displaying posts 201 to 225 of 267
Pages (11): first .. 8 [9] 10 .. last
Author Subject: Track Car Project Gti-6
Disco_Stu
Post #201
Cant remember how to do links now -doh! (+ the search is not working so can't find help)
Peugeot 306 Gti-6 Track car (soon to be supercharged)
Project page
Blog
Posted 8th Nov 2011 at 11:31
Post #202
Honestly I don't know, but I don't see how a liquid can reliably displace 100% of a gas when it's got physics working against it. Only way to see is to try it, and see if the temperature at the top of the cooler is the same as the bottom like a radiator.
Clicky
Posted 8th Nov 2011 at 11:33
Disco_Stu
Post #203
Clicky
Good idea, I will see if there is a temperature difference once it is running.
...and thanks for the clicky
Project page
Blog
Posted 8th Nov 2011 at 11:37
Post #204
There are things you can do to help, as Matt hinted at personally I'd remove the cooler and fill it the other way up, then re-attach it once you knew most of the air was out.
Posted 8th Nov 2011 at 11:41
Post #205
Generally, the high system pressure and the viscosity of the oil means it can capture pockets of air and drag them around to the sump, if you don't have the outlets on the top any remaining microbubbles tend to get compressed right into a corner of the tanks and do very little to affect performance.
Posted 8th Nov 2011 at 11:48
Post #206
Could always drill a hole in the top to let the air out Whistle
Posted 8th Nov 2011 at 11:53
Post #207
There's one in the engine already Whistle
Posted 8th Nov 2011 at 12:24
matt evans
Post #208
Self tapping screw should do it!! LOL
honestly3k wrote:
owain wrote:
Posted 8th Nov 2011 at 12:28
Post #209
I've always mounted mine upside down as I like to disconnect the pipes when servicing so I can get as much of the old contaminated oil out as possible and never had a problem with the cooler not functioning properly, if you are worried you could as said unbolt it and flip it over with the engine running but it's hardly worth the effort.
Posted 8th Nov 2011 at 12:42
Disco_Stu
Post #210
It’s alive!!!
Finally got the car started today – not for very long as I still need to fit the exhaust then run it in.
Also started modifying the seat sub frames to move them over a little, the initial seat position was a little too close to the door.
Below if the photo of the harnesses (which I was going to post last week, but forgot)
Project page
Blog
Posted 13th Nov 2011 at 18:15
mabgti
NV motors
Post #211
Are those trs wannabes?
Isnt srs a protected copyright from the airbag systems?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 14th Nov 2011 at 12:20
Post #212
srs are made by sabelt aren't they?
Posted 14th Nov 2011 at 12:50
Disco_Stu
Post #213
Yes Sabelt manufacture these harnesses.
Just run out of FIA approval, hence why I bought them at a good price.
Project page
Blog
Posted 14th Nov 2011 at 19:58
Disco_Stu
Post #214
Fitted the exhaust and decat so it is a ‘little’ quieter now (unfortunately the exhaust is a Magnex and I am pretty sure it is the noisiest thing known to man! – was meant to be a mongoose, anyway it will do for now)
Stainless steel decat:
Also managed to move the car for the first time yesterday, not far just enough to check it could actually move change gear and stop!
I have also taken a very short video of the car starting and running.
Video Link
Project page
Blog
Posted 4th Dec 2011 at 19:13
Post #215
Video Link
yeap thats why i got rid of mineThumbs down nice sound but makes your ears BLEED!!!!!!
Posted 4th Dec 2011 at 20:02
BrianM
Post #216
fantastic project mate, not long to go now Smile
'13 208 Gti Bianca White, '99 Bianca 306 Rallye, '92 309 Goodwood GTi 5dr, '92 Miami Blue 309 GTi 3dr.
Posted 4th Dec 2011 at 22:10
Disco_Stu
Post #217
New parts arrived;
> Smaller door mirrors
> Smoked side repeaters
> Harness eyelets and backing plates
Fitted the door mirrors, side repeaters and front grill today;
The engine still starts no problem, but we noticed that the rear of the car is lower one side more than the other – another job to the list.
Project page
Blog
Posted 17th Dec 2011 at 16:20
Disco_Stu
Post #218
Have not been on here for a while so here is an update to see that work has not stopped.
Firstly we now have the car level and had the 4 wheel alignment checked and adjusted.
Next was some heat reflecting foil to go under the bonnet
Fitted both seats and harnesses in their final position (hopefully).
Strut brace fitted
Next was the heated windscreen + wiring
Took the car outside and noticed a knocking noise from the front drivers side wheel. Luckily we found out this was only a faulty drop link, which we have now changed
Need to does some work on the trailer to make it road legal (some tyres, new brakes and possible some wiring). After this we are ready to do a local track day as run in (nice and slow Smile )
Project page
Blog
Posted 31st Mar 2012 at 17:12
gti-gaz
Post #219
looking good!
Posted 2nd Apr 2012 at 16:38
birk
Post #220
Looks good Smile
Where did you get the heat reflecting foil from?
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 2nd Apr 2012 at 23:04
rallye1999
Post #221
Where do you get the heated windscreen from?
Posted 3rd Apr 2012 at 12:55
Disco_Stu
Post #222
Hi, sorry for the delay in responding.
I got the reflecting foil from a friend at work (I will ask him tomorrow where he got it from)
The heated windscreen is from Ricky Evans motorsport
Project page
Blog
Posted 4th Apr 2012 at 22:13
Disco_Stu
Post #223
The foil is from:
Frost Restoration Equipment Website
Project page
Blog
Posted 5th Apr 2012 at 18:52
birk
Post #224
Quite expensive then...
07889376885
Dan
Posted 5th Apr 2012 at 20:25
Disco_Stu
Post #225
It is not the cheapest, I was lucky that the person at work only needed a little bit and was happy to give me the rest Smile
It does stick very well, I've seen some cheap stuff in the past which falls off after a few days.
Project page
Blog
Posted 5th Apr 2012 at 20:29
