displaying posts 1 to 25 of 124
Pages (5): [1] 2 3 .. last
Author Subject: High Boost Rotrex conversion
fletch
Track Head
Thought it was about time I started one of these threads Happy
Intro
About three and a half years ago, before I got the trackday bug to distract me, I was thinking about more power in the 6. I tried Nitrous, which I actually quite enjoyed, but began looking for a more sustainable boost in power. Having seen the Ecosse conversions using the Opcon 'charger (and the price!) as well as contemplating a T16 conversion, I decided there wasn't enough power per
Posted 23rd Dec 2008 at 04:42
fletch
Track Head
Heres some of the shiny bits I collected up ready for the rebuild Wizard
Posted 23rd Dec 2008 at 05:01
Laugh i remember coming home all excited from work to see what had been delivered when i was building my s/c 6.
Looks to be an awesome project mate Thumbs up
Posted 23rd Dec 2008 at 05:02
stu
+1
Look forward to further updates! Cool
Posted 23rd Dec 2008 at 05:05
fletch
Track Head
Rebuild
My bare block came back having been overbored to 86.5mm. This was accurate, measured using an inside mic with no wear at the top of the bore. I also had the Ancillary bracket cut down, and the head came back skimmed and cleaned.
Bearing tunnel:
I decided to tart up the block while it was in pieces, so set about priming and painting it.
At this point in the build I moved house, and shortly after, helped in the in-laws move house.
Anyone who has moved, knows the hassle and work that needs doing before everything is settled in
and so the build was put on hold Sad
Posted 23rd Dec 2008 at 16:14
rallyestyle
Keep it going buddy, looking very nice indeed Smile
Who do you get to do all your engine work/fabrication?
Just Drive It
Posted 23rd Dec 2008 at 17:22
fletch
Track Head
The machine work was subcontracted by Lynx Garage as I was down there quite often for various reasons. Not sure what fabrication you mean though?
Posted 23rd Dec 2008 at 19:00
rallyestyle
Poor choice of words really as its pretty much the opposite to what i meant, rephrased... who hacked apart your ancillaries bracket? Laugh Im guessing Lynx too Yes
Just Drive It
Posted 23rd Dec 2008 at 19:17
fletch
Track Head
With seemingly endless birthdays, moves, holidays, weekends away etc and me getting depressed at the lack of progress I decided (and told the missus Laugh) much of the next few months was to be spent finishing off the build.
I set about building the bottom end:
Bearing clearances were then measured and checked.
Shells and Crankshaft were put in place and the main bearings torqued down.
Time to crack out the shiny bits Cool
Pistons were fitted to the rods with gudgeon pins in place.
Next up the rings...
I didn't want to hide these away in the block as they are beautiful bits of kit, but the engine wouldn't really work well without them... Meh
Fitting the pistons to the cylinders...
Big ends with L19 ARP bolts torqued up. (These bolts have a tensile strength of ~40,000psi more than ARP2000 bolts Crazy)
Engine was turned over and everything was moving nicely.
Now was the time to crack out the multiple bags of bolts I labelled up over a year ago Unsure
Some of the labels had deteriorated Laugh
Posted 23rd Dec 2008 at 19:33
paul. Banned!
hi mate dont want to sound a pan but your pistons are in the wrong way the arrow is to the rear of the engine
Posted 24th Dec 2008 at 01:50
http://www.306gti6.com/forum/showthread.php?id=91000&page=1
Posted 24th Dec 2008 at 01:59
n.g.k
Owned
Inside you are face!
Tune Of The Month
Posted 24th Dec 2008 at 02:15
read88
Mate, ur in crawley??? Listen, im desperate to get a GTI-6 at some point, and i do wanna supercharge it eventually as well, low boost tho.. im only about 20 mins away from u fella, do u mind if i give u a hand with this project, i don't know jack-shit about engines, but im pretty desperate to learn a bit more.. but im pretty strong and healthy n I'm good at taking orders, give me a bell mate anytime n ill come up n give u a hand!
Regards,
Ben
Media.
Posted 24th Dec 2008 at 02:30
nuss306
Hiya mate looks an excellent rebuild and will be interested on seeing it completed and seeing what power you get from it.
Keep up the good work! Cool
Vauxhall (c20let) powered peugeot 306 2.0 16v turbo, aka - PUGLET
Posted 24th Dec 2008 at 02:42
birk
about 400bhp i suspect
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 24th Dec 2008 at 02:47
fletch
Track Head
Paul i made the orientation decision based on rich's experience. He installed them this way and they came out with no wear on the skirt or piston slap. So we will see how they fare.
Posted 24th Dec 2008 at 03:06
midlife
No shit SherlockLaugh my ass off
Loving the write up, keep it upThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 24th Dec 2008 at 03:02
Do i see a set of 4-pots in your shiny box of tricks? Cool
Posted 24th Dec 2008 at 03:07
pedro_de_la_cruz
did Rich go for 86.5mm overbore too?
great project there mate, that feeling when its all finished and you take it for its maiden drive (even if you are running it in) is going to be memorable!
*R.I.P Pete Sims*
Posted 24th Dec 2008 at 03:12
midlife
I was thinking the exact same thing, they look big buggers, what breed are they thenDunno
Cool
Team 330™Cool
Posted 24th Dec 2008 at 03:16
fletch
Track Head
Cool
Just 406 V6 Brembo calipers lads:
Posted 24th Dec 2008 at 05:08
fletch
Track Head
Windage tray, Oil pump, crank seals, woodruff keys were all refitted.
Ancillaries bracket was fitted to the block and then the Alternator, SC bracket, and Rotrex were test fitted.
In parallel to the bottom end build, I was building up the cylinder head, that had come back from the Machinist skimmed and cleaned up.
New stem seals:
When fitting the valves to the Cylinder head I discovered one of the inlet valves was bent.
The valve guides looked ok, so I replaced the valve and continued by lapping in all the valves just to make sure they seated properly.
Next up was the tappets, cam carriers and cams. I fitted the timing cover, seals and pulleys, ready to drop onto the block.
Posted 24th Dec 2008 at 05:45
I may have missed a bit of this that is glaringly obvious Matt but which one is this going in? Diablo.
Looks a good work in progress btwThumbs up. Keep at it and get it al done.
Posted 24th Dec 2008 at 05:56
mattg4321
i reckon it'll be going in the black one Yes
looks awesome matt - keep up the good work, let me know if u need a spare pair of hands and ill do my best to help you out
Ex 6 owner - now S2000 Cool
Posted 24th Dec 2008 at 05:59
midlife
fletch wrote:
Cool
Ahhh, it was the bolts in the crossover pipe holes that threw meDoh
Cool
Team 330™Cool
Posted 24th Dec 2008 at 06:14
