displaying posts 1 to 25 of 50
Author Subject: Alloy top mounts on KW's
mabgti
NV motors
Have a bit of a problem...
Got a pair of alloy top mounts from compbrake to fit on the KW coilovers. Thing is.. i'm confused as to how they go on..
Compbrake said... fit washer on rod.. fit top mount on top of spring pan.. and then use sleeve nut.. No thrust bearing or additional bits..
Firstly the top of the KW rod has a spacer as standard.. so if i use the washer it reduces the amount of thread available on the top. So i took away the washer and the KW thread spacer fits snug into the spherical bearingBig grin and the sleeve nut tightens nice..
But is it meant to fit like this? as surely the spring will move around under the top mount being flush?
mabgti has attached the following image:
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 28th Sep 2008 at 04:21
mabgti
NV motors
kit
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 28th Sep 2008 at 04:23
mabgti
NV motors
flush...
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 28th Sep 2008 at 04:24
mabgti
NV motors
anyone tried these?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 28th Sep 2008 at 19:26
Spring should be fine once there's some weight on it, it's only the same as the bottom spring cup after all.
So long as they're ground straight they'll stay straight, the only problem I'm guessing that spacer doesn't account for the angle that the mounts may be running and is just a straight block?
Posted 28th Sep 2008 at 19:38
puglover Banned!
but you dont have a shoulder on it anymore so as soon as you put some weight on the shock it will come through the top hat. And without the springs on a bearing central to the rod it will grind away like a dick when you turn. Pics of i how think it should be done coming.
Posted 28th Sep 2008 at 20:13
Well normally there would be a top spring pan that sits on the rod and butts up against the top hat spacer, but he doesn't appear to have one?
Posted 28th Sep 2008 at 20:11
puglover Banned!
this allows the strut to sit at an angle properly whilst retaining vertical forces on the springs. The top bearing will act as thrust bearing when weight is on it allowing twist forces in the springs to move also.
This takes some f*cking about and im not taking them apart to show you exactly how its done but you drill the top hat hole to fit the rod through perfectly with zero play. (Exactly the same diameter as the bearing) then in this spacer thing thats below the threads on the KWs grind two flats to get a spanner onto (this keeps the rod still when you tighten the nut on top) HAve the nut put on a lath to get maximum sleeve on it safely. This gives you enough bite (turns) on the threads for it to be strong and safe. Put it together with springs wound down to lowest point so you can get a spanner in between top hat and strut top to tighten it then wind the springs up and push the spring hat up to the top.
Posted 28th Sep 2008 at 20:21
puglover Banned!
demon theives also sell flat needle bearings the can be put top and bottom of main springs then youll be proper sorted Thumbs up
Posted 28th Sep 2008 at 20:23
mabgti
NV motors
cheers john.. i understand it now.
Where did you get the tophat from and how much?? As combrake said i didnt need one!
Compbrake said to assemble as i've done.. w*nkersFlip
But.. the spacer on the rod thread is removable isnt it? surely its just screwed on.. As eibach are sold with long or short threads but KW just used spacersYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 28th Sep 2008 at 23:17
puglover Banned!
top hats are from compbrake LOL they are the 2.25 inch ones. Dont let him charge you more than
Posted 28th Sep 2008 at 23:28
mabgti
NV motors
Got a set of proper top hats ordered.. Just need to find out if KW spacer on the spindle can be taken off... as this will save alot of hassle..
It cant be fitted like this as john says..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 29th Sep 2008 at 20:51
Got a better picture?
Posted 29th Sep 2008 at 20:52
mabgti
NV motors
in talks with KW germany to find out if the spacer on the spindle can be taken off... Alot of the 106/saxo lads have a similar problem.Yes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 29th Sep 2008 at 22:08
midlife
The material that the spacer is made out of is different to the material that the shaft & thread are made out of, imho if it went on it should come off. I tried takling John into having a go at taking his spacers off but he wasnt too keen.
Cool
Team 330™Cool
Team "no front end or engine"
Posted 29th Sep 2008 at 22:57
puglover Banned!
Thing is you'll be fine and better off doing it like i have, you can have top hat with some threads through it which will eventually wear and produce a sloppy fit or drill it and have it 100 percent surface area tight in the hole which wont wear, you have an allen on the top so you dont need to grind any flats either to tighten the nut. Just get it sleeved to its max.
Posted 29th Sep 2008 at 23:11
mabgti
NV motors
Well... they're not 2.25" jon... as they are way too small.. Should've listened to sales man when he asked me three times... "you sure they are two and a quarter.?"
"Yeh cos JON said so!"
Should've pulled my finger out and measured the coilsLOL... 2.5" top hats en routeYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 9th Oct 2008 at 23:07
puglover Banned!
when you say way too small how to small??? think you will find that the 2.5s are way to big i had this very same problem none of the compbrake hats fit my springs exactly so i had to grind off the paint on the top of the springs.
They are only about a mm out.
Posted 9th Oct 2008 at 23:12
Sure they're not 60mm ID with them being KW's?
Posted 9th Oct 2008 at 23:18
puglover Banned!
probably yeah. they seemed different as i had both 2.25 and 2.5s and both wernt right. LOL
where do you get 60mm ones from?
Posted 9th Oct 2008 at 23:22
Rally design used to do them, but these days I hit the '60MM TOP COIL MOUNT' program on the mill, put in a chunk of 7075 T6 and press 'Go'.
Razz
Posted 9th Oct 2008 at 23:25
puglover Banned!
LOL
Posted 10th Oct 2008 at 00:01
mabgti
NV motors
Phillip why didnt you say so! Price for pair please...
jon... SO 2.5" fitted yeh?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 10th Oct 2008 at 00:28
puglover Banned!
no 2.25 with a lil shaving off the springs i was gonna tell you about it but i forgot.
Posted 10th Oct 2008 at 00:35
mabgti
NV motors
Dude... i have 2.25 inch in my hand now... they are silver and very flat topped...
The ones you have are BLUE 2.5"... the coilover spring ID is 2.4"
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 10th Oct 2008 at 00:37
