displaying posts 376 to 400 of 542
Pages (22): first .. 15 [16] 17 .. last
Author Subject: My 306 Gti6 Throttle Boddies Race Car
mabgti
NV motors
Post #376
looking good... but did the btcc have the induction piping to the left?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 23rd Aug 2010 at 05:00
spiky
Post #377
not by this pic
http://www.openpitlane.co.uk/forum/showthread.php?p=140374
if you fancy selling it, to buy a right hand one, i may know someone interested Big grin
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 23rd Aug 2010 at 12:38
roberts_306
Post #378
Got new map from Daveyboy uploaded today, runs a lot better now.
Carl took it for its MOT and it has passed Smile
I have 2 small problems with the Jenvey.
1) Backfires through the exhaust after lift off
2) Pops through the Jenveys on idle
Spoke to Omex they said to balance the bodies and adjust the map slightly.
www.pugsport-racing.co.uk
Posted 23rd Aug 2010 at 22:30
rallyeash
Post #379
sounds like it needs tweeking
309 3dr K20 Type R
Posted 23rd Aug 2010 at 22:55
309btcc
**DODGY SELLER**
Post #380
it will backfire through exhaust on lift off slightly but the bodies may be out of balance???
Posted 23rd Aug 2010 at 23:36
roberts_306
Post #381
Update
Omex have tweeked the 0% High engine Speed (Overrun) area.
They also said the Throttle Bodies will need balancing, hopefully this will correct the problems.
I wonder what Bhp increase I have?
Hopefully it will be near the 200 mark if not plan B will have to come into operation,
Posted 24th Aug 2010 at 00:22
rallyeash
Post #382
whats the rest of the spec without the tb's?
standard engines with bodies make somwhere in the regon of 185@fly
309 3dr K20 Type R
Posted 24th Aug 2010 at 01:21
mabgti
NV motors
Post #383
balancing in what way? you run a single cable to muli butterfly loop yes?
i've got a feeling it will be injector timingYes
and 0% overrun will mean harsher off throttle under load.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 24th Aug 2010 at 01:22
roberts_306
Post #384
Its got a Magnex Decat, and 3" Straight through exhaust.
Posted 24th Aug 2010 at 01:46
roberts_306
Post #385
Sorry this is what Omex said
See the attached calibration. I have increased ignition timing in the 0%thottle, high engine speed (overrun) area. Do a File | Compare to see exactly what I have done. This will not affect the performance in any way.
The pops on idle will almost certainly be the throttle bodies needing balancing.
Best regards
Andy Cornock
Omex Technology
Posted 24th Aug 2010 at 01:47
miles
Post #386
It's pretty easy to Balance the bodies when fitting, this is a must before anything is done really or you will never know where you are with one side being different to the other. You can measure them to start and either listen by ear (Old timers method and best) of use a Balancer guage which Omex etc supply.
On the power front as said anywhere from 170 to 180 I;d say from experance (Rollers depending of course)
I;ve done a back to back, abit on a tuned Mi engine both came in with the same power and torque 185bhp (Cannot recall torque fiqure) but one had the std 6 inlet and the other 45mm bodies both mapped at Emerald.
Other silly point, De-cat and it passed the MOT or was this done with the CAT fitted?
www.pugracing.com
Posted 24th Aug 2010 at 03:24
Post #387
Basicly one set of bodies is more open than thew other pair, you need to fiddle with the adjustment screw on the link mechanism between the two pairs of bodies. This is a bit of a fiddle but as Miles says it is vital. Get a foot of garden hose and put one end to your ear, then the other end into one pair of trumpets (does'nt matter which you start with as either PAIR are linked) listen to the sound between each pair of trumpets, if you alternate quickly you should be able to hear the imbalance. Adjust the screw until they both sound the same, if you have access to a carb balancing meter this job is a piece of p*ss, but good results can be had by ear if you are careful.
As for power, on a standard lump with just bodies you can expect something more like this...
Posted 24th Aug 2010 at 03:38
Post #388
Police LOL
Posted 24th Aug 2010 at 04:37
Carl Chambers
Post #389
rikky wrote:
Police LOL
Cat was back on for MOTWink
as for the problems, if watch the trumpets its popping in all 4 of them, so points to timing I would think?
All are balanced on a flow gauge?
will try the new map from Omex but ideally will need a tweak on a rolling road I would think?
All this just to get 180bhp seems a waste of time and a lots of money to me! My GTi-6 205 has 178bhp with the standard managment and inlet!
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
Posted 24th Aug 2010 at 12:42
rallyestyle
Post #390
I know, but yet people still do it Crazy LOL Must be the noise they do it for Devil
Just Drive It
Posted 24th Aug 2010 at 16:52
mabgti
NV motors
Post #391
LOL it sounds and drives differetnYes.. bit pointless when the rs inlet is a work of art!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 24th Aug 2010 at 18:06
roberts_306
Post #392
I would be happy with 180 Bhp for the moment until I have funds to do cams and engine work.
The supercharger gave me massive power but did not sound like a touring car so was pointless Smile
Posted 24th Aug 2010 at 21:43
pete_rallye
Post #393
Touring cars didn't have throttle bodies to start with! Its just most owners have moved to them for the extra 3bhp you get.
Lap of the 'ring
Posted 24th Aug 2010 at 22:33
roberts_306
Post #394
So basically 3bhp cost well in excess of £2000 good value for money NOT!
Posted 24th Aug 2010 at 23:19
pete_rallye
Post #395
Well, I got 5bhp, so much better value! For 260bhp+ you need to spend another £2k+ on the base touring car engine. Mainly headwork, but different pistons are needed too.
Lap of the 'ring
Posted 24th Aug 2010 at 23:58
Post #396
and ditch half of the engine bay bits LOL
what did chris bowen do with his ex btcc lump? just a thought
Posted 25th Aug 2010 at 00:01
rallyeash
Post #397
ive got his throttle bodies anyway...
309 3dr K20 Type R
Posted 25th Aug 2010 at 00:43
309btcc
**DODGY SELLER**
Post #398
bowen run it low on oil ad blew it up lol
Posted 25th Aug 2010 at 00:50
Carl Chambers
Post #399
Well the tweaked map from Omex has improved it no end, no more popping back on idle.
double checked the balance today with a flow meter and its spot on.
think its got to go on the rollers for the final tweaks and it will be there as its still not 100%, its alot better than it first was but gone as far as I can really.
but cost-bhp is not good not unless further engine work is done, so get saving now DaveRazz
does sound good thoughSmile
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 25th Aug 2010 at 02:15
mabgti
NV motors
Post #400
bowens was a high comp mi16..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 25th Aug 2010 at 02:22
