displaying posts 26 to 50 of 97
Pages (4): 1 [2] 3 .. last
Author Subject: AP Racing Budget Brake Project
rallyestyle
315mm would be very impressive under 15's Thumbs up Every mm counts Devil
Just Drive It
Posted 8th Sep 2008 at 17:36
Welly Forum Admin
Well done mate. If you can send me the piston sizes i'll work out the breaking force for you. Give you a rough idea anyway.
Vrs power!!
Posted 8th Sep 2008 at 19:12
rallyestyle
Cheers Welly that would be cool as i have no idea Doh
Leading 38.10mm and Trailing 41.3mm (1.5" & 1.625")
Ap Site says the piston area is 49.5 although i presume thatas mm squared Dunno
Just hope it goes together smoothly on the car now Yes
Just Drive It
Posted 8th Sep 2008 at 19:55
So they should have approximately 96% of the braking power of the gti6 calipers when considering piston sizes alone.
Of course, the AP caliper is a lot stiffer so outright braking power should be much the same (bar the effect of the bigger discs), along with less pedal travel.
Posted 8th Sep 2008 at 19:35
rallyestyle
Yeah just had a look on the web Phil and if calcs are right it's 97.5% of the braking power so you were nearly there with your approximation Yes Thumbs up
After driving my mates Caterham at the weekend with an AP setup im looking forward to the reduced pedal travel Smile
Just Drive It
Posted 8th Sep 2008 at 20:15
I get 96.83% working it out? Unsure Dunno
Posted 8th Sep 2008 at 20:32
rallyestyle
So it's the combined piston area for one side right? I may have that wrong Dunno That's 1.77" + 2.06" = 3.83" square
Normal is 3.93 i think Unsure
1% of 3.93 = 0.0393
3.83/0.0393 = 97.5 (1dp)
I dont really have a clue though mate so your probably right Laugh
Just Drive It
Posted 8th Sep 2008 at 20:55
Well, I did it from the mm dimensions so there may be some lost in translation LOL:
Quick conversion for standard pistons gives me 3.97 square inches.
Posted 8th Sep 2008 at 20:59
rallyestyle
Could be Yes I updated the post a bit above with the measurements in inches too, they were on the AP Racing diagram but at the time i thought mm was more relevant Doh
Just Drive It
Posted 8th Sep 2008 at 21:30
rallyestyle
Post #35
*Small Update*
The brake discs and brake fluid have arrived so they are all set for fitting now Yes
With the help of Chris (matoski) i went for the OE Brembo 406 Coupe discs and i must say quality wise they definitly look the business, thanks once again Chris Thumbs up For the brake fluid i have a litre of Motul RBF 600, this fluid is a DOT4 fluid with excellent wet and dry boiling temps that rival and in some cases exceed various DOT 5.1 fluid along with the advantage of not needing to be changed so often.
I plan to get everything on the car over the weekend so i will update with some pics once i have it done Yes Smile
Just Drive It
Posted 16th Sep 2008 at 20:12
matsoki
Post #36
No problem Tom, gald to help.
Can't wait to see the pics all built up.
Am I reading the thread right, you have a less clamp force than std calipers?
But you should have gains from the bigger pad area, and disc dia? But with more control because of the calipers?
Built on 25th November 1998... That was a Wednesday..... Thank God it wasn't a Friday!
RIP - Pete Sims
Posted 16th Sep 2008 at 20:53
rallyestyle
Post #37
Something like that mate i think yeah Yes Im not really sure of the math but the calipers are the ones supplied by AP Racing for their 306 Road/Rally kits so they will be up to scratch Yes Guess i will be able to compare come monday Smile
Just Drive It
Posted 16th Sep 2008 at 21:01
Post #38
Yep, but that's not a problem, it's only a function of master cylinder area vs piston area's anyway. You can get more clamp pressure by putting a smaller master cylinder on a standard setup.
He should have more leverage from the discs, less caliper deflection which will give a less pedal travel and more consistant braking.
The larger pad area will only really act as a larger heat sink for high speed braking, to help a little with pad temperatures, and it will reduce pad wear, the actual friction isn't affected much by pad area.
They'll wear more evenly too, and get less pad knock off, which'll reduce the pedal travel some more. They'll certainly feel far better just from that.
Which means you can go down on the master cylinder size if you want more power but with the same pedal travel.
Posted 16th Sep 2008 at 22:22
rallyestyle
Post #39
Thanks Phil, good to know that info for the future Thumbs up
Just Drive It
Posted 17th Sep 2008 at 14:10
Post #40
Well, we'll find out shortly by the sound of it Big grin
Posted 17th Sep 2008 at 15:59
mabgti
NV motors
Post #41
hows this going now?
test fitted yet? squeel?
Just wanted to know if the crossover pipes are original?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 22nd Sep 2008 at 22:13
puglover Banned!
Post #42
LOL optimism
Posted 22nd Sep 2008 at 23:09
mabgti
NV motors
Post #43
slightly inquisitive...
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 22nd Sep 2008 at 23:17
rallyestyle
Post #44
On the phone here so will update tomorrow at work but yep they are fitted (mighty close though) and so far zero squeal although i have only tootled around until i can bed them in properly Yes Check back for an update tomorrow, they look sweet Devil My thumb hurts now Laugh
Just Drive It
Posted 23rd Sep 2008 at 00:11
fletch
Track Head
Post #45
Happy Birthday Tom Cheers
Posted 23rd Sep 2008 at 00:57
chet
LongtimeLurker
Post #46
Happy Birthday
Happy Birthday mate, have a good one Cheers
Look forward to the pics Cool
___=[ 306 RALLYE ]=__
Rallye Pics///R.I.P: T499 HFC///Farewell: T153 JCP <==Love ==> Welcome: S2000
Posted 23rd Sep 2008 at 01:03
stu
Post #47
Happy Birthday Cheers Hope you have a good one Tom.
Look forward to the update.
Posted 23rd Sep 2008 at 01:06
rallyestyle
Post #48
Cheers guys, thought i would take the day off, cant stand working on my Birthday Laugh
Anyhow i have some pictures, sadly i only realised this morning that in my entusiasm to get them on and take the car for a spin i forgot to take some of them with the wheels on Doh Laugh Anyhow i will do that tonight Yes
Fitting was not that hard, i had some issues with a siezed nut on one of the brake lines but for some reason this decided to loosen itself over night to my surprise Smile I made a weekend of it and did the rears too so it was sort of a complete brake overhaul Yes
Anyhow here are some pics of the badboys all attached, i got funky with some yellow paint too Whistle
Now one caliper wasnt bleeding very quickly so i think it may have issues as it wasnt functioning that well on my test drive Doh I believe there may be a blockage going into the caliper somewhere but i will have to wait till the weekend before i can get a look at that Yes For now i have left the serious bedding in until i can get it fixed, once thats done i can start giving some decent feedback Yes
On another note while doing the fitting i realised the discs could probably go to 315mm quite easily on the current bracket and if i was to offset the whole lot like in Ash's kit i reckon i could go 330mm or perhaps slightly bigger, there is buckets of room further back although as Ash suggested i believe the balljoint would be a deciding factor as to how far back any disc could go Yes
Watch out for the pics with wheels tomorrow Thumbs up
Just Drive It
Posted 23rd Sep 2008 at 14:54
matsoki
Post #49
Looks very tidy....... Love
The new black coating on the brembo dics look good too....
Get them wheels on.
RIP - Pete Sims
Posted 23rd Sep 2008 at 15:52
russbez
Post #50
where is that pop corn smiley when you need it
looking very tidy Yes
My Rallye project thread
Posted 23rd Sep 2008 at 18:28
