displaying posts 551 to 563 of 563
Pages (23): first .. 21 22 [23]
Author Subject: Wilwood brakes
mr swampy s16
**BAD SELLER**
Post #551
im on a real slow connection just awaiting the above pics to load up
Posted 18th Jul 2009 at 03:59
mr swampy s16
**BAD SELLER**
Post #552
those hoses you have there look more like 106 rears rather than fronts
and certainly aint front ones.
i will pm you details in a mo, but the ones i will supply are swagwd both ends same as the ones in wellys kit (which i supplied).
the one end will be male with a willwood taper thread on, you will need to remove the adaptor already in your hub as mine go straight in.
the other end will be a gti oe type fitting
Posted 18th Jul 2009 at 04:05
x69 rgg
Post #553
well. here they are. came back from my mates house last week. supercharger running. covered about 150 miles. initial bite seems good. earlier vauge feeling has gone. maybe bedding in? might bleed them again when they're had some more use. but ive got a horrendous squeel now. only on low speed braking it seems. im using the mintex 1144's for the wilwoods from rally design.
still, look farking nice though!! Love
cheers welly Thumbs up
"I need to 're-mortgage' my six"
Posted 11th Aug 2009 at 03:50
SteviePut
Post #554
Look like mineSmile But I'm using the Smartpad from RD. They squeal like a good un but only when warm. When they're hot or cold they don't make a sound. Fantastic stopping power once they're bed inNinja
Posted 11th Aug 2009 at 03:52
t5 hdj
Post #555
will 205 speedlines fit over wilwoods with the 11mm spacers anyone know??
WANTED: Mint crystal headlamps
Posted 4th Dec 2009 at 00:44
SteviePut
Post #556
If you pop down with a wheel and a spacer you can try it on my carWhistle
Posted 4th Dec 2009 at 03:22
vts_tibi
Post #557
have you tried the original steel wheels over them?
but it would be the very best to try a C5 steelie, but there's only a few mm difference between the two
VTS
best 60' : 2.272
Team Trackday™
Posted 4th Dec 2009 at 22:05
Panchitus
Post #558
Hi
Does anyone can help me with a pair wilwood caliper brackets???
thanksThumbs up Thumbs up
Posted 13th Feb 2015 at 17:05
pugheaven
Post #559
Rallye design sell them I think
Posted 13th Feb 2015 at 17:06
Post #560
not the ones in this group buy that happened years ago, only ones to fit their own 285mm disc.
Posted 13th Feb 2015 at 17:07
pugheaven
Post #561
I'm sure when I had wilwoods and used standard discs they just had some washers to space the mount out/in to give the correct offset
Posted 13th Feb 2015 at 17:10
Panchitus
Post #562
Thanks MateThumbs up
Posted 13th Feb 2015 at 17:29
Panchitus
Post #563
Panchitus wrote:
Hi
By the way, I do not care if the brackets are used !! faster payment!!Thumbs up Thumbs up
Posted 13th Feb 2015 at 17:31
