displaying posts 1 to 25 of 89
Pages (4): [1] 2 3 .. last
Author Subject: Uprated Head Gaskets
rich_w
I can supply bespoke Lynx Power Engineering Head Gaskets, as used on my car.
The gaskets are MLS construction as per the OEM one, with numerous improvements:
1. Three layer construction - inner layer is stainless steel, the outer two layers are spring steel with elastomer coating. The OEM item is mild steel.
2. Individual fire rings - inbetween one of the spring-steel outer layers and the central core, there are additional 'fire rings' around the cylinders. These are essentially thin, large metal washers, which provide an increased clamp load around the cylinder and a mechanical seal.
3. To give you an idea of the performance of these, I blew a Cometic MLS gasket on ARP head-studs after 700 miles on my 443 BHP engine. I then fitted one of these, which to this day is fine, 10,000 miles later. I've done a compression test - all 4 cylinders are within 3 PSI of each other - which on an engine this highly-strung is bloody good! It indicates there's no leakagebetween cylinders or out of the cylinders,
[b]Cost is
Contact Details:
07732 822546
Posted 7th Dec 2009 at 17:39
chrisd306
This is what me and davey have and daveys 205 is sound at 350 odd bhp.
also a very good price now, wish i had bought head bolts as there cheaper han orginal pug ones!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 4th Dec 2009 at 14:41
205gti6_ro
have you got a few of these? or is there a limited number?
Posted 5th Dec 2009 at 01:03
vts_gav
rich_w wrote:
- all 3 cylinders are within 3 PSI of each other
whats happened to the fourth have you only got a gti5 now lol
Posted 5th Dec 2009 at 03:05
puglover Banned!
wow awesome work rich.
Posted 5th Dec 2009 at 05:38
chris with a pug
what head bolts are they rich? and would it be worth getting a set of head studs as i been thinking of doing that
Posted 5th Dec 2009 at 16:10
rich_w
They are 10,9 grade stretch bolts, as per the OEM type.
As for the studs, it's upto you - they are a lot of money [around
Contact Details:
07732 822546
rich_w
Doh
Edited Laugh
Contact Details:
07732 822546
He's got so much boost now that he's lopped a cylinder off to make the car lighter LOL
Posted 7th Dec 2009 at 17:44
rallyeash
still got a gasket and bolt set available? as i will need one Smile
can you pm me a price for standard uprated main and big end bearings, billet flywheel, billet crank pulley, head gasket and head bolts.
cheers
309 3dr K20 Type R
Posted 14th Dec 2009 at 01:56
rich_w
cheers
Yes - got about 5 gasket / bolt sets here.
YHPM.
Contact Details:
07732 822546
Posted 14th Dec 2009 at 18:06
spaniel
i got mine a couple of days ago. it came quick and was well packaged, i would buy off this geezer again Smile
Posted 26th Dec 2009 at 22:36
rich_w
Glad you got it OK mate
Cool
Contact Details:
07732 822546
Posted 4th Jan 2010 at 17:07
rich_w
I have now sold out of these gaskets - but should have more towards the end of January.
Plenty of head-bolts still in stock.
Cheers,
Rich.
Contact Details:
07732 822546
Posted 11th Jan 2010 at 18:25
rich_w
Some people have asked for pics of these - so'ive put them below.
The most notable thing is the fire-rings bonded to one of the outer layers, which provides a mechanical seal around the combustion chamber.
Smile
Contact Details:
07732 822546
Posted 22nd Jan 2010 at 01:37
bobdylan_55
forgive me if i already asked before, but are you able to supply these all the time? basically im not after one at the moment, but if my head gasket goes on my turbo engine id be looking at buying one.
309 GTi6-T
Posted 22nd Jan 2010 at 16:16
rich_w
I can supply these all the time - all though there may be a 2-3 week wait on them at times, depending on where we are with the manufacturing / stock cycle.
Smile
Contact Details:
07732 822546
Posted 22nd Jan 2010 at 17:22
adamjb
Might be a daft question but would there be any advantage in using these on a standard spec' engine? I'm just trying to make a list of parts I may need in the future and I'm wanting to use the best I can get. Not really planning on any modifications apart from airfilter, lightend fly wheel when its worth replacing, that sort of thing so pretty unstressed engine.
white rallye
Posted 24th Jan 2010 at 06:49
mike rallye
hi rich do you still have any of these uprated gasket. and is it a worthly to do?
Posted 25th Jan 2010 at 18:22
t0mt0m
the second i got some money spare i will be ordering one of these and bolts from you! as i have been after a performance head gasket! Smile
t0m
1997 Diablo Red 1.6 xs! crashed and scrapped!
1998 Nile blue Gti 6
1999 Yamaha R6! maybe for sale soonish still in two minds!
Posted 28th Jan 2010 at 00:51
rich_w
I will have more of these in stock any time now - the manufacturer told me the end of January so any time now.
Please PM me when you are ready to order to sort out payment etc.
As for worth using on a relatively standard engine - given an OEM head gasket and bolts will cost you circa
Contact Details:
07732 822546
Posted 28th Jan 2010 at 17:54
rich_w
My supplier has confirmed my new stock of these will be sent to me on the 5th February - so I will have them available shortly after this for delivery.
Smile
Contact Details:
07732 822546
Posted 2nd Feb 2010 at 17:36
b1ack_mi16
Can you supply these gaskets with a 87.5 or 88 mm bore?
Posted 10th Feb 2010 at 13:12
rich_w
I'm afraid not, I think they are approx. 87mm bore.
It's not an issue though - you can run the HG smaller than the bore size - as long as your pistons don't protrude the deck at TDC [they shouldn't!].
It won't effect 'squish' or 'quench' either.
Smile
Contact Details:
07732 822546
Posted 16th Feb 2010 at 00:31
rich_w
I have finally received some more of these - and have 4 available.
I'm not sure when I will be able to get more produced for various reasons - so if you need one in the near future, my advice is buy one now whilst I have stock.
Smile
Contact Details:
07732 822546
Posted 16th Feb 2010 at 00:33
