
Post #348
the bumper found its way back on today:
chopped the lugs off the fuel rail, it would of been so much better doing this before i primered it, ive got to smooth out the lower pits using a few coats of filler primer and sanding:
fir extinguisher would have to go here if full seat movement is to be kept:
it does feel sturdy enough with just the 1 strap but a steel strap would be much better.
Posted 1st Apr 2012 at 16:18
king of the hill
Post #349
quality work mate great patience shown with this
DON!T BUY IT---EARN IT
Posted 21st Apr 2012 at 22:54
Post #350
Thanks, maybe I've been a bit too patient at times LOL
Posted 21st Apr 2012 at 22:59
