| Author | Subject: bretts rallye makeover [tbs] |
brett-black-rallye
Senior User Location: felixstowe Registered: 28 Aug 2007 Posts: 573 Status: Offline |
Post #51
i got round to picking the engine up after work today, that was a big dent in my bank account ![]() ![]() ![]() |
armogedden57
Junior User Location: leeds Registered: 11 Dec 2006 Posts: 79 Status: Offline |
Post #52
looking good mate, kudos for doing it right 1st time.________________________________________ '96 xsi - awaiting a vts engine transplant this week'98 XSI - scrapped '99 xsara vts - psa darkside - scrapped! willygti wrote: I spy power steerig fluid all over your lovely clean floor.. awful stuff - smells like period |
spike_uk06
Seasoned Pro Location: Billingshurst Registered: 03 Aug 2006 Posts: 1,637 Status: Offline |
Post #53
Good luck mate! looking good and you should have a peach at the end of it.________________________________________ Team ChinaTeam Pirelli Team Cracked Bumper 92k 20th Nov 1999 she was born |
Post #54
brett-black-rallye wrote: i stood back the other day and the rear is in desperate need of lowering ![]() naah the front needs to come up 30mm or so! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jimmyrallye
Seasoned Pro Location: portsmouth Registered: 19 Apr 2008 Posts: 3,144 Status: Offline |
Post #55
you dont like your cars lowered welshpug do ya mate ________________________________________ "Police arrested two kids yesterday, one was drinking battery acid, the other was eating fireworks. They charged one and let the other one off." |
brett-black-rallye
Post #56
its each to there own on how low really. IMO 60mm is perfect! |
Post #57
there's lowered and there's too low!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brett-black-rallye
Post #58
i agree, too low is when the wheel hits the arch. and it doesnt! |
Post #59
they never do, you hit the bumpstops, or in your case you'll be on them soon enough, which makes them very dangerous.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brett-black-rallye
Post #60
they shouldnt, ive cut them down. |
Post #61
That tends to result in you destroying the damper internals instead, you'd be better off fitting longer, softer, polyurethane foam bumpstops.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
brett-black-rallye
Post #62
its what gmax recommended so i went with it. |
willygti
Seasoned Pro Location: Exeter Registered: 08 Oct 2007 Posts: 5,024 Status: Offline |
Post #63
Excellent thread.I've got the same suspension setup matey, and in my opinion it's fine for normal drivign but gets seriously under-steery on the throttle when turning relatively sharpish - but it would do this even if i were at standard ride height or lowered 40mm. I think you should put smaller wheels on, as they make your callipers/discs look piddley. When i start earning some money the suspension is defo going to be uprated, but retain the 60mm drop as i think it looks awesome. 15x7 with 205/50/15s look mega with a 60mm drop ![]() ________________________________________ Team Ducati 7482003 Subaru Impreza STi |
brett-black-rallye
Post #64
yeah i see what you mean about the brakes, i might uprate to willwoods and put 16s on in the near future |
brett-black-rallye
Post #65
i went down to the unit yesterday to sort out my magnex exhaust as it was leaking and found this![]() all around the front of the back box the weld came apart so roni got his welding skills out. ![]() wilst i was there i uncovered the engine and decided to give it a bit of paint ![]() |
Post #66
sooo much nicer than black, you can actually see what you're doing in the engine bay ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brett-black-rallye
Post #67
welshpug! wrote: sooo much nicer than black, you can actually see what you're doing in the engine bay ![]() thats what i thought, more detail will be able to be seen and a totaly silver engine in a black bay should look pretty cool. |
brett-black-rallye
Post #68
i finally received my managment today ![]() ![]() im still waiting for the throttle cable linkage and tps im picking up my head tomorrow, then i will be building the engine up |
Post #69
where from and how much was that?Looks like a pro built megasquirt? just another thought, possibly a bit late now, but there's no space for decent cams in the standard pistons.... ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
brett-black-rallye
Post #70
welshpug! wrote: where from and how much was that? Looks like a pro built megasquirt? just another thought, possibly a bit late now, but there's no space for decent cams in the standard pistons.... it came as a whole package with the jenveys for a grand you are correct it is megasquirt i was told that the cams i have are the same as pt81s but just a different make. theres a few people that are running them with standard pistons, but as my head has been skimmed and the block has been decked it maybe a bit close. i will investigate that when the head is together. is there a certain way to test if the valves hit the pistons or is it just a put together, turn the crank and listen for the tunes? |
brett-black-rallye
Post #71
i collected my head today after the skim and de coke![]() ![]() the exhaust ports look far better now |
willygti
Post #72
Good progress mate. Have you got an idea of how much your going to be spending all in - as i'm eyeing up the throttle body option as soon as i finish uni in a few weeks ________________________________________ Team Ducati 7482003 Subaru Impreza STi |
brett-black-rallye
Post #73
im still not happy with the sound of my exhaust, its far too tinny and loud so i bought some wadding to refill the back box to dull it down a bit |
brett-black-rallye
Post #74
willygti wrote: Good progress mate. Have you got an idea of how much your going to be spending all in - as i'm eyeing up the throttle body option as soon as i finish uni in a few weeks i havent sat down and added it up, im a bit scared to, to be honest lol. i recon its around 3grand on the engine, but it can be done cheaper. if i were to do it again i would probley try and get hold of a real low milage bottom end |
jimmyrallye
Post #75
hi brett whats that wading stuff for the exhaust as my back box its quite loud and wouldnt mind some of this stuff in mine, were do you buy it from ________________________________________ "Police arrested two kids yesterday, one was drinking battery acid, the other was eating fireworks. They charged one and let the other one off." |
