displaying posts 501 to 525 of 542
Pages (22): first .. 20 [21] 22
Author Subject: My 306 Gti6 Throttle Boddies Race Car
Post #501
pete_rallye wrote:
You're going to cut out a perfectly good custom cages roll cage, and replace it with a bolt in job?! Seems a bizarre way aroud the problem. Surely it would be easier to find a professional welder, give him some money, and get him to sign something saying he installed it? All the MSA do is check the quality of the welds, and they may drill a small hole to check the thickness of the tubes.
Oh, and if you're complaining about the cost of racing already, I wouldn't bother going much further!
What qualifies a professional welder in the eyes of the MSA anyway? As far as I know they don't ask for a coding as such, so would a B-Tec, or City & Guilds, MOT/vehicle welding qualification carry enough weight to go through? I only ask as many motorsport firm seem to employ welders who although often perfectly good at what they do (myself included) don't actually have a recognised welding qualification.
Posted 20th Dec 2011 at 21:03
roberts_306
Post #502
It's a bolt in cage next time I can't justify spending over £600 when a bolt in
One will do the job
www.pugsport-racing.co.uk
Posted 20th Dec 2011 at 21:17
Post #503
still need some welding with a bolt in.
Posted 20th Dec 2011 at 21:21
Post #504
It's the usual vague legal wording of the person welding it must be 'competent', so if they have a crash and you end up in court it's a lot easier for the bloke who welded it to be able to produce a couple of structural tube certificates and say 'there you go' - MSA are just covering their arse and passing the buck...
Posted 20th Dec 2011 at 23:09
Post #505
typically uoui just send your sample wld to whoever supplied the cage tubing and they willtest it, or at least thats what CC do, I guess the MSA do similar?
Posted 20th Dec 2011 at 23:45
Post #506
Heres some I "Prepared earlier" LOL
Posted 22nd Dec 2011 at 18:37
roberts_306
Post #507
Been busy lately creating our website https://www.pugsport-racing.co.uk so not had a lot of time to do any major work.
16 Row Oil Cooler + pipes and adaptor plate purchased for Xmas
Front Bumper and panel removed, to get the car down to the same as Carl Chambers 306 Rallye, I am doing nearly the identical work so both fans removed
Wiring Tray removed from below panel
Horns and fan control module removed from passenger corner
Posted 10th Jan 2012 at 21:24
roberts_306
Post #508
Whole wiring loom currently being taken out then Carl Chamber is re-wiring car with Digital Dash, Headlights, Brake Lights, Indicators, Wiper Motor so alot of weight will be lost with all excess wiring, relays etc being removed.
ABS has been disconnected now and will also be removed by Carl Bias valve will be plumbed in.
Pics to follow soon
Posted 12th Jan 2012 at 22:17
roberts_306
Post #509
Front wiring loom removed from front end including washer bottle, fusebox.
Whole interior wiring loom removed, all wiring to tailgate removed. Dash was removed and binned as it was cut around the roll cage so new dash that is being cut down, all wiring removed.
Where the old roll cage was mounted all plates were ground flat.
Front FIA approved towing strap fitted.
Also today the steering column was painted in black satin, brackets painted for oil cooler, pictures will be uploaded tomorrrow.
Posted 9th Feb 2012 at 21:50
roberts_306
Post #510
10.8 Kgs of un-wanted cables removed from car. New loom to be made by Carl Chambers
16 Row Oil cooler mounted with long braided hoses
Posted 11th Feb 2012 at 14:31
davewagon
Post #511
Shock
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 11th Feb 2012 at 15:00
roberts_306
Post #512
Yeah the dash weights a load
Posted 11th Feb 2012 at 17:08
roberts_306
Post #513
Roll Cage turned up from Demon Tweeks, rubbed down and primed
New stickers put on by Carl Chambers to match his race car.
Posted 9th Apr 2012 at 20:55
eddy_gti6
Post #514
Looking good Cool you getting yourself a race licence aswell?
Posted 10th Apr 2012 at 20:40
roberts_306
Post #515
Thanks there's a lot going on
With my car over the next couple of weeks. I sure am getting my race licence but first I've got some track days to do my first one is at French car show at Donnington park
Posted 10th Apr 2012 at 20:55
roberts_306
Post #516
New dashboard cut down and fitted
Roll Cage test fitted into car
OMP Roll Cage welded in along with harness bar to the rear.
Wiring is currently being sorted along with digital instruments, all that I will have is Indicators, Main Lights, Wipers, Fog, Engine Start and fuel pump, these are the necessary items I want to keep.
Posted 11th Apr 2012 at 21:49
eddy_gti6
Post #517
Pics of your rear welded in harness bar please Cool
Posted 11th Apr 2012 at 22:44
Carl Chambers
Post #518
its not with Dave, the car is here with me, what pics do you want or what do you need to see?
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
Posted 11th Apr 2012 at 22:50
Post #519
looks like it shouldn't rattle much anyway! LOL
needs black masks though Whistle
Posted 11th Apr 2012 at 23:10
eddy_gti6
Post #520
Pick of how the harness bar in the back is welded to each arch, and the 2 side bars welded to the boot floor please
Posted 11th Apr 2012 at 23:28
Carl Chambers
Post #521
Eddy here are the pics of the harness bar,
its was put where it is mainly because there was plates still there from Daves old cage, so thought it a good idea to make use of them.
been doing the wiring on it today and its a night mare as always, but its all done now and the car runs again, just got to tidy it all up;
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 13th Apr 2012 at 21:02
jonnyvandijk
Post #522
Both cars look amazing, saw them yesterday and was very impressed. Dave you must be gutted you can't get out there with Carl on Sunday!!
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
Posted 14th Apr 2012 at 08:19
roberts_306
Post #523
Yeah I sure am but it's going to happy next year for sure Smile
Posted 14th Apr 2012 at 09:05
Post #524
You will need to change your catch tank for a biger one to comply with MSA regs I believe, great progress though, I need to get mine moving on Sad
Posted 14th Apr 2012 at 09:21
roberts_306
Post #525
Yeah wish I'd brought a 2 litre one in the first place
Posted 14th Apr 2012 at 17:02
