displaying posts 426 to 450 of 659
Pages (27): first .. 17 [18] 19 .. last
Author Subject: 2wd Offroad Buggy
Post #426
Posted 1st Jul 2012 at 12:11
Post #427
Posted 12th Jul 2012 at 22:21
Post #428
Posted 13th Jul 2012 at 13:48
Post #429
Might be for sale if anyone's interested, comes with s**tloads of spares, just needs an engine adding to give a grin so big yer ears fall off.
Posted 26th Jul 2012 at 00:27
Post #430
Right, as above, now for sale, will come set up for the Mazda rotary engine but could be altered if needed, plenty of spares negotiable with package.
Posted 7th Oct 2012 at 20:59
Post #431
Watch admin doesn't delete the thread now its become an 18 page car ad. :pmsl
Posted 9th Oct 2012 at 10:30
Post #432
Hey, you can't complain about not having a detailed parts list and history!
There's loads of racing near Southampton you know Thumbs up
Posted 9th Oct 2012 at 11:24
Post #433
Us southern softies are more evolved, we don't wallow in the mud, we trundle round on tarmac, far more civilised Razz
Posted 9th Oct 2012 at 12:05
Post #434
Nah, all you southern softies cheat and use 4wd.
Posted 9th Oct 2012 at 12:11
Post #435
Our advanced technologies will always keep us one step ahead of the North! Viva la South! Laugh my ass off
Posted 9th Oct 2012 at 12:20
Post #436
Yeah, it don't work, we just go past sideways and cover them in mud whilst they're crying about getting some dirt on their shiny race overalls Big grin
Posted 9th Oct 2012 at 12:22
Post #437
Savages! No respect for our Gucci threads Thumbs down
Posted 9th Oct 2012 at 15:15
Post #438
I have a completely rebuilt Renesis high-power (230) engine available if anyone knows anyone after one. It has a series 1 sump and oil system/side irons but the uprated series 2 housings (with extra oil injectors) and internals. Plus I have the S2 sump and oil system if required.
Basically, a S2 engine converted so it can fit in either S1 or S2 chassis. Plus I have uprated coils and other bits available (manifolds, etc) if wanted that can go with it.
Has zero miles on it since rebuild, which was finished a couple of weeks ago by WGT Developments:
Of course, if someone has a spare 306 shell, I'm sure we could sort something rather fun out....
Posted 12th Feb 2013 at 21:14
Post #439
I do...
Posted 13th Feb 2013 at 12:46
Post #440
There we go, sorted. I'll expect the cheque in the post, yes?
Posted 13th Feb 2013 at 13:21
Post #441
Expect all you like Big grin
Posted 13th Feb 2013 at 15:16
Post #442
It'll probably have the same result as expecting that racer to move any time soon, eh? Wink
Posted 13th Feb 2013 at 15:25
Post #443
Bingo Yes
Posted 13th Feb 2013 at 16:52
Post #444
LOL
I dub thee Midlifethe2nd
Posted 13th Feb 2013 at 16:53
Post #445
Right, we had this up for sale for a while, had a guy come to have a look, decided he wanted it if we could stick a cheap 2-litre 4-pot in it for him, so we sold off some of the rotary bits, did a bit of research, bought some parts and started chopping the frame...
...A month after that, he came by to say he was very sorry, but he couldn't afford to do it after all, and could he have his deposit back....:/
Anyway, since we'd done the research, started chopping, and bought some bits, and we had a bit of spare time over winter....it seemed rude not to give the old girl another chance Big grin
She's had a bit of plastic surgery courtesy of Mister 9 Inch (angle grinder, get your mind out of the gutter):
As the new engine is longer than the rotary, we chopped out the centre of the beam tube so that we can push the transaxle forwards into the cabin a couple of inches to keep the rear overhang similar, we don't need that reinforced part there any more anyway because it was what the old torsion bars used to run through/work against, so it was basically a great hunk of steel tube and plate doing nothing.
Free weight saving! Big grin
Posted 19th Mar 2013 at 12:36
Post #446
Anyway, one immediate issue was the new engine used a pull clutch, and there's no room in the transaxle to make that work, so we needed to convert to a push clutch somehow. We found a plate that was a similar size and a diaphragm that would fit, but the spline for the Renault transaxle was wrong, so we nipped up to CG Motorsports to see if they could stick us a Renault spline in the clutch we'd found (or a paddle version of it).
We used to just weld centres in off-the-shelf paddles for the VW clutch setup, but the splines never last that long as they soften a little from the welding heat no matter what you do to keep them cool, so we wanted to do it 'properly' this time.
Anyway, Mick had a good look, and decided he'd got an even bigger paddle and push diagphram already sat on a shelf that would go on the standard flywheel - provided we gave it a skim to take the raised surface off it - so we came back with a nice 230mm setup:
Which looks a little more promising than our old lash-up of Renault/VW/RX-8:
Posted 19th Mar 2013 at 12:37
Post #447
Due to a bit more weight/leverage and stress being anticipated this time, we went with poly mounts for the transaxle instead of the old solid strap system, there's no real movement in them for the engine torque, etc, they're simply to reduce shock loads on the gearbox from landings/frame flex.
And as you can see, moving the transaxle forward proved to be quite a tight fit....
Then we mocked up an adaptor plate for the bellhousing to the new engine, and bolted it up just to see how it fitted:
Which, as it turns out, is almost exactly where the rotary was after the alterations.
That big chunk of steel holding all these tubes together in the middle wasn't important, was it? I'm sure it wasn't. It'll be fine. Maybe.
Posted 19th Mar 2013 at 13:03
Post #448
That just looks wrong now, all those tubes terminating in thin air!
Will the sump need any oil control mods, as it's now a longitudinally mounted engine?
Posted 19th Mar 2013 at 13:18
Post #449
Yeah, one advantage of the rotary was the flat sump needed very little in the way of oil control, not the case with this.
Anyway, whilst we were at it, we thought about maybe going a touch wider on the rear tyres to compensate for the additional rear weight bias, might need a rethink on that one, not a whole lot of room left Laugh my ass off
And we checked the new clutch, after chopping a hole in the middle of the adaptor with the angle grinder, everything fits okay, but we've got loads of spare room in the bellhousing - there's a good 30mm of wasted space there, maybe more with a tweak of the release bearing, which makes the clutch quite snatchy as the lever arm is at an angle, so we might have a little rethink there, we stuck 2 release bearings back to back for the minute just to test the pedal feel:
And, after a bit of a trawl around scrapyards and ebay, we accidentally might have bought this, an Eaton M112 supercharger from a Jaguar 4.2L V8....it was so cheap it seemed rude not to...
Posted 19th Mar 2013 at 13:21
Post #450
Devil
Posted 19th Mar 2013 at 13:23
