displaying posts 26 to 50 of 89
Pages (4): 1 [2] 3 .. last
Author Subject: supercharging gti6
drumfinpete
URL=http://img215.imageshack.us/i/imgp1183.jpg/][/URL]
got the manifold back, great job, looks good too, connected everything up again added my new injectors turned the key and all i get is a clicking noise from the starter it wont turn over. charged the battery tried jump leads and a tow nothing worked its not even trying to start. any body got any ideas i thought it might be the immobilser ??
p millar
Posted 28th Jan 2010 at 02:53
allanallen
Even if it is immobilised I would think it should still turn over. I'd go over all your wiring again and check that you batterry is definitely good. Possibly a knackered starter?
I'd be very careful what your doing with the car once its started. Simply putting bigger injectors in is not enough to allow you to run for any length of time. I would think it will run rich at idle and probably soot the plugs up until it wont run. Then it will run lean on boost. Thats if it will rev at all, as i'm not sure how the standard ecu/map sensor will react to positive pressure without being fetteled.
Allan
Facebook
Posted 28th Jan 2010 at 03:14
chrisd306
pete, bit off topic but you a rangers fan??
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 28th Jan 2010 at 03:18
drumfinpete
thanks for advice, dont intend to run it long its going to get remapped with autotune in ballymena as soon as it starts, that reminds me still need new plugs and leads whats the best type for this set up
p millar
Posted 28th Jan 2010 at 13:42
rallyeash
check all you power and earth cables, sounds like you could of took one off and not reconected.
to simply check the earth get a jump lead and attach it from the lifting hooks on the head to the wing. see if she starts now Smile
309 3dr K20 Type R
Posted 28th Jan 2010 at 14:54
drumfinpete
will try that tonight
p millar
Posted 28th Jan 2010 at 19:43
allanallen
Gti6 doesn't use any plug leads pete. I'd initially run it with the standard plugs and see how it goes, you may need to change them for a cooler grade. Might be worth while finding out what the low boost lynx conversion uses?I think it will foul them up pretty quickly when you first get it started though, so it may run one minute then stop and not want to start again.
Facebook
Posted 28th Jan 2010 at 23:25
allesclar
CHRIST!! is there enough room between manifold-sc-rad?
seems if you have any bit of engine movement then crush Sad
Team allesclar ®
Posted 28th Jan 2010 at 23:30
birk
Standards are 6, rich use's 7s in his, ive had 8s, but they made it hard for the car to start some times.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 28th Jan 2010 at 23:58
drumfinpete
Post #35
any one got a stainless exhaust system at the right money
p millar
Posted 29th Jan 2010 at 02:12
drumfinpete
Post #36
hi guys, thanks for the help so far but i need you again i have worked out i need a new starter, but i also noticed i never hear the fuel pump so i pulled of the feed pipe and turned the key nothing came out, where do i start
p millar
Posted 30th Jan 2010 at 00:25
fletch
Track Head
Post #37
Crank sensor, ECU fault, or double relay behind the battery could be the problem.
Posted 31st Jan 2010 at 03:16
mabgti
NV motors
Post #38
Very neat work.. manifold looks nicely done.
If you wanna make sure it doesnt pop, disconnect lambda and tps and get a rising rate fuel reg on there so you can set the idle pressureYes
SC bolted to engine so manifold will be ok... worried bout the rad thouughUnsure
Ive ran 8's fine
What he said.. but start off with the fuel cut switch on n/s top strut!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 31st Jan 2010 at 04:29
drumfinpete
Post #39
got it sorted was the plug at the back left hand corner of the engine bay must run fuel pump, took advice and put std injectors back in and left the charger pipe disconnected started and runs fine, but its sucking the blue silicone bend flat when i rev it thinking of inserting a couple of metal rings to support it. hopefull will map this week
p millar
Posted 1st Feb 2010 at 20:29
rallyestyle
Post #40
See if you can replace the silicone pipe with a section of alloy tubing and a couple of cilicone connectors, will be fine then Thumbs up
Just Drive It
Posted 1st Feb 2010 at 21:05
mabgti
NV motors
Post #41
any update??
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 23rd Feb 2010 at 21:04
drumfinpete
Post #42
fitted recirc dump valve and a stainless exhaust since i last posted but this has taken me up to my 2 k budget going for mapping on monday another
p millar
Posted 24th Feb 2010 at 16:11
chrisd306
Post #43
cant wait to see what its putting out like!!
& Audi Q5 S Line
Posted 24th Feb 2010 at 17:23
drumfinpete
Post #44
will try to get a graph on monday will have to get photos up, painted the engine looks great
p millar
Posted 24th Feb 2010 at 20:37
millic333
Post #45
more pics and an update??
sharland wrote:
Your life is like an action movie. And I want in.
CARL.
Posted 1st Mar 2010 at 22:20
cooper666
Post #46
any update pall
clio r27
ps3 id:cooperkloe
Posted 3rd Mar 2010 at 02:36
drumfinpete
Post #47
still awaiting its return.
p millar
Posted 3rd Mar 2010 at 13:10
drumfinpete
Post #48
hi, need you guys again the car is away at tuning but its sucking in the pipe from the intercooler to the inlet manifold, and therefore running like a pig, my theory is not enough air coming through the filter to supply the charger and is starving the engine i have reomed the filter as tempory measure and have bought a bonnet scoop to proved some o2 but what filter is going to let my baby breath, i was looking at mushroom filters on ebay remember i am on a budget dont want any 300 quid suggestions
p millar
Posted 12th Mar 2010 at 23:25
allanallen
Post #49
You need to use solid pipes pete, I think you'll struggle with large lengths of silicone/rubber hose.
I didn't have this problem as I left my throttle body on the manifold and used a dump valve to release the boost when the throttle is shut. You could look at moving your throttle downstream like mine but hard pipes should solve it. I doubt your filter has much to do with it. Universal k&n's are pretty cheap though have a search on google, I think I paid about
Facebook
Posted 13th Mar 2010 at 00:05
greenbelt
Post #50
With the Rich_W SC kit we have the same problem of collapsing silicone piping on idle.
I had the same problem at the charger outlet and solved it by putting rings of boost piping inside the affected areas.
It was only meant to be a temporary measure until I could get solid pipes made up but 6 months and 3k later it hasn't caused any problems.
At the Essex Rolling Road meet last week I noticed ballardpaul had the same problem at the inlet manifold join.
It's something we can live with. Just doesn't look great.
Smile
Standard Black 6
Black HBSC6 Smoke
Posted 13th Mar 2010 at 00:28
