displaying posts 351 to 375 of 1309
Pages (53): first .. 14 [15] 16 .. last
Author Subject: Daveyboy's Rallye Race car
Post #351
10 minutes
Posted 1st Aug 2009 at 00:55
Post #352
Well, it's arrived, and the fit looks excellent, very close to the shell all the way round and it doesnt look like there will be much need of cage to shell gusset plates but I will probably chuck a few on anyway as they look the part.
The drive back was interesting though with my instrument cluster taped to my steering column and no functioning indicators either!LOL
Anyway, heres a few pics to give you an idea of the fit, ignore the mess (I did'nt do it!)
That should keep me busy for a while...
Posted 1st Aug 2009 at 04:48
Post #353
Much better fit that Thumbs up
Posted 1st Aug 2009 at 04:57
Post #354
Yeah but I can't see how I'll be able to drop the hoop down to weld the a pillar/roof bars?
Posted 1st Aug 2009 at 05:03
Post #355
Snap the tacks on the rear hoop off the main hoop, pull it out of the way, then do the same with the 2 main feet that they've put in under the hoop, and twist the whole cage downwards - you'll probably find you'll need to take the door cross out to get it to flex past the rear seat area, cause you have to squeeze the bottom of the hoop in, he-man style - then you should have *just* enough to weld the top of the main hoop.
edit: no front strut tubes/dash bar?
Posted 1st Aug 2009 at 05:10
Post #356
phillipm wrote:
edit: no front strut tubes?
They have supplied them, and the windscreen bar, they are just not pictured. Wink
Post #357
Ah, left you the fun bit then! Big grin
Posted 1st Aug 2009 at 05:12
Post #358
I expect I can get busy with a ratchet strap or something to pull the legs of the hoop together while I pull it forward at the the bottom. I just know I'm going to end up with something I can't get at! Shock LOL
Posted 1st Aug 2009 at 05:13
Post #359
Yeah, the ones on Rikky's were sprung in slightly anyway, so it wasn't too hard to get it that bit further - but had to push it out with a 2-ton panel press once the feet were back in to get it up to the bodyshell - didn't take much force, just easier to hold whilst it was tacked back in.
It is a bugger to get in there even so - you're nearly at 90* with the torch at the top.
Tin opener on the roof skin would be favorite....LOL
Posted 1st Aug 2009 at 05:23
Post #360
Good excuse for a carbon roof? Cool
Posted 1st Aug 2009 at 06:05
puglover Banned!
Post #361
f*ck me thats tight Smile
i reckon im taking my roof off to do mine. Big grin
Posted 1st Aug 2009 at 06:16
Post #362
^^It'd be a lot easier!
That cage fit so much better than the other ones its silly - good job you got in touch Jim!
Posted 1st Aug 2009 at 06:19
Post #363
looks good, but those main hoop feet look rather too small and thin to me?
Posted 1st Aug 2009 at 15:47
Post #364
Possibly, but the bottom of the hoop overlaps the main chassis rail (Sill) which is very strong, the plate therefore does'nt need to be very big.
Posted 1st Aug 2009 at 16:18
Post #365
depends waht regs you're working to, I would always make them to MSA minimum then you can sell the car to whoever you want to when you get bored with it, increasing its value drastically, rather than just being a track car...
the main chassis rail really isn't that strong....
bit of 3mm plate, 120cm2, whatever shape that suits for the main 4 points, rears 60cm2 each. Smile
Posted 1st Aug 2009 at 17:13
Post #366
They're bigger than they look, I measured 'em to be sure.
Posted 1st Aug 2009 at 17:23
Post #367
cool Thumbs up
Posted 1st Aug 2009 at 17:35
chris with a pug
Post #368
and how the f*ck do you paint it?
Posted 1st Aug 2009 at 18:00
Post #369
Ask Rikky LOL
Posted 1st Aug 2009 at 18:06
rikky 🦔
Post #370
remove roof, throw in tin of paint, rotate car on a rollover jig numerous times.
nah i just red oxide primered the welded areas and hammerite matt-black'ed it
it was a completely bare shell when i painted it though, no windows doors etc anything..
Posted 1st Aug 2009 at 18:16
Post #371
Not the old Mr.Bean firework trick then?
Posted 1st Aug 2009 at 18:15
rikky 🦔
Post #372
LOL
reminds me actually i need to chase my welding sample up to make sure it's ok to fit the cage... Shut up
after all the arseache if they don't give me the certificate i will be on the riot path and be getting it checked elsewhere hopefully
Posted 1st Aug 2009 at 18:20
Post #373
LOL
Posted 1st Aug 2009 at 18:22
chris with a pug
Post #374
we could try that on jims, fill it with paint and roll it down the street
Posted 1st Aug 2009 at 19:06
rikky 🦔
Post #375
hammerite spray is fine unless you want to go down the compressor and gun route. i couldn't be arsed and got an excellent finish with cans doing very light coats. just make sure you treat the welds well and the underneath incase it's f*cked your underseal
i've got the front end of mine in bits as i speak with no wings etc or anything on the front, treating the chassis legs
Posted 1st Aug 2009 at 19:10
