displaying posts 51 to 75 of 89
Pages (4): first .. 2 [3] 4
Author Subject: supercharging gti6
mabgti
NV motors
Post #51
You wanna get it fully hardpiped.. i had to use a special 3">2.5" cast reducer for mine. Its the difference in vacuum at manifold and charger that does itYes
I use only silicone couplers with alloy bends.. make the world of difference to throttle responseYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 13th Mar 2010 at 01:14
birk
Post #52
2nd that mabs, noticed a big difference when i hard piped mine the other month.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 13th Mar 2010 at 01:16
allesclar
Post #53
is the heat wrap any good on the boost pipe mabz?
i think your coolant cap is coming off. Wink
Team allesclar ®
Posted 13th Mar 2010 at 01:18
mabgti
NV motors
Post #54
i noticed the alloypipe heat up at pod queuein last year, so thought heat wrap wouldnt do it any harm.. ill log the inlet temps when i get the DTA fitted..
rad cap is fine.. nissens rad hence not the best fit.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 14th Mar 2010 at 01:41
drumfinpete
Post #55
will do guys thanks again, do you have any suppliers for the pipe and what size is the throttle intake i dont want to go back to the tuners again, to measure it,
p millar
Posted 14th Mar 2010 at 03:08
drumfinpete
Post #56
hi guys, still having no luck with this car, went and lifted it today after remapping it will only start when it wants to, wont idle, runs like its on 2 cylinders dont think the tuners have a clue they have the new chip installed but its doing exactly what it did when i left it in he says diagonistic plug is broken and thinks it is another coil pack away i already got him one last week he blames the iridium plugs so now it has the standard plugs, it started first time today but wouldnt take throttle for 30 seconds ran lumpy farts and bangs then stops tried it again when i got it home wont start at all, any ideas
p millar
Posted 20th Mar 2010 at 03:14
allanallen
Post #57
What exactlys on the new chip? A base map or something they've written?
Facebook
Posted 20th Mar 2010 at 04:27
drumfinpete
Post #58
it is a new base programe written by chip wizard in the uk one he has used before i have left it with a local mechanic to check the timing as i changed the belt and am worried that it may be off slightly on one of the cams, either that or a broken wire somewhere. thats my theory but as you know thats not worth much. getting really fed up with it now thinking of packing it all in and breaking it.
p millar
Posted 30th Mar 2010 at 22:34
greenbelt
Post #59
Keep the faith mate Yes
I wanted to torch mine a couple of times when I was fitting my Rich_W kit last year. It will be worth it when you finally get it sorted.
Also I had problems with Iridium plugs as the idle wasn't great and it was running way too hot. Try the NGK ones instead.
Check and double check all your wiring too. It's not always easy to see if there are breaks.
Other than that, good luck Smile
Standard Black 6
Black HBSC6 Smoke
Posted 30th Mar 2010 at 22:50
rich_w
Post #60
You need to find out more about what software they've fitted to the ECU.
Chipwizard's won't send out files, or base maps - the only way he will do anything to a car is if it's sat in his dyno cell.
I'm not sure, but maybe somehow you've got hold of one of my base files written by Chipwizards.
If this is the case it would explain the issues you are having, it's written for a completely different set-up.
Unless you find a mechanical fault, I was just go and get a bespoke re-map from Wayne.
Smile
Contact Details:
07732 822546
Posted 30th Mar 2010 at 23:07
Post #61
Would it not be an idea to weld a downturned 90 degree bend right onto the end of the inlet? That would save on another joint.
Posted 30th Mar 2010 at 23:27
drumfinpete
Post #62
the car was not running right before i took it to them always sounded like it was on 2 cylinders was ok before i started the mods, now i have got laid off so no cash for any thing, as far as i know he sent the chip details by internet to waynr and he sent back a new base map but the car is running worse than before if anything. i think it is something simple and not the mapping ok it will still need set up once its running on all cylinders
p millar
Posted 2nd Apr 2010 at 00:48
maxwell
Post #63
just heard about this conversion from a mate! sounds like a good wee project considering the 306s you normally see knocking about ballymena lol
will have to keep an eye on it!
Posted 13th Apr 2010 at 05:38
drumfinpete
Post #64
hi finally got the car running jump started it at 60 mph as a last resort and it fired up it is now starting on the button and running and idling pretty good but i have no power less than standard its also sucking in the pipe from the charger to the intercooler on throttle and always shows negative on the boost gauge. tested the guage and is working fine thought i had charger plumed in wrong way for a second. removed the feed pipe to the inlet manifold and blanked off the pipe and started it and it put the pressure off the scale at 2+ bar so there are no leaks and the charger is in the right way. any ideas
my theory is the charger is not putting out enough air to feed the engine as i have no air filter fitted at present and i am using the std throttle body i assume the charger is not turning quickly enough and need a smaller wheel. what do you think
p millar
Posted 17th Apr 2010 at 23:25
drumfinpete
Post #65
took off the recirc pipe from the boost valve to give the charger more air and it created a tiny bit of boost where there was strong vacumn before but does not run well with pipe open any ideas would be welcomed
p millar
Posted 18th Apr 2010 at 22:00
smegal
Post #66
I'd try a smaller charger pulley for a start.
Ex SC-6
Now in a Megane R26
Posted 18th Apr 2010 at 22:13
drumfinpete
Post #67
opened the second inlet on the charger and it seems to have helped the pipe does not suck in any more and i seem to be showing 1 or 2 psi pressure on the gauge now rather than 7 psi vacumn. opened the blow off pipe into the charger as well and was getting 3 - 4 psi on the gauge how much boost should i aim for on standard engine and 440 cc injectors.
p millar
Posted 21st Apr 2010 at 00:04
smegal
Post #68
7-8 to be in line with the rotrex type conversions? I would certainly not go much higher than 9psi especially with the type of charger used.
Ex SC-6
Now in a Megane R26
Posted 21st Apr 2010 at 00:32
drumfinpete
Post #69
some photos of current set up to help explain things
drumfinpete has attached the following image:
p millar
Posted 26th Apr 2010 at 00:52
drumfinpete
Post #70
Uploaded with ImageShack.us
p millar
Posted 26th Apr 2010 at 00:54
drumfinpete
Post #71
p millar
Posted 26th Apr 2010 at 00:59
drumfinpete
Post #72
p millar
Posted 26th Apr 2010 at 01:02
mabgti
NV motors
Post #73
suprised you havent done your research.. that dump valve will do nothing there. You need to work out crank to charger ratio.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 26th Apr 2010 at 01:20
allanallen
Post #74
Pete, get rid of the dumpvalve and block the holes up. You don't need a dump valve when your throttle body is up-stream from your charger!
The only way air should be able to get into the system is through the throttle body so block all the other holes up. Other holes after the throttle body will allow un-metered air into the system and it wont run properly.
All your pipes need to be hardpiped, before and after the charger. Under load the pipe between the throttle and the charger will close up and not let air through. The pipes after the charger will close up under closed throttle when there is vac in the system.
As per are pms your pulley ratio should be spot on, I will check the sizes of my pulleys when i'm in the garage later on and let you know for a comparison.
You will see negative boost pressure when at idle and driving around under no load/small throttle openings. You'll see positive pressure when you get the throttle well open and the engine under load.
Your system should go;
Airfilter
Throttle body
Charger
Intercooler
Inlet manifold
All connections as mentioned need to be solid, you can use silicone hose to join solid pipes but only small lengths so they can't collapse.
Probably a daft question but is your charger belt tensioned up properly?
Good luck, al
Facebook
Posted 26th Apr 2010 at 13:25
drumfinpete
Post #75
hi guys, still having major diffs with this project, took the car to a different tuner who worked out the map sensor needed to be on the inlet manifold, this cured the misfiring and running on 2 cylinders. had hard piped everything and removed stupid blow off valve as instructed. but we still had no power less than standard and still showing vacumn under full throttle. and up to -8 psi vaucumn at idle or low revs,we assumed the engine is demanding more air than the charger is providing and decided to reconfigure the set up mto give the charger unrestricted air, layout is
air filter (or lack of)
charger
intercooler
throttle
manifold
still have no power and vacumn as before and will only run properly at tick over or full throttle
i think the problem is with the charger either its f*cked or not running fast enough to create pressure but why is everyone else getting away with the standard pulley ? and is there any way of testing if the charger is working properly, i blocked the end of the pipe and it put the gauge off the clock on throttle, how do i work out the ratio of the crank to the charger
p millar
Posted 18th Jul 2010 at 15:18
