displaying posts 326 to 350 of 563
Pages (23): first .. 13 [14] 15 .. last
Author Subject: Wilwood brakes
SteviePut
Post #326
How heavy are the stds Paul? Do you know?
Posted 22nd Nov 2008 at 19:20
Post #327
~4.6kg for caliper, carrier and part-worn pads.
Might be out a little as that was an old-kitchen scales job Smile
How much do the wilwoods come in at?
Posted 22nd Nov 2008 at 19:39
Welly Forum Admin
Post #328
Complete calipers with pads:
Wilwoods 2.6kgs
Stds 4.8kgs
Vrs power!!
Posted 22nd Nov 2008 at 19:44
Post #329
2 kilo's per side is a hell of a saving on unsprung weight, Hmm
*Checks bank balance*
Posted 22nd Nov 2008 at 19:53
SteviePut
Post #330
Just got the brackets etc. Cheers PaulThumbs up
Phil, how did you manage to get them so shiney? Must have been a very fine/slow finishing cut. Unless you've polished them??Confused
Posted 22nd Nov 2008 at 20:22
SteviePut
Post #331
smegal wrote:
SteviePut wrote:
Edit: I've been looking through the RD catalogue and couldn't help noticing the Superlite 6-pot caliper has the same mounting centre measurements. Hmmmmmm LOL
If only they had dust seals for the road.
But do you really need them? Those AP's that, whats his name, has fitted didn;t have them did they?
Posted 22nd Nov 2008 at 20:23
Post #332
Posted 22nd Nov 2008 at 20:39
rallyestyle
Post #333
Who me? Whistle
They did not have conventional dust shields by the looks of things but i spoke to a chap at ap racing and he assured me they did have seals to keep the dirt out Yes
Anyhow i did some research on the topic and no you dont really need dust seals so they would be fine Yes Would have thought you would require bigger disks though as although the mounting points are the same the offset of the caliper is most likely different Yes
Just Drive It
Posted 22nd Nov 2008 at 20:41
SteviePut
Post #334
rallyestyle wrote:
Who me? Whistle
I thought it was you tbh but I couldn't be arsed to look and didn't want to make myself look a pleb!! Laugh my ass off
Posted 22nd Nov 2008 at 20:44
jose
Post #335
Hi,
Have you done any investigation/ calculations/ FEA analysis into the stresses which are acting on the bracket under full braking load?
Whats the maximum shear forces acting on the cross seaction of the bracket? and what factor of safety have you engineered into the bracket?
I have access to ESDU charts if you want to use them.
Jose
Nile Blue GTi6
Alpine White 205 GTi 1.9 - Project
Air Con Pipes Thread.......
Machine Polishing - Paint Correction - Swirl Removal in West London - PM for details
Posted 24th Nov 2008 at 03:11
Welly Forum Admin
Post #336
jose wrote:
Hi,
Jose
Pass, thats why i left Phil to do them as he knows much better than i do.
Vrs power!!
Posted 24th Nov 2008 at 03:39
Post #337
Minimum strength shear failure around the bolt area would take 11.93ton-force, based on a 5x1,000,000,000 cycle length.
Maximum brake loading based on the absolute maximum brake line pressure and .5cf pads, with -3 braided hose is 2.72 metric tons.
(For interests sake predicted failure mode is never going to occur across that shear area, the bottom half of the bracket especially is almost entirely in tension, nominal predicted deformation strength is therefore 29.82tons, although the caliper mounting bolts would let go first)
Nominal braking force given 1g of deceleration on the stock car is 885kg-force, dependent on car attitude.
Slightly over-rated, I'd bet on the cast hub mounts going before the bracket did...
The spare one has been under the press and checked to 10 tons, hence the marks from the jig around the bolts (not going to press on a caliper!)
I can test it until failure if you want the figures?
Posted 24th Nov 2008 at 04:14
Welly Forum Admin
Post #338
LOL nope thats fine by me
Vrs power!!
Posted 24th Nov 2008 at 04:12
Post #339
Thumbs up
The original one was more than strong enough tbh, but hey LOL
Posted 24th Nov 2008 at 04:13
smegal
Post #340
Got the fitting kit today. It looks SEXUAL. There is something rather aesthetically pleasing about well finished metal. Cant wait to get 'em fitted as soon as the spacers are made. Hyper
Ex SC-6
Now in a Megane R26
Posted 24th Nov 2008 at 20:36
psjunkie
Post #341
got mine fitted on sunday! all i can say is awsome job welly a huge difference on the std setup. Just a pointer here lads when your fitting make sure you have a ¼" ring spanner for the bleed nipple i was fooked without one LOL
Was a tight squeeze behind the comps about 1mm clearance from front of caliper to back of spoke! EEEK!
got piccy too but i cant get them onto the pc argh!
1997 P1 Gti 6 Charged
Posted 24th Nov 2008 at 21:19
psjunkie
Post #342
Added some pics, sorry about the HUGE size !
they are in this album.. as photobucket aint working properley so i cant get the direct IMG link
pics
i will sort some better pics out when its been washed/nicer day
Posted 24th Nov 2008 at 21:56
Post #343
Posted 24th Nov 2008 at 21:55
psjunkie
Post #344
cheers bud
SteviePut
Post #345
I'm assuming they're fitted WITHOUT spacers??
Posted 24th Nov 2008 at 22:53
Welly Forum Admin
Post #346
Yeah i did mention that the bleed spanner was an odd size.
They look sexual behind them Mo's.
Really pleased you like them and they are working.
Thumbs up
Vrs power!!
Posted 24th Nov 2008 at 23:16
garry
Post #347
Spacers list:
1. walls99, money ready.
2. smegal, money ready.
3. bininoz money ready
4. Stevieput, money ready.
5. Garry, money ready (if they fit 205's)
Do you know if these spacers will be suitable for the 205 Speedline/SMR alloys?
205 GTI6 S
Posted 24th Nov 2008 at 23:29
Welly Forum Admin
Post #348
Ask Phil regarding spacers.
I'll be honest i don't have any experience with the 205 wheels. But i'd imagine it would be ok as i have seen 306 with 205 wheels on
Vrs power!!
Posted 24th Nov 2008 at 23:31
psjunkie
Post #349
Love with the mo's
no spacers fitted at the moment they are very close im been sorted with some 3mm's though Wink just to bring them out a little.
First impressions are awsome. didnt want to go too mad though untill i get them bled properly and made sure everything is sound and ok!
When i removed my old caliper the pads litrally fell out think it was missing some clips hahaDry
A bit blurry but heres another
Posted 24th Nov 2008 at 23:53
SteviePut
Post #350
garry wrote:
Spacers list:
Gary, when i get mine fitted I'll let you know as my track wheels are 205 alloysSmile
Posted 25th Nov 2008 at 22:31
