displaying posts 26 to 50 of 124
Pages (5): 1 [2] 3 .. last
Author Subject: High Boost Rotrex conversion
chris with a pug
I am glad I am not the only person who destroyed the valve stem seals getting them off.
Posted 24th Dec 2008 at 14:21
im just trying to remember what the woodruff key is for, my old workmate forgot to refit one once and had to take engine back apart to fit it, in some old hgv
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 24th Dec 2008 at 15:00
MCH_GTi6
formerly mch
Looks a good project Thumbs up
Wish I had the spare cash!
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 24th Dec 2008 at 15:08
chris with a pug
It turns the pullies
Posted 24th Dec 2008 at 15:18
rallyestyle
Good work Matt Thumbs up
Have you rebuilt an engine before? Your step by step approach has made it look quite logical, maybe i should give it a crack afterall Yes
Just Drive It
Posted 24th Dec 2008 at 15:39
mabgti
NV motors
Great work dude... glad to see its coming together..
NOTE: Be sure to clean off all the paint from the oil cooler exhange mating surface... IF it doesnt seal... you'll have pressure issuesYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 24th Dec 2008 at 21:33
fletch
Track Head
Was cleaned up prior fitting mate Thumbs up
Posted 26th Dec 2008 at 00:25
fletch
Track Head
New MLS Gasket:
Head is on Smile
All the brackets and sensors werer fitted to the block as well as parts of the wiring loom.
The thermostat housing, water and oil pipes were also refitted.
Found the oil level sensor had some frayed wiring, so repaired that while it was accessible
and dropped it back in.
Some new cooler NGKs ready to go into the head, cheap too Smile
Applying the SC kit
Sorting the inlet components:
Having test-fitted the Rotrex, Inlet adapter and Inlet Manifold, I used a bit of wire to
simulate the throttle cable routing. Given this, I marked up the inlet adapter and compressor
housing, ready to fit them together. A punch was used to help retain the inlet on the housing.
I then pressed them together.
You can imagine how fast the impellor spins when you see how far it movese in relation to a
small turn of the pulley. Cool
Next up was to fit the lower dipstick tube which I had been waiting on, and then the sump.
Had a hand from my assistant cleaning the sump...
The head was torqued up and was now ready to be timed up.
Fuel rail fitted - damn you Rich for anodizing it in gold Roll eyes Suppose it matches the
supercharger bracket now...
Grabbed a pulley from Rich and proceeded to time up the engine...
Engine timed up and Exhaust manifold fitted
Posted 26th Dec 2008 at 08:21
pedro_de_la_cruz
fletch that is top work Thumbs up
gold fuel rail looks funny LOL
*R.I.P Pete Sims*
Posted 26th Dec 2008 at 15:58
matty_rallye
Post #35
Excellent stuff mate, good read that!
2.1 16v 306 Rallye.
Posted 26th Dec 2008 at 16:08
sacko_gti6
Post #36
Excellent work so far!
Gold fuel rail? Blink
Build Date - 30 September 1997 - Tuesday's car..is full of pace? Wink
Posted 26th Dec 2008 at 19:25
zac
Post #37
Shit hot. Great read! Cool
Hit the limiter in 6th gear at 169mph (GPS - TomTom on the German autobahn). Still pulling like a train too. Cheers
- Phase 3 GTi-6 (409hp 'charged weekend toy)
- Phase 2.5 Rallye (daily driver)
R.I.P Pete Sims
Posted 26th Dec 2008 at 19:51
jib
Post #38
Just goes to show what you can achieve when you have the space, tools, time, finances and know how.
Top work mate.
Will be keeping a close eye on this one!
Posted 27th Dec 2008 at 00:51
puglover Banned!
Post #39
looking good fletch, great write up too Thumbs up
Posted 27th Dec 2008 at 00:54
rich_w
Post #40
Sorry about the fuel rail Matt Laugh
It's been zinc passivated, and is an ideal surface prep for painting, so you could always paint if it's really winding you up
Laugh
Contact Details:
07732 822546
Posted 27th Dec 2008 at 05:07
fletch
Track Head
Post #41
Had a bit of a rocker cover dilemma and decided on polished covers for now:
Just the PAS assembly to finish...
[Jeremy clarkson mode]Meanwhile..
I now set about putting the interior back into my other GTi-6 to use on the road during the engine swap.
Rich came up to sort my ECU out so I could run the car with the new engine fitted. Thanks to
his careful skills with a
Posted 28th Dec 2008 at 04:23
fletch
Track Head
Post #42
Engine swap
Time to get on with it Devil
One long serving and capable 167bhp engine Smile
Out with the old engine and gearbox...
The "Scooby burger" Crazy
My Quaife ATB was fitted to the crown wheel with the help of Sean's compressor. Should help with traction through the bends.
Next up was removing the clutch and flywheel and the bolt Sean had kindly rounded off for me
Whistle Roll eyes
Some grinder and drill action later, flywheel was out and ready to be fitted to the new engine.
Posted 28th Dec 2008 at 04:27
n3mo
Post #43
awesome read mate looking forward to the next install
owen
Deffo Need Better Rubber
Posted 28th Dec 2008 at 04:33
smighall
Smeg-all
Post #44
Mmmmmm my scooby burger
And those clutch bolts were a f*cking PITA, some muppet must have done them up too tight when they did the clutch Whistle
Meh
Posted 28th Dec 2008 at 13:10
mechanical_repairs
Post #45
Love the burger!
Bet that stops hunger for a bit. Going well, engine seems a bit red.
Carl
Posted 28th Dec 2008 at 15:17
pedro_de_la_cruz
Post #46
yeah i really want one of them! LOL
*R.I.P Pete Sims*
Posted 28th Dec 2008 at 15:23
cress87
Post #47
+1 That burger looks immense. Shifty
Posted 28th Dec 2008 at 19:32
mike rallye
Post #48
some good work fletch, will sound awsome when completed
Posted 28th Dec 2008 at 23:14
jib
Post #49
Sorry i may be abit late here but you get to choose between a low boost and high boost map at the flick of a switch? Thats some techno shit!
Is this the first time this has been done?
Posted 29th Dec 2008 at 15:49
matty_rallye
Post #50
mechanical_repairs wrote:
Love the burger!
Carl
Christ, id expect it to stop movement for a while aswell!!
2.1 16v 306 Rallye.
Posted 29th Dec 2008 at 16:13
