displaying posts 1 to 25 of 76
Pages (4): [1] 2 3 .. last
Author Subject: 205 rallye, gti6 on tb's
rallyeash
ive got to reblock my rallye so thought i would share my progress
bonnet off.
front bumper off
then i whipped the head off to make it lighter as i didnt have a engine crane
and tooke rad out
then i took the box off and lifted the block onto the floor and slid it out the nearside wheel arch, forgot to take a pic of that lol
all loaded up in the van.
then covered the rallye over.
last night i removed the crank from the old block, cleaned it up and fitted it to the new block, along with oil pump sprocket, chain and new crankshaft oil seals. also fitted new water pump
then i put the pistons,linears and rods back in the new block.
turns over like is should
all thats left to do on the bottom end is torque up the crankshaft, rods, fit oil pump and sump.
then i can bolt the head and box back on then get it back in the car
hoping to get the engine all torqued up tonight and get the head back on.
ash
_________________
309 3dr K20 Type R
Posted 10th Sep 2008 at 17:22
bet that shifts!
Posted 3rd Sep 2008 at 20:57
is this one an Mi/gti6 hybrid? few of these lurking about now Big grin what was up with the block?
Posted 3rd Sep 2008 at 22:15
rallyeash
yeah certainly is a mi/gti6 hybrid
has a small crack on the back of the block and leaking a bit of coolant
309 3dr K20 Type R
Posted 3rd Sep 2008 at 22:20
rallyeash
spec is
1905cc alloy block mi16 engine
1927cc forge pistons
arp rod bolts
mi16 crank
gti6 sump
1.8 16v repair head gasket (to keep compression right)
gti6 head
cat cams (cant remember the model)
collin satchell 45mm throttle bodies
gti6 injectors
dta e48 ecu
sandy brown one off loom
group A lower engine mount
group N gearbox mount
be3 1.6 gearbox
mi16 final drive
quiafe atb diff
309 gti driveshafts
309 gti wishbones
205 1.9 gti hubs
205 1.9 subframe
205 1.9 gti arb and drop links
toyo r888's
compomotive 15" wheels
gaz coil overs
group n top rubbers
omp strut brace
309 gti rear beam
omp record 2 seat
corberu passenger
omp 10 point cage
fully stripped
willians harnesses.
poly carb windows.
heated front screen.
battery in boot
gti-6 brakes
s16 rears
braided hoses
wilwood bias valve
brake lines internal.
309 3dr K20 Type R
Posted 3rd Sep 2008 at 22:41
rallyeash
engine is now all torqued up and have fitted the head and bodies back on.
tonight im going to bolt the box and starter back on and maybe even get it back sat on its mounts.
will get some pics up later.
going to try get it down sandy's by the end of the month for mapping.
ash
309 3dr K20 Type R
Posted 10th Sep 2008 at 17:18
rubenf.
It
Hug from Madeira Island
Posted 10th Sep 2008 at 19:26
jenvey_gti
Truely awesome car, those wheels would look better in white though imo Razz
R.I.P. Pete Sims
Posted 10th Sep 2008 at 22:33
bonzo
As said, this looks great, would love to see it when completed!
Like jenvey_gti said, I would have gone for white wheels on a white car if it were mine, but its your baby and looks great either way!
Bet that thing is quite an experience to drive!Love Keep updating!Thumbs up
Ninja Black Rallye Ninja
Posted 11th Sep 2008 at 07:16
rallyeash
thanks for the comments, i did have white compo's about two years ago when it was a 1400.
im thinking about getting these ones done in white, but will wait until i need to change the r888s and do it at the same time.
309 3dr K20 Type R
Posted 11th Sep 2008 at 14:03
captaink
Good to see another 16v 205 around (I have a 205 GTi6 with unknown set of Catcams in it).
When I got home last night, my G/F demanded that I take her somewhere expensive - so, I took her to a petrol station.
1993 L reg 205 with GTi6 engine and GTi6 brakes
1995 M reg FTO GPX manual
Posted 11th Sep 2008 at 18:21
rallyeash
finally some pics, going to get the engine back on its mounts sunday i hope Razz
flash was a bit bright
309 3dr K20 Type R
Posted 19th Sep 2008 at 01:53
Whoa, my eyes! LOL
Could you get it much shinier?
Posted 19th Sep 2008 at 05:33
petegti6
phillipm wrote:
Whoa, my eyes! LOL
Cue Manny with some photography b bulshit :llo
Cress87 wrote:
This place is getting beyond a joke. There's been an enormous influx of bellends signing up recently
Team 205 1.9 GTi ™
Team: Hmm™
Posted 19th Sep 2008 at 08:20
rallyeash
engine is now sat back on its mounts, will get some pics up later maybe, tonight im going to try get the driveshafts back in and have it sat back on its wheels Big grin
and if i have time start getting the coolant pipes back on and get some coolant back in it
hoping to get it back to sandys for mapping next weekSmile
309 3dr K20 Type R
Posted 23rd Sep 2008 at 17:24
russbez
looking sweet
keep us posted Yes
My Rallye project thread
Posted 23rd Sep 2008 at 18:07
rallyeash
few updates over last few days
fron end back together and driveshafts fitted
cooler mounted
sat behind the number plate
all ive got to do now is fit the exhaust mani back on and a few odds and ends.
309 3dr K20 Type R
Posted 26th Sep 2008 at 02:41
chas
That's looking good. I quite like the idea of a Hybrid. Seems to be the best of both worlds Smile.
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 29th Sep 2008 at 13:43
rallyeash
thanks, yeah hoping thats its going be best of both worlds. we shall see in the next few monthsSmile
got a fair bit of work done on it over the weekend, fitted 10mm copper fuel lines and a 106 gti fuel filterSmile also stripped the dash out of my 1.6 im breaking and lightened it and put it in the rallye, along with the 1.6 dials so now i have 140 on the clock not 110, which was useless, and have oil pressure gauge, etc
will upload pics of the inside later on
309 3dr K20 Type R
Posted 29th Sep 2008 at 18:02
black_6_stirling
Looking good hows it coming along now ?
This is the video that made me want a 6
The 6is gone Cry
Posted 14th Oct 2008 at 03:43
mike rallye
some excellent work gone on there. so what sort of price has the project cost you ,do get to the spec its at now?
Posted 15th Oct 2008 at 03:16
wardy18
what fan are you running on that rad and where do you get them from?! im still running a very cut down standard 205 fan cage with one fan in?!
also how come the inlet manifold is soo long, i always thought shorter the better but i assume its like that for a reason and im no designer/fabricator, just interested?!
nice build by the way, good work
Posted 16th Oct 2008 at 21:37
rallyeash
i dont actually know how much ive spend on the car overall, (a fair few grand though) but ive enjoyed doing it aswell and learned a hell of a lot at the same time.
i havent had time to do much to the car over the last couple of weeks but ive got a track day at oulton park with practical performance car mag at the end of november so have to get it finished by then.
i got the fan from merlin motorsport at castle combe, was around
309 3dr K20 Type R
Posted 16th Oct 2008 at 22:17
rallyeash
havent really had any time to work on the rallye last few weeks but got a little bit done last night.
got the 6 manifold back on, fitted oil filter, put gearbox oil in it and a few other small bits.
im trailering it over to a customer/freinds farm at the weekend as hes got a four poster ramp i can use for nothing Smile
and ill be able to do the return fuel line, fit the downpipe and rest of exhaust and give it a check over before going to sandys.
few pics
fluids 'aquired' from work
6 manifold bolted up
fuel line
and just a few random ones
309 3dr K20 Type R
Posted 30th Oct 2008 at 01:18
I hope that W90 oil isn't going anywhere near the pug!!!
Posted 30th Oct 2008 at 03:20
