displaying posts 201 to 225 of 1309
Pages (53): first .. 8 [9] 10 .. last
Author Subject: Daveyboy's Rallye Race car
Post #201
miles wrote:
The vacume pump can be left just to feed the Servo as it provides more than enough without the inlet being needed, All the ones I;ve converted are like this are work better as there's no loss of vacume when left foot brakeing
Cool, just got to make myself up some 1/8 NPT balanking plugs then? LOL
Posted 13th Apr 2009 at 23:41
Post #202
Found my switched live and power feed for the fuel relay, unfortunately I still have an issue as when you turn the key to the accessories position the fuel pump is supposed to prime for 2-3 seconds and then stop until you turn the key to the start position. At the moment when I turn the key to the second click the fuel relay stays on all the time. Small stuff though really and I'm very pleased with the new soundtrack my car has Ninja
Posted 13th Apr 2009 at 23:45
Post #203
Had my final delivery from Jenvey today, trumpets are finally here so as soon as five o'clock rolled around they were bunged straight on! Love
Got my battery box yesterday too, so that went on last night.
Will be recieving an auto-tensioner next week and then I'll be able to get an auxilliary belt on and take her for a spin.
Big grin
Posted 17th Apr 2009 at 06:43
robertinho
Post #204
dave, what is the advantages of using this ignition system instead of the original multi coil system?
Posted 17th Apr 2009 at 07:58
birk
Post #205
Looks well, have you ditched the powersteering then ?
how much was the battery cage, i want one for mine.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 17th Apr 2009 at 15:13
smighall
Smeg-all
Post #206
A lot of after market ECU's don't support coil on plug and use a wasted spark system instead, hence the need for a different coil pack.
Meh
Posted 17th Apr 2009 at 15:16
Post #207
What he said Big grin Omex 600 ECU does not support individual coilpacks but as far as I can see there is no real penalty or benefit from the different coil arrangements (except for the fact that the single coil is slightly lighter, not that I weighed it or anything...Whistle )
Posted 17th Apr 2009 at 15:43
Post #208
Posted 17th Apr 2009 at 15:49
Post #209
could have used the J4R coilpack, that's wasted spark like the one you have, no need to plug leads then Wink
don't forget your battery still needs to be in a sealed box with a vent to the outside.
is it a Jenvey manifold? which filter are you going for?
Posted 17th Apr 2009 at 16:04
Post #210
Should've done a bit of research on here beforehand, I've had so many people tell me what I could've or should've done but it does'nt really matter now it's on there and seems to work
Is the sealed battery box an MOT requirement or is that just for racing cars?
Yep, Jenvey/Longmans manifold and I'll be opting for a Pipercross dome filter, got to order it soon as I can afford it so tht I can get the backplate marked up and drilled, as they come plain from Jenvey.Roll eyes
Posted 17th Apr 2009 at 17:40
richard Banned!
Post #211
the battery needs venting regardless, it is letting off poisonous and flammable fumes when charging. it might not fail on the mot but it'd need looking for your own health and safety
Posted 17th Apr 2009 at 17:46
Post #212
I'll have a look for a vent tube then, there is a hole in the car left over from the fixing bolt that held up the spare wheel cage which is now redundant so I could run a vent tube out through that. Cheers Thumbs up
Posted 17th Apr 2009 at 17:50
jonnyvandijk
Post #213
But the BMWs and minis etc which have the battery in the boot are not vented as far as I was aware?? Gives off fumes?? Confused
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
Posted 17th Apr 2009 at 19:18
chris with a pug
Post #214
You can use standard management appaerntly, but no one told Jim until it was too late
Posted 17th Apr 2009 at 21:46
mabgti
NV motors
Post #215
looking good mate.. love the progress... but be careful with cable ties on the strut brace.. engine moves alot more when in load and could rip the fuel line in two... hence peugeout used routing blocks..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 17th Apr 2009 at 22:02
Post #216
Thanks for the pointer, I have moved things around a little more under the bonnet since the last pictures, and there is plenty of slack on the fuel pipes now (especially as I'm on Group N mounts so the engine now moves very little) Thumbs up
Posted 18th Apr 2009 at 03:09
Post #217
Got my autotensioner today, so guess what I'll be doing tomorrow? Yes, sleeping off a hangover, then, I'll be getting under the car and fitting my Aux belt so I can take the car for a drive Cool
Posted 19th Apr 2009 at 04:21
chris with a pug
Post #218
Ill pop down when I get back from wales you should have fitted it by then.
Those tensioners weigh a ton lol.
Posted 19th Apr 2009 at 16:54
brett-black-rallye
Post #219
looking good mate. im about to go through all this with mine, so you might be getting one or two questions Smile
Posted 19th Apr 2009 at 17:43
Post #220
You don't wanna ask me! I've just blundered through it and somehow they work!LOL
Seriously though, it's not too bad. What management are you thinking of running? Apparently Wayne can map the standard ECU to run bodies. Does mean a trip up North everytime you need to change something though.
Posted 19th Apr 2009 at 17:48
brett-black-rallye
Post #221
haha, same as what i will be doing then. ive gone for a megasquirt ecu. i would like to get it mapped at waynes but hes too far away for me.
Posted 19th Apr 2009 at 18:18
Post #222
Can Megasquirt give you a base-map or do you have to start totally from scratch with thieir ECU?
Posted 19th Apr 2009 at 22:07
brett-black-rallye
Post #223
they give you a base to get it running. hopfully with their ecu i should be able to keep my normal coilpacks aswell.
Posted 20th Apr 2009 at 04:41
Post #224
That should save you a few quid then if you don't end up having to buy a different coilpack and plugleads.
Posted 20th Apr 2009 at 12:18
Post #225
Tomorrow my coilovers will be arriving...Cool
Saturday and Sunday are set aside for gearbox removal, clutch and lightened flywheel fitting and installation of the LSD. Going to be a LONG weekend with much skinning of knuckles and swearing...Ninja
Posted 24th Apr 2009 at 04:32
