Matt
| Author | Subject: PhillipM PTFE Gaskets Group Buy |
matt.gti6
Regular Location: Warwickshire Registered: 03 Aug 2008 Posts: 478 Status: Offline |
Post #226
Hey Phil, no sign of my gasket...has it been sent out yet?Cheers Matt |
bas oosterhout
Newbie Location: Amsterdam Registered: 27 Apr 2008 Posts: 18 Status: Offline |
Post #227
Hi Phillip,Good to see you finally have the gaskets. Can you send pm for paying the remaining money? ________________________________________ White 1988 LHD 205 GTi5 LSRXsara RFS engine (fully rebuild) and Xsara 5 speed gearbox | Quaife LSD | Lynx SC kit| Lynx flywheel and pulley | Mocal oil cooler | Mocal oil cooler thermostat | Spal fan | RunnCool radiator | Constella Gear Linkage | Spax RSX 810 front dampers | Spax RSX 810 rear dampers | Home made rollcage (sparco copy) | Home made uniball arms/309 ARB/309 driveshafts | 306 24mm rear ARB | Megane Brembo brake calipers | Ap racing discs on bells | Xsara Brake Servo | Partner 23,8 MC | 4 x C5 alloys | 4 x Teamdynamics | 4 x Toyo 888, 4 x Michelin slicks | Polycarbonate bonnet & aerocatch bonnet pins | Green windows | Sparco Pro 2000 seats | Sabelt Harnass | 309 16V speedometer | Car Guardian Recorder | CXI B3 Comfortblinkmodul | |
Post #228
matt.gti6 wrote: Hey Phil, no sign of my gasket...has it been sent out yet? Cheers Matt There's a couple gone out at the same time that haven't turned up yet, I'm assuming it's because the post offices around here were shut for a few days but let me know if they don't arrive next week. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
bas oosterhout
Post #229
Would we need PTFE washers? If so can you supply those?________________________________________ White 1988 LHD 205 GTi5 LSRXsara RFS engine (fully rebuild) and Xsara 5 speed gearbox | Quaife LSD | Lynx SC kit| Lynx flywheel and pulley | Mocal oil cooler | Mocal oil cooler thermostat | Spal fan | RunnCool radiator | Constella Gear Linkage | Spax RSX 810 front dampers | Spax RSX 810 rear dampers | Home made rollcage (sparco copy) | Home made uniball arms/309 ARB/309 driveshafts | 306 24mm rear ARB | Megane Brembo brake calipers | Ap racing discs on bells | Xsara Brake Servo | Partner 23,8 MC | 4 x C5 alloys | 4 x Teamdynamics | 4 x Toyo 888, 4 x Michelin slicks | Polycarbonate bonnet & aerocatch bonnet pins | Green windows | Sparco Pro 2000 seats | Sabelt Harnass | 309 16V speedometer | Car Guardian Recorder | CXI B3 Comfortblinkmodul | |
Post #230
No, your normal bolts and washers will do, although if you want to reduce heat transfer through the bolts you can swap to stainless steel ones.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
beez_neez_gt
Post #231
Hi Phillip,Received mine this morning, thanks a lot We all know they are good quality and i totally agree, good stuff. What is it made out of, it feels a little like rubber ? Cheers.. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #232
Errm, PTFE? ![]() It's reinforced with carbon and a little mica, hence the colour and texture. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
eddy_gti6
Post #233
could you make these for any inlet on any car?________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
turboblack
Junior User Location: San Lorenzo Isontino Registered: 04 Mar 2010 Posts: 84 Status: Offline |
Post #234
Hi Phil! Can you PM me you paypal adress for pay one of this gaskets?Thanks ________________________________________ 306cab 2.0 16v:Wossner 12:1 45mm Jenvey Piper 285H 6 Gearbox + Quaife LSD 406 Brembo D2 Suspension E-tech Strut Brace Emerald K6 Ecu |
Paddy Power Turbo
Banned!Location: galway/ireland Registered: 24 Feb 2009 Posts: 628 Status: Offline |
Post #235
mr swampy does some nice stainless steel bolts n nuts id have 1 off u only i just bought 1 ov ur old 1s from turbo wagon ![]() ________________________________________ TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200 dyno print out : 185.4 at the flywheel modern warfare 2 |
turboblack
Post #236
Bump for philipm PM for paypal adress for pay one of this gaskets!________________________________________ 306cab 2.0 16v:Wossner 12:1 45mm Jenvey Piper 285H 6 Gearbox + Quaife LSD 406 Brembo D2 Suspension E-tech Strut Brace Emerald K6 Ecu |
Post #237
Afraid I don't have any left from the group buy, although there's been some interest so there might be enough to get another going:1. Turboblack 2. Ballardpaul ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
ant_kernow
Senior User Location: newquay Registered: 23 Oct 2009 Posts: 949 Status: Offline |
Post #238
1. Turboblack 2. Ballardpaul 3. ant_kernow ________________________________________ team umpalumpa. |
diablowgti6
Newbie Location: coatbridge Registered: 19 Aug 2010 Posts: 17 Status: Offline |
Post #239
1. Turboblack2. Ballardpaul 3. ant_kernow 4. Diablowgti6 ________________________________________ oh s*it built on a thursdayMy other cars an 8v turbo |
tsd167
Junior User Location: Spalding Registered: 07 Aug 2010 Posts: 73 Status: Offline |
Post #240
1. Turboblack2. Ballardpaul 3. ant_kernow 4. Diablowgti6 5. tsd167 |
k22wes
Senior User Location: somerset Registered: 23 Apr 2008 Posts: 538 Status: Offline |
Post #241
1. Turboblack2. Ballardpaul 3. ant_kernow 4. Diablowgti6 5. tsd167 6. k22wes (depending on how long they take) ________________________________________ 205 gti6 white phase 2. |
ballardpaul
Seasoned Pro Location: Croydon Registered: 22 Jul 2008 Posts: 4,135 Status: Offline |
Post #242
Sorry boys bought one second hand. 1. Turboblack 2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 ________________________________________ Phase 2 Blaze GTi 6 (Standard) SoldPhase 3 Supercharged China GTi 6 (249.8 BHP) Sold Phase 3 Supercharged Diablo GTi 6 (443 BHP)Sold Nissan 350Z (300 BHP) |
lewisdmz
Senior User Location: plymouth Registered: 25 Jul 2009 Posts: 504 Status: Offline |
Post #243
1. Turboblack2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 6. lewisdmz I might be out of this actually, didn't realise how much work was involved in fitting it. |
ant_kernow
Post #244
lewisdmz wrote: 1. Turboblack 2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 6. lewisdmz I might be out of this actually, didn't realise how much work was involved in fitting it. what do you mean? o/t seen as your in plym, you keen for a meet? ________________________________________ team umpalumpa. |
lewisdmz
Post #245
ant_kernow wrote: lewisdmz wrote: 1. Turboblack 2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 6. lewisdmz I might be out of this actually, didn't realise how much work was involved in fitting it. what do you mean? o/t seen as your in plym, you keen for a meet? In my mechanical naivity i thought it would just be a case of undoing a few bolts, lifting the inlet manifold off and replacing. Now i've had a look you need to remove all sorts of shit, guaranteed if i tried this my car would not work. There's a pug306 meet at Cheddar Gorge on the 20th which i might pop up to... |
Post #246
1. Turboblack2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 6. lewisdmz 7. Prism7guy ________________________________________ Goldie the track car. |
ant_kernow
Post #247
quote: i did see that. i may look into it. ill pm you if i do quote: There's a pug306 meet at Cheddar Gorge on the 20th which i might pop up to... ![]() ________________________________________ team umpalumpa. |
eddy_gti6
Post #248
Am in for another one after selling mine to ballardpaul ![]() 1. Turboblack 2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 6. lewisdmz 7. Prism7guy 8. Eddy_gti6 ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #249
1. Turboblack2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 6. lewisdmz 7. Prism7guy 8. Eddy_gti6 9. קדי לבנר קדי לבנר .10 ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
davewagon
Senior User Location: Corby / Northampton Registered: 21 Feb 2007 Posts: 889 Status: Offline |
Post #250
1. Turboblack2. K22wes 3. ant_kernow 4. Diablowgti6 5. tsd167 6. lewisdmz 7. Prism7guy 8. Eddy_gti6 9. קדי לבנר קדי לבנר .10 11. Davewagon Put me down for one of these too please. Could you PM me with payment details. Thanks, Dave ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
