displaying posts 26 to 50 of 158
Pages (7): 1 [2] 3 .. last
Author Subject: 205 GTi6 'S' - Project build diary
studarude
Im using a similar oil cooler on my Mi 205 bud, got any thoughts on how you plan to route the hoses?
Is that a 16 row cooler?
Posted 30th Apr 2008 at 17:59
garry
It's a 19 row.
I have the hoses sorted now, although no pics until the weekend.
I have run an sandwich plate with a built in stat from the block to another stand alone oil stat (I found that the sandwich plate didn't close fully, so the oil was over cooled). The pipes then run over the rad into the cooler.
I used to use the spare fan cowling for the oil cooler which worked well too. But I couldn't do that this time due to the intercooler.
205 GTI6 S
Posted 30th Apr 2008 at 18:21
dave
wish I had the money and time to do things like this, great work Thumbs up
Posted 30th Apr 2008 at 18:44
garry
Evening all, got my new dummy Power steering pump today from Rich Walker. I have to say I am really chuffed with it, much better than running an actual pump in a closed loop as I had originally planned.
You may remember earlier on in the thread I made up a template for the pump and forwarded the details to Rich, the ‘pump’ had to be notched to clear the radiator.
From this:
To this:
I got the drive belt fitted to the charger aswell. I spent ages sodding around with the tensioner pulley trying to bend it back in order to fit the belt, I tried hitting it with various hammers, levering it with various screw drivers and chisels, taking it off and utilising the wife to hit it whilst I levered it (note: very risky activity). I then resorted to the Haynes manual (under wife’s instruction) although by this time I was convinced it was seized, low and behold all I needed to do was insert a ratchet into the square hole and lever it down! With that sorted progress could continue albeit with a very smug wife/ assistant. Blush
I had to cut a section out of the inner wing to clear one of the belt tensioners
I fitted my new SPAL 10’’ Fan, note the fitting kit is some long thin pins that slide through the radiator between the fins:
I finished plumbing in the supercharger fluid circuit, the black cylinder with the blue cap to the left of the headlight opening is the header tank.
Also a pic of the 19 row engine oil cooler fitted:
205 GTI6 S
Posted 4th May 2008 at 03:22
zac
Top work mate. Wink
Hit the limiter in 6th gear at 169mph (GPS - TomTom on the German autobahn). Still pulling like a train too. Cheers
- Phase 3 GTi-6 (409hp 'charged weekend toy)
- Phase 2.5 Rallye (daily driver)
R.I.P Pete Sims
Posted 4th May 2008 at 03:39
mechanical_repairs
Looks great, i so cant wait to get the rest of my kit.
Carl
Posted 4th May 2008 at 18:54
crossflow
will the rad you are using on your 205 fit a 306 aswell??
Nice car by the way i've driven a 205 with 280bhp but it's n/a and it only weights 750 kg's fiberglass everything and it was mad it will frighten the bejesus out of you.
Posted 4th May 2008 at 22:18
willygti
205 GTi-6 SC - aka 'The Nappy Filler' LOL
Team Ducati 748
2003 Subaru Impreza STi
Posted 4th May 2008 at 22:31
monty_rm
Its all looking good mate Big grin
Keep posting! Thumbs up
P3 '99 GTi-6 in China Blue
BMW 330Ci M-Sport
Chuck Norris' dick is so big it has its own dick, and even it's dick is bigger than yours.
Team Ninja
Posted 5th May 2008 at 18:45
rich_w
Post #35
Good work Garry Thumbs up
The dummy PAS setup is smart as, glad you're happy with it!!
Keep the progress coming - it must be nearly running my now?
Unsure
Contact Details:
07732 822546
Posted 5th May 2008 at 22:09
daza
Post #36
thats going to be 1 mental 205LOL
mclovin needs more power
Posted 6th May 2008 at 14:44
garry
Post #37
It won't start!
I will update later.
205 GTI6 S
Posted 6th May 2008 at 14:45
garry
Post #38
Ok, I need some help here. The car won't fire up.
I have fuel pumps working
Spark in the spark plugs
I have put a multi meter on the injector feed and get a pulse
Starter motor is turning
There is a pulse/pressure coming from the exhaust
I have tried adding power by boosting the battery with my BMW 530
but it won't fire up!
Help!
205 GTI6 S
Posted 6th May 2008 at 16:18
smighall
Smeg-all
Post #39
ECU unlocked? Fuel pipes connect the right way round?
CPS/CAM sensors connected properly?
Meh
Posted 6th May 2008 at 16:20
rich_w
Post #40
The ECU was tested on my car, so it SHOULD be OK.
If he's getting fuel and spark I would assume it's unlocked.
Has it definitely got fuel pressure? i.e. make sure there's no airlocks and the pumps are primed properly.
Contact Details:
07732 822546
Posted 6th May 2008 at 16:33
garry
Post #41
Thanks for the replies.
I thought the fuel system would self prime? Ie build pressure then return via the regulator to the swirl pot.
I will try the sensors again.
205 GTI6 S
Posted 6th May 2008 at 16:51
rich_w
Post #42
I don't think the ECU will give spark without a working cam / crank sensor.
But check anyway.
I can lend you another ECU to try if you think that's the problem.
The fuel system should all self prime - although it may be worth disconnecting the return from the fuel rail just to check it's flowing OK.
Contact Details:
07732 822546
Posted 6th May 2008 at 16:58
rallyestyle
Post #43
So any joy with starting her up?
Just Drive It
Posted 7th May 2008 at 22:14
rich_w
Post #44
Is it fook No
It's got compression, air, fuel and spark - everything needed for combustion - but it doesn't seem to be happening!
I've sent out another ECU to try, hopefully this will do the trick.
Really am puzzled on this one!!
Contact Details:
07732 822546
Posted 7th May 2008 at 23:31
smighall
Smeg-all
Post #45
I think it will have locked itself to your car rich when you tested it. Have you connected this one up to yours too before sending it out?
Meh
Posted 7th May 2008 at 23:46
fletch
Track Head
Post #46
Are the cam/crank sensors definitely known to be working then?
Posted 7th May 2008 at 23:55
garry
Post #47
The car ran fine before I took it apart.
205 GTI6 S
Posted 8th May 2008 at 00:18
Post #48
story of my life LOL
Posted 8th May 2008 at 00:24
rich_w
Post #49
I always do them in such a way they can't lock to, or be locked out by my car.
Also, Garry's ECU has been de-immobilised by an ECU repair firm, so it would work in the 205 without the transponder etc.
This means the immobiliser comms. pins inside the ECU have been cut - so this means there's no way it can become locked, even if fitted to a foreign immobiliser circuit.
Smile
Contact Details:
07732 822546
Posted 8th May 2008 at 02:08
mabgti
NV motors
Post #50
Must be fuelling, and i guess it'll be the fuel pump relay or the cutoff switch...
Check the loom from the ecu plug aswell as you've moved itYes
Again i doubt its the ecu as it worked on rich's car....
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 8th May 2008 at 04:44
