displaying posts 26 to 50 of 503
Pages (21): 1 [2] 3 .. last
Author Subject: Hybrid & 30mm ARB's
Trigger
General Trig
Any idea how much fitting would be Ash?
Trig
Posted 1st Apr 2009 at 00:13
drew o
im still looking to have one soon ash any joy on the price?
306 GTi-6™ In Moonstone FTWBig grin
Team Speedline Turini
PS3-Drew_o
Posted 1st Apr 2009 at 00:16
drew o
i deffo want a hybrid one ash anyone else for
PS3-Drew_o
Posted 1st Apr 2009 at 00:18
dommo
Assuming it's like a standard ARB to fit then it's easily doable in a couple of hours.
I fitted a GTi rear ARB to my diesel last year (when I was 18 - and I'm fairly car mechanic orientated, but not massively, I wouldn't touch a cambelt for example) and it's still fine, it made a creaking sound once so I retightened it and it's fine.
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 1st Apr 2009 at 00:23
Rich E Forum Admin
Two hours?!
The last one I changed I had done from start to finish in arond 20 minutes, and that included fitting new seals.
Even a novice should be able to do this inside an hour.
Posted 1st Apr 2009 at 02:50
james_geldart
Rich E wrote:
Two hours?!
what exactly is involved in fitting one of these, kwick guide anyone? Ive rebuilt my front suspension, and swapped the rear shocks and beam mounts , but ive always hesitated messing about with the rear beam (lowering etc)... i assume from what youve said its fair easier than swapping torsion bars and beam rebuilds? and doable with the beam on the car?
cheers
James
Recommends:
'mechanical_repairs' - Leicester
'miles' for suspension & Grp N/A goods
Baker BM Mounts
Posted 1st Apr 2009 at 02:53
clen666
I'd be interested in a hybrid arb Thumbs up
where is best place to get all the seals that need renewing?
Team 'unintentional rat look'
Posted 1st Apr 2009 at 03:12
tobeski
quote:
quote="james_geldart"]
Rich E wrote:
Two hours?!
cheers
James
Fitting is p*ss easy... basically take the rear wheels off, undo the smaller bolts holding the arb end plates to the trailing arms. Then get an M12 bolt and wind it in to one of the end plates so it comes of, then just pull the end plate on the other side and the whole bar will come out. Easy as that, 20 mins max.
Look at nwphoto's FAQ for lowering the rear as it's included in the process
Now rollin' in a 182FF
Posted 1st Apr 2009 at 03:25
dommo
I did say "easily doable in a couple of hours" Razz
So that's to include someone who's clueless (such as myself). Although I think it took me about an hour to do mine, winding that m12 bolt took some doing though, the end plate really didn't want to come off.
Posted 1st Apr 2009 at 05:15
scouse monkey
Post #35
If anyone is doing this and is around Bristol or Chorley/Preston and wants to get rid of their old GTI ARB then give me a shout on PM Smile
Posted 1st Apr 2009 at 14:29
dannygti-6
Post #36
Very intrested in this also
if this goes ahead at 165 i will have 1
Xbox Live = Sp4n
Team one gti-6 - 2 cherry rallye's
Posted 1st Apr 2009 at 18:39
monkeyman
Post #37
Just paid full price over at Spoox : (
but at least I get to play with this one soon : )
As said above, removing rear wheels and the end plates gives you access to the rear ARB fixing.
Forum Search Clicky
Posted 1st Apr 2009 at 19:27
smighall
Smeg-all
Post #38
I may well take one Ash, if you need to make numbers up Thumbs up
Meh
Posted 1st Apr 2009 at 20:35
fletch
Track Head
Post #39
Another taker here Thumbs up
Posted 1st Apr 2009 at 20:56
clen666
Post #40
1. drew o
2. andy+katie
3. clen666
4. dannygti-6
5. smighall
6. fletch
lets do this!
Posted 1st Apr 2009 at 21:31
Post #41
I'm also interested in one of these.
So if you buy this hybrid ARB nothing else needs to be bought to enable you to fit it to a standard 6?
Edit: Just read the original post Doh
Posted 1st Apr 2009 at 22:52
drew o
Post #42
nope unless you break something lol
PS3-Drew_o
Posted 1st Apr 2009 at 22:44
SteviePut
Post #43
One of my plans was to fit one of these. But I'm a little confused as to why it's a different thickness each end(I've never looked at one). Why is it not made at say 28mm all the way across? Or is it that it'll only fit in one way??Confused Surely the effective diameter is really only 25mm?? Or am I missing something.
And lastly, can someone who has one tell me what it's actually like? Is there a noticeable difference?
Posted 1st Apr 2009 at 22:56
smighall
Smeg-all
Post #44
Steve, it has to be a hybrid (to make it 25mm or whatever) as the sizes change in the trailing arms. So it will only fit from one side, otherwise you have to machine the trailing arm shafts etc IIRC.
Meh
Posted 2nd Apr 2009 at 01:10
SteviePut
Post #45
Cheers SeanThumbs up
Posted 2nd Apr 2009 at 01:31
SteviePut
Post #46
1. drew o
2. andy+katie
3. clen666
4. dannygti-6
5. smighall
6. fletch
7. Stevieput (I'll have to pay by chq so let me know when the funds are requiredSmile)
Posted 2nd Apr 2009 at 01:32
ash
Six Addict
Post #47
As per Sean's reply, 25.4mm is the biggest that will fit one trailing arm, and 28.5 is the biggest that will fit the other. All but 14" (IIRC) are 28.5mm, making it effectively the equivalent of a 27-27.5mm ARB rather than the std 24mm.
It will make a noticeable improvement to a std car and also works well if you uprate the suspension. It makes the turn-in better, whilst removing the roll induced weight transfer at the rear of the car. Basically it gives you controlable lift off oversteer.
The first one was fitted to my own GTI6 about 5 or 6 years ago; I currently use a 30mm ARB on my race 306.
Posted 2nd Apr 2009 at 13:35
ash
Six Addict
Post #48
1. drew o
2. andy+katie
3. clen666
4. dannygti-6
5. smighall
6. fletch
8. Shane
9.
10.
Looks like this will go ahead as soom as I have the cash. PM me and let me know how you would like to pay and I'll send you my details.
I'd rather have a bank transfer of
Posted 2nd Apr 2009 at 13:52
clen666
Post #49
Shweeet, lets get to 16! :p
Are you taking payments now then?
Posted 2nd Apr 2009 at 15:16
drew o
Post #50
i can pay end of april if that ok mate? defffffooo want one come on guys get the numbers up to 16 Big grin
PS3-Drew_o
Posted 2nd Apr 2009 at 16:12
