displaying posts 26 to 50 of 86
Pages (4): 1 [2] 3 .. last
Author Subject: 2.2 bottom end work
matty_rallye
Ha, the pistons and rods are from a 300zx 3.0. 87mm pistons. They are apparantly a very good and cheaper alternative to forged parts!
2.1 16v 306 Rallye.
Posted 1st Feb 2008 at 02:41
I wouldn't run without spray bars they are there for a reason Wink
Posted 1st Feb 2008 at 02:44
matty_rallye
Hmm yea, however i think that they havent been removed, very unsure on what caused the wear. I dont know if over-revving could cause it with the standard hydraulic lifter, it may be a possibility?!
2.1 16v 306 Rallye.
Posted 1st Feb 2008 at 02:52
ecureuil_zx16v
and rods???
wont this engine stay so square, vibrating?
Citroen ZX 16v
XU10J4RS turbo
Posted 1st Feb 2008 at 05:19
smighall
Smeg-all
Any chance you could ask and find out? I know no other XU10 heads run the spray bars.
Meh
Posted 4th Feb 2008 at 05:24
matty_rallye
Not a lot of progress yet, new cams have been decided on and being made at the moment. They are being custom built to a spec that Sandy has come up with by Newmans. Should have a similar lift to the old camshafts but a longer duration.
Dont know the exact specs of them yet but it will post it up when i find out!
2.1 16v 306 Rallye.
Posted 18th Feb 2008 at 23:47
puglover Banned!
any news on the crank yet matey
Posted 19th Feb 2008 at 05:34
matty_rallye
Still down there with the rest of the car mate. Unfortunatly i broke my ankle on sunday so i think it may be another month before i can even pick the car up Sad
2.1 16v 306 Rallye.
Posted 19th Feb 2008 at 15:35
matty_rallye
Pistons were machined yesterday to enlarge the valve cutouts
2.1 16v 306 Rallye.
Posted 19th Feb 2008 at 15:42
ecureuil_zx16v
Post #35
great!!
what max RPM will you run in this engine?
Citroen ZX 16v
XU10J4RS turbo
Posted 20th Feb 2008 at 02:05
matty_rallye
Post #36
After the mess of the old cams were gunna stick to 7250 or there abouts. In fairness with the higher capacity it should peak at a slightly lower rpm anyway.
2.1 16v 306 Rallye.
Posted 20th Feb 2008 at 03:21
matty_rallye
Post #37
Piccy of lightened and balanced flywheel and paddle clutch that is being fitted. Flywheel is now just under 4.5kg.
2.1 16v 306 Rallye.
Posted 21st Feb 2008 at 00:34
matty_rallye
Post #38
Little bit of an update!
Block decked and bored
Bits ready to go together
Rods with arp bolts
Crank in place
Loom made and wrapped
Unfortunatly there has been a small problem with the rods. The rods have an oil spray system from the factory which you can see in the pic at the bottom of the rod where there is a small lump. Problem being is that the engine would turn over fine in one direction but they would catch in another. Good job everything is tried before it goes back in the car.
Had to be stripped apart again and the rods have now been machined to fit.
2.1 16v 306 Rallye.
Posted 7th Jul 2008 at 14:57
petegti6
Post #39
Interesting, this should be the project section now matey, get some pics of the car itself too Cool
Cress87 wrote:
This place is getting beyond a joke. There's been an enormous influx of bellends signing up recently
Team 205 1.9 GTi ™
Team: Hmm™
Posted 7th Jul 2008 at 19:10
matty_rallye
Post #40
Ok, are admin able to do this?
2.1 16v 306 Rallye.
Posted 8th Jul 2008 at 02:10
mandic
Post #41
What sort of rods are u using? S16?
Posted 8th Jul 2008 at 04:44
petegti6
Post #42
300 ZX ones Yes
Team 205 1.9 GTi ™
Team: Hmm™
Posted 8th Jul 2008 at 04:53
Welly Forum Admin
Post #43
moved Thumbs up
Vrs power!!
Posted 8th Jul 2008 at 05:36
matty_rallye
Post #44
Excellent thanks.
2.1 16v 306 Rallye.
Posted 8th Jul 2008 at 14:30
matty_rallye
Post #45
Problems again unfortunatly. It seems that there is too much float on the crank end with the 300zx rods and it may go together ok but Sandy isnt too confident it will last as well as it should.
Looks like a set of forgies are on the cards Sad
2.1 16v 306 Rallye.
Posted 12th Jul 2008 at 01:32
Post #46
bummer, not wide enough? how long are they? std pin size I presume yeah?
Posted 12th Jul 2008 at 01:41
matty_rallye
Post #47
Yea the pin is standard, its the float on the crank thats the problem.
2.1 16v 306 Rallye.
Posted 12th Jul 2008 at 02:11
petegti6
Post #48
As in, the aren't wide enough so theres too much movement on the crankpin journal?
I did think it would have been a stroke of luck for some nissan parts to "just fit" on a peugeot crank LOL
Forgies FTW anyway Big grin
Team 205 1.9 GTi ™
Team: Hmm™
Posted 12th Jul 2008 at 23:42
matty_rallye
Post #49
I think it is a case of them not being wide enough. Sandy has got some opinions from a few other reputable builders and they seem to think that with the amount of movement there is they should be fine, not worth taking the chance tho imo.
2.1 16v 306 Rallye.
Posted 13th Jul 2008 at 16:47
petegti6
Post #50
Nope.
Whats the clearance, surely theres a spec for that in haynes anyway?
Team 205 1.9 GTi ™
Team: Hmm™
Posted 13th Jul 2008 at 18:13
