displaying posts 51 to 75 of 456
Pages (19): first .. 2 [3] 4 .. last
Author Subject: braided brake lines (new description)
scib4
Post #51
mr swampy s16 wrote:
Erm i wrote above i was working on it
Since the 4th of DecemberShock
as said above closest i have is the escort cosworth
That's twice you have told me that and i have no idea whyUnsure
if you can provide a set of old lines that can be copied then a set can be made to order
It has taken a month to get to this pointLOL
Mike
08 BMW 320d M-Sport touring (Superchipped Spec)
11 VW Transporter Kombi T5.1GP LWB (Bi-Turbo spec)
Yeti DJ (Jump spec)
Specialized SX Trail (DH spec)
Specialized Pitch (XC spec)
Posted 4th Jan 2009 at 00:55
nat205gti
Post #52
hello mate,how much for a set for a standard gti-6, with clear covers, and how much extra is it to have stainless fttings? i desperately need to change my brakes all round and want fitt braided lines at same time. thanks
Posted 4th Jan 2009 at 23:32
nat205gti
Post #53
received mine and very pleased esp. for the money. thanks mate
just need the sun to come out melt the snow so i can fitt them Smile
Posted 9th Jan 2009 at 19:46
nat205gti
Post #54
cool keeps us posted,i need some lol. and discs Sad
Posted 9th Jan 2009 at 21:43
pugbug
Post #55
How much are you doing some for GTI6 brake upgrade?
Posted 12th Jan 2009 at 14:06
mr swampy s16
**BAD SELLER**
Post #56
you have pm chap
order goes in tomorrow (friday)
Posted 16th Jan 2009 at 00:54
scrob
Post #57
Does the
Posted 21st Jan 2009 at 23:25
Post #58
these are good Yes
mr swampy s16
**BAD SELLER**
Post #59
Scib4, sorry cant help you
the ends are specific to them apparently and not viable for them to make
Scob you have pm
rikky cheers chap much appreciated
next order goes in friday
Posted 22nd Jan 2009 at 03:00
Post #60
I shall be placing an Order for some Yellow 306 GTi6 set very soon hopefully when I got the spare cash if dats k. also do you do sum for a focus in red front only? a mate wants to no
Posted 30th Jan 2009 at 15:57
mr swampy s16
**BAD SELLER**
Post #61
What year and modle focus?
Posted 30th Jan 2009 at 17:24
Post #62
t reg so it be 1998 hatchback mk2. i need to stop writing in text message style LOL someone will have ago at me
Posted 30th Jan 2009 at 20:03
mr swampy s16
**BAD SELLER**
Post #63
Mk2 focus with rear drums
Posted 31st Jan 2009 at 01:53
Post #64
opsy its i mk1 with discs on rear same price? will let him no
Posted 31st Jan 2009 at 19:55
mr swampy s16
**BAD SELLER**
Post #65
no yellow left
focus with rear disk set
Posted 5th Feb 2009 at 04:10
Post #66
are they stainless braid with stainless fittings and coated in plastic?
if so quote me happy for an early ZX16v kit minus the short ones to the calipers.
483mm long fronts, 194mm rears.
Posted 5th Feb 2009 at 04:46
Post #67
i have them throughout my 306, completely internal, they are good quality with good fittings Yes
pm'd you btw swampy
Posted 5th Feb 2009 at 04:52
Post #68
oki doki pose you have plain or carbon effect then?
Posted 7th Feb 2009 at 21:16
mr swampy s16
**BAD SELLER**
Post #69
Welshpug, zx isnt listed.
Though if the ends are the same as the 306 (id imagine they are)and those lengths are correct then a set can be made to spec
hovis16 yes carbon and clear both available
hose it ptfe lined stainless braided
ends are zinc plated mild steel of a very high quality
Posted 7th Feb 2009 at 22:18
puglover Banned!
Post #70
swampy how much for a full set like rickys? with bango ends for brembos at the front. front with t piece and from cylinder through bulkhead to rear beam and t off from there.
Posted 21st Feb 2009 at 19:44
mr swampy s16
**BAD SELLER**
Post #71
now your asking
if you could measure up i could tell you
had a diagram from rikky but have lost my hard drive with it on since them
ill sk rikky if he has the image still
Posted 21st Feb 2009 at 20:16
Post #72
sorry i dont remember sizes.. i know i had 2x 50" lengths for the master cylind -> bias valve / bias valve to rear t peice, then possibly some 60" lengths from each caliper to the T peice at the rear. then maybe 2x standard front ones to the strut holder, then from there to a T peice.. i forget their length.. i just made them up in wire first with proper ends on them
definitely a set of front standard hoses [stainless]
2x 50" lengths.. got knows what else LOL
edit> however i need to replace the bit that goes from the back of the bias valve to the beam, with something 10" longer as i dont have enough room to put the valve where i want to. infact the valve is a nightmare and with a passenger seat makes it tricky to mount
Posted 21st Feb 2009 at 21:31
mr swampy s16
**BAD SELLER**
Post #73
rikky did you get the measurement of that extra one you wanted??
can also do wilwood knob adjust bias valves at
Posted 22nd Feb 2009 at 15:11
Post #74
sorry yeah i did, i will check on monday and let you know
i have a wilwood lever one sat here, its fine, i dont want a knob style one No thanks though
Posted 22nd Feb 2009 at 15:38
puglover Banned!
Post #75
ricky what do you mean by
definatly a set of standard front hoses stainless??
Posted 22nd Feb 2009 at 19:27
