displaying posts 26 to 40 of 40
Pages (2): 1 [2]
Author Subject: Ignition leads
Laugh my ass off
Posted 17th Jun 2014 at 19:25
I fix bicycles Razz
Posted 17th Jun 2014 at 19:26
Bicycles have moving parts. My Filofax does not LOL
Still had no luck so I refitted the existing leads which I thought were knackered - runs fine.
Confused as to what the actual issue was - but basically there was a missfire issue with existing leads. Fitted new ones. Problem solved. Problem comes back. Fit old leads. Problem solved.
Maybe a connection issue somewhere. I shall keep an eye on it and set fire to it if it happens again.
Tempted to get another coil incase there's something up with one of the outlets and it vibrates loose or something.
Thanks for your help, member of the month June 2014.
  • Posted 17th Jun 2014 at 20:08
    could well be the coil, they tend to show symptoms when hot before totally breaking down and causing a misfire from cold.
    Posted 17th Jun 2014 at 20:39
    RallyeP6
    That's just what i'm going to look for later, a coil pack and leads. Already bought the AMP mini timer connector. Will try and get a Valeo or Bosch coil though as i've had failing coils in the past with other cars.
    Stalling cars that won't start straight away and have to be pushed off the road are no fun!.
    Posted 20th Jun 2014 at 16:07
    demondriverdan
    Bit of a thread revival. I'm running a generic Corsa B GSi coilpack and Halfords HT leads on my car but after the last race I found the HT leads are working loose, I could lift them out with 1 finger.
    Are Magnecor the recommended brand?
    Rallye Race Car
    Posted 16th Aug 2017 at 08:39
    YES !!!
    Sandy said they are worth every penny ...so I bought a set & amazing tight fit both ends .....you did comment on my project about them ?
    Not cheap & get the thicker better ones ...look at my project & they are bright red ....got them second hand Thumbs up
    Posted 16th Aug 2017 at 09:58
    get the pliers out and squeeze the terminals a bit till they click on nicely.
    Posted 16th Aug 2017 at 11:14
    Forgot ....Your engines not had much work on it has it Dan ?
    You are not after every little thing yet ?
    As Mei just said try that & when your engine gets done ...invest Whistle
    Posted 16th Aug 2017 at 12:54
    demondriverdan
    Post #35
    It's not crazy modified but still fairly (ported and polished head, cams, bodies). The performance gain will be minimal, I'm more after something that fits better so it doesn't come off as it'll ruin a race if it does
    These should be ok? http://www.larkspeed.com/shopper/i/G4588/Peugeot-306-XSi-2-0-SOHC-8v-Magnecor-8-5mm-KV85-Competition-Ignition-Leads
    Rallye Race Car
    Posted 16th Aug 2017 at 14:14
    fatlapit
    Post #36
    xsi coil pack fit and forget
    Posted 16th Aug 2017 at 15:27
    demondriverdan
    Post #37
    We spoke about this yesterday! Razz
    Rallye Race Car
    Posted 16th Aug 2017 at 16:49
    fatlapit
    Post #38
    lol true amongst other things
    Posted 16th Aug 2017 at 17:07
    Post #39
    On my old engine I had one of those with cut out modified to fit my Engine but it was old as all of them are & started playing up Thumbs down
    Yes I had a spare but they are all getting tired like me now LOL
    Posted 16th Aug 2017 at 17:19
    demondriverdan
    Post #40
    I've ordered those leads, will see if they're the right ones when they arrive. Pretty pricey though!
    Rallye Race Car
    Posted 17th Aug 2017 at 09:33
    Pages (2): 1 [2]
